We have a simpson espirit 550 and the water doesnt stop at selected water level.it fills up til it overflows
  • 42 Answers
Defective water level switch/sensor.
Posted on Apr 06, 2011
Hello, hope you can help, I have a eziset 550 simpson when I put the water on it starts filling but won't stop I have to listen & try to change settings so the water that won't stop running doesn't...
there is a small hose from the bottom of the tub to the water level switch
that gets air pressure to activate a switch when the level selected overcomes the switch spring
At that point the water solenoid is turned off and the wash cycle begins
over flowing indicates that the level sensor is not working or the inlet solenoid and diaphragm is faulty
if it doesn't progress the wash cycle , that indicates a program board problem so call the technician for a proper diagnosis
Sep 13, 2017 | Simpson Washing Machines
How do I remove the agitater from simpson washing machine espirit 550 5.5kg
most machines with verticle and turning agitators have a cap on the top which may be removed with a small ***** driver. that should give you access to dawgs and release nut. use a rubber hammer to gently tap and loosen if need be.
Apr 03, 2016 | Simpson Washing Machines
Hi, my simpson eziset 950 when filling with water doesn't stop filling when the cycle starts. Water overflows all through the washing cycle. When I turn the tap of it stops filling.
there is a small tube running from the bottom of the tub up to a pressure switch in the control panel that is set by what ever wash level you want
when the pressure in that tube exceeds the pressure set by the knob it does 2 things
it turns off the inlet water solenoid to stop water coming in and then starts the wash cycle
as it is starting the wash cycle , it indicates that the stop solenoid for the water inlet is either still getting power or the stop valve is faulty
try replacing that water control valve first
Jan 31, 2016 | Simpson Washing Machines
Simpson espirit 750 manual required can't change water level
Hello
Try these links to download the manual to your machine.
laundry.manualsonline.com/ex/product/.../m/simpson/d/.../22S750M
http://www.dataentryjobs.us/67948.html
trd-techconnect.net/User's%20guide,%20Instructions%20book
www.search-document.com/pdf/.../simpson-esprit-washingmachine
www.sign.ac.uk/pdf/sign97.pdf
Feb 09, 2012 | Simpson Esprit 750 Top Load 7.5kg
Cycle stops and the code FE appears and to refer to manual but I don't have one, can you help
IE: Water level (246) was not reached in 8 minutes
UE: Imbalance: Load too, small too large
OE: Drain problem took longer than 10 minutes to drain
FE: Overflow issue drain pump running to comp
PE: pressure sensor (sensor out)
dE: door error. open door. switch is out
LE (with a a slash in the
middle of L. Upside down F) Thermistor out
CE: Over amping Too much soap wrong soap
LE: hall sensor shorted/destroyed from sudslock
bE: Ball sensor loose connection/out of order
EE: eeprom out test mode only
PF: power failure momentary interuption of shocktricity
Must be some sediment in the water level pressure hose. Blow out the sediment, reconnect the hos, pump out the water and retry. This is an lg washer. You may only need to set or reset the water level frequency. I have service manuals and notes HERE
Apr 06, 2011 | Washing Machines
Simpson Espirit water not Filling
try removing your cold water hose and check to see if the screen filter has a calcium buildup or some other obstruction.  if not that then possible bas inlet valve on washer.
Aug 03, 2010 | Washing Machines
Washing Machines Logo
390 people viewed this question
Top Washing Machines Experts
