Question about Magic Chef CAV2000 Top Load Washer
Why is a substantial amount grease on the floor under the machine?
  • 42 Answers
Sounds like the transmission case is leaking. Not a simple problem to repair.
Posted on Apr 06, 2011
Substantial amount of water accumulating on floor behind driver's seat
No solution here but maybe an Idea. Could be A/C condenser drain is plugged or heater core is leaking. I'm guessing it's not rain leaking in?
Aug 07, 2012 | 2004 Toyota Camry
Front panel
i am sorry to say but that is true the machine will shake if on a wood floor if the duet is on a concert floor it does not shake as much
Apr 25, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Water under machine on the floor also some grease residue on the floor after we pulled it away from the wall. 17 year old Whirlpool washer.
Most likely cracked internal hoses that spatter when the unit runs. Easy to fix. The tub and other parts rarely crack if ever. They are molded hoses and easy to get replacements. If they ask too much you can get a substitute (non-molded) at auto parts stores.
Mar 14, 2010 | Whirlpool Washing Machines
Grease spot found on the floor from the right side
There is a bearing seal that does tend to leak. Feel free to ask any other questions. I do recommend copy and pasting this link in your internet address bar under a new tab for more great repair info:
http://home.howstuffworks.com/how-to-repair-a-washing-machine3.htm
Oct 13, 2009 | Maytag LAT3600A Top Load Washer
Intermittent water observed under machine
Difficult if not seen. Most common water on the floor senario is a drain pump leaking:or a perrished pipe from friction.or sometimes, water backs up from the house drainage system due to a restriction.
Sep 25, 2009 | GE WJSR2070B Top Load Washer
Water on floor; small amount to begin with..15 loads ago?, now lots of water (1+ gallon) and black grease on floor. slow spin, noisy and hard to get spinning.
if this machine is an older model, it may not be worth the effort to get it repaired. This sounds like the transmission and spin tube are on the way out, and there is some seeping around those seals. The transmission is probably leaking and will soon fail.
Aug 31, 2009 | Washing Machines
I have an oil leak on my clothes washer.
If you have a front loading washing machine the oil is really the grease for the bearings that support the drum. The grease seal needs to be replaced, and if you are replacing the seal you might as well do the bearings. This is not a cheap repair because of the amount of labor involved in tearing the machine apart to replace the seal and bearings. If you don't repair the seal, eventually the grease will be washed out of the bearings and the bearings will be destroyed. You can tell if you need new bearings because when the machine is on the fast spin cycle it will sound like a jet engine taking off.
May 24, 2009 | Washing Machines
Water is leaking into the drivers side floor when it rains
let's try something here and see if works,
get a garden water hose and put the most pressure near where you see leaking water and have someone inside the car look for it.
G
May 08, 2009 | 2002 Honda Accord
Magic Chef CAV2000 Top Load Washer Logo
Top Magic Chef Washing Machines Experts
Ian Jones
shaun taylor
Are you a Magic Chef Washing Machine Expert? Answer questions, earn points and help others
