I am trying to setup my netopia 4432wg to connect to another netopia and set it up a wireless connection in a different room for other laptops.
    Master:
  • 395 Answers
Can you just setup wireless from the first 4432wg with the security key for laptop to use? It would be easier and simpler than connect it to the second router.
Posted on Apr 06, 2011
  • baggotm Apr 06, 2011
    The distance between the rooms are too far so i need the 2 nd router with wireless
  • Blue Chip 999 Apr 06, 2011
    Just to make sure, if using cable to connect two routers, you want to make sure the distance is within 328 feet.
    Issue the static IP for the second netopia as its wan IP, from second netopia give it different IP address and configure new DCHP scope for wireless. Once you can join the wireless network, make sure you can ping the first router and get out to the Internet.
I reset my Netopia Cayman 3347W wireless router and now my Laptop is not able to use the Wireless signal as it states that the connection manager is set to use only secure wifi but the reset signal is not...
You reset the router. that means router is set on factory default.settings has been changed now that's why connection manager is not responding properly. Now you have the run setup CD and set the router again.
Oct 11, 2012 | Netopia Cayman 3347W-Ent Wireless Router
A friends iof my gave me this router, but I don't know how to install it so that i can use it with my laptop in my living room. my internet is connect to my computer in my room. My main internet is in...
You have a few options. If you already have a router, set this one up as an Wireless Access point. It pulls signals from the main router and you can connect to this one. BUT your signal could be weak depending on the distance, walls etc. If you can make a cable run, use it as a switch. (Extend your ports, and as a wireless point. Go to Cisco Linksys and download the manual.It is not difficult. Use the main router as a your DHCP and this one as a wireless point. You will need to set up the SSID and security (Securty is optional, but I would do it). Give it a SSID different then your main one and you can setup your device to connect to the one with the strongest signal (Most do this by default.
Dec 18, 2010 | Linksys Wireless-G Broadband Router
Having trouble connecting to a Netopia 3347NWG-006 router using my wireless capabilites on my Acer Aspire One. My wireless connection at home works fine, but my place of work has the Netopia system and I...
Depending on the wireless security in work, you might have to go and enter those values manually, search for wireless networks with windows wireless manager, then down on left is addvanced options, double clikc on the wireless netowrk your trying to conect to in addvance options, and change the security settings for it and re enter its wep key.
Or just make sure you are entering the correct wep key. hope this helps
Dec 01, 2009 | Acer Aspire One PC Notebook
I have been trying to connect to the Belkin G (F5D7234) from my computer in a different room. It keeps telling me that the WEP key is incoprrect. I'm using the WPA2 code my mom gave me....do I need a...
To connect to your wireless router, it needs the router’s wireless settings configured and also needs the wireless cards in all the laptops and or computers to be configured with the router’s wireless settings. Then the laptops and desktop computers can communicate with your wireless router.
To set-up and secure the wireless router from unauthorized access, follow these steps: -
1. Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL IP address.
3. Enter the router setup, login and password
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WPA2 (if not then WPA).
7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router wirelessly.
Nov 26, 2009 | Belkin Wireless G Router
Wireless not working, went into setup and enabled
1. Please make sure its the router and not the laptop. can you get the laptop to scan for other networks . this is to make sure that the issue is with the router and not the laptop. 2. goto the setup again and try changing channels to 11 or 4.
Thanks
Ranjit
Oct 05, 2009 | Netopia (3347NWG-ENT) Router (3347NWGENT)
My internet connection will work when yellow cable is plugged in but wireless has stopped working on both laptops. The wireless connection isn't even showing up in the wireless connection window.Help!
your router may have been reset somehow and the wireless settings have been retired. goto: http://192.168.0.1 . and follow the setup wizards for wireless setup. This will repair the problem
Aug 27, 2009 | Netopia 2247NWG-VGx Wireless Router...
Getting PS3 NAT type 2 with Netopia router!
u should have dmz on router. but if not u can try your modem. that was my issue. i still use router for connection and stuff but i enables ip/dmz to pass through on my modem and it changed to type 2 more info email me at joshuaboo@aol.com on add me i believe my ps3 thing is ADV_WARfighter
Jun 10, 2009 | Netopia (3347NWG-VGX) Wireless Router...
Wireless Internet Connection Being Blocked
Do they have there security setup to match your netopia? If your not sure surf to the modems interface 192.168.1.254 go to expert mode and make sure the wireless settings match the settings (wep,wpa, 128 bit or 64 bit,open, shared key, etc..)on the laptop if not change them in the laptop
Nov 15, 2008 | Netopia (3347NWG-ENT) Router (3347NWGENT)
Computers & Internet Logo
David Payne
David Payne
