Question about Dryers
Loud noise when starting Is it the belt? - Dryers
  • Dryers Master
  • 43,501 Answers
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Posted on Apr 06, 2011
WHAT IS THE LIKELY CAUSED OF A LOUD SQUEALING NOISE COMING FROM THE ALTERNATOR SERPENTINE DRIVE BELT SYSTEM ? IS IT THE ALTERNATOR OR SERPENTINE BELT?
serpentine belt is getting old and hard and the cold weather was causing it to slip
check belt condition ( small cracks across the grooves = scrap and get a new one) and check tension
Jan 22, 2016 | Cars & Trucks
2008 Mitsubishi lancer radio from loud squealing noise
What is causing that irritating noise? ' DSMtuners
www.dsmtuners.com > ... > Articles: Miscellaneous
Jun 1, 2009 - 2 posts - ‎1 author Check the ECU power relay in the console, under the radio. ... You hear a loud clicking type noise from under the hood when you try to start the car. .... You hear a squealing, grinding, or rubbing noise in the lower timing belt .... The Mitsubishi Eclipse, Eagle Talon, Plymouth Laser, Mitsubishi Galant VR-4, ... LOUD squeak when turning steering wheel (Video Inside)
Mar 5, 2011
Why does my alternator belt squeal so much on initial ...
May 14, 2010
More results from www.dsmtuners.com
Lancer Troubleshooting [Archive] - evolutionm.net
www.evolutionm.net/forums/mitsubishi-evolution-forums/f-203.html
NEED RADIO HELP! ... Help not start Lancer GT 2012 EngineOverheating STOP SAFELY warning on ... AC ISSUES 2011 Mitsubishi Lancer ES · 2008 Lancer GTS no start please ... 2011 lancer no sound · Driver/Passenger side floor squeaky? ... plastic piece of rear shelf rattles a lot · Very loud noise on Lancer ES 2008 ...
Dec 03, 2015 | 2008 Mitsubishi Lancer GTS CVT Sedan
Try to start makes loud clunky noise but would not start
Sounds like either the timing belt snapped or you broke a con rod....check to see if the belts are still intact....
Feb 23, 2015 | 2004 Toyota Sequoia
I have a loud squealing noise upon starting the car. the squealing normally lasts about 30-45 seconds. sometimes the noise will appear aftrer pulling off from a stopped position, as well. all belts
Try to tighten the belts a little firm.Sounds like when engine idling no squelling only when about to take off .Some times belts may seem ok on the outside but if you look on inner side you tend to see cracks in the belts .
Jan 06, 2014 | 2000 Mazda 626
Vacuum sounds like an airplane after 1 year of use.
the motor bearings are starting to fail most likely. You can diagnose the source of the noise by removing the brushroll and belt, could possibly be the brushroll bearings but if you still get the noise when the belt is off its the motor.
Jan 07, 2010 | Bissell 6594 PowerForce Bagless Upright...
Just replaced Serptine Belt now car making loud
It's not uncommon for a new belt to require re-tightening soon after it's been replaced. Check the belt for any excessive slack (shouldn't have more than 1/2 -3/4" ). A loose belt would be one possible cause for the loud noise you describe.
Jul 15, 2009 | 2003 Cadillac CTS
91 buick regal 3.8L is making a loud clank noise in belt area
It sound to me like you have a bad belt tentioner check to see if it's real easy to move by hand if so change it problem solved .Hope this helps you out!!!
Jun 03, 2009 | 1991 Buick Regal
96 Nissan maxima -Loud Belt-like noise
try some belt dressing (spray in a can) you can get at any auto part supply,it worked for me
Jun 02, 2009 | 1996 Nissan Maxima
Truck making noise after replacing water pump, think i may have put belt back on wrong
I have a very loud squealing noise in my 2003 mazda mvp engine when i accelerate. We removed the belts which would eliminate belts as the problem. And that's that it. If anyone has any info please let me know.
Thank you
May 11, 2009 | Mazda B3000 Cars & Trucks
Primera 1990 P10 makes loud noise from belt when starting
i recently experienced the same issue. it can be your tensioner pulley or your water pump see the belts are connected to the pulleys and sometimes get worn out and need to be replaced. especially on a older car see a mecanic
Jan 31, 2009 | Nissan Pulsar Cars & Trucks
Dryers Logo
148 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
