Question about Zanussi Refrigerators
Zanussi ZNB343 Fridge/Freezer. After 9 months, this supposedly frost-free freezer wasn't! Called Zanussi, engineer came and said problem was with missing sealing of outlet pipe from freezer causing fan to work too hard. He put some puttylike substance on gap where outlet pipe comes out the back, said switch off for 48 hours and then problem will be solved. I haven't yet switched off for 48 hours as I need to run down the contents. Engineer suggested this is known fault that he has fixed several times. I remain unconvinced. Should I be concerned, as one year guarantee fast running out! Thanks Paul
SOURCE:
  • 237 Answers
SOURCE: Fridge not getting cold, fan tested and working but not being switched
The fan won't run if the unit is in a "defrost" cycle. It turns the fan and compressor off so the heater can defrost the coils. If the evap fan isn't running and the compressor isn't running then you may be stuck in a defrost cycle. See if you have a defrost timer that can be manually advanced (looks like a screw head that can only turn clockwise direction). It could be located in the frige section on the roof area. Usually a small hole mixed in with other screw holes that you will have to look up into and see the clock dial screw head. If you find that, manually turn the screw (it will click as notches go by) until you can hear the compressor and fan turn on. If that happens you likely have a bad defrost timer. If you have an "adaptive" defrost unit it will be a small circuit board that controls the defrost cycle and you will have to replace the board.
Posted on Nov 24, 2006
  • 210 Answers
SOURCE: LG LRFC22750 Bottom freezer french door refrigerator
6343ed3.jpg The problem is ice build up on the back wall. The noise you hear is the fan blades hitting the ice. On the back wall water gets trapped, it then builds up over time, and a big ball of ice forms and blocks the fan. Take off the back wall, defrost the build up and cut the insulation off as above. The water will no longer get trapped and the problem will not come back.
Sgt 48
Posted on May 31, 2008
SOURCE: ZANUSSI ELECTROLUX -- FRIDGE (TOP HALF) NOT WORKING?
9 times out of ten, when the freezer portion works, and the refrigerator portion doesn't, it is the evaporator fan that is the problem. I am not familiar with that model, so I do not know where the fan is located. But there is a fan that blows cold air from the freezer into the fridge portion. Usually, a fan blade is just stuck, and just needs to be repositioned or the bearing the motor spins on could be frozen or rusty. I little household oil usually does the trick, or you might need a new fan motor.
Another possible cause is the ice that can build up. If there is ice blocking the air's path it will have the same result. You said you had defrosted the unit, so this is not likely in your case
Posted on Dec 31, 2008
bobicehouse
  • 1524 Answers
SOURCE: zanussi frost free fridge freezer leaking water at back
Here is a link for your unit's manual: http://www.serviceforce.co.uk/pdfs/U30164.pdf
Posted on May 16, 2009
  • 146 Answers
SOURCE: Bosch Fridge Freezer: Fridge Not Cooling
Your refrigerator's cool is provided by your freezer section through a damper - there should not be excessive frost on the cooling coils - the most common problem is a defrost timer - are you absolutely sure the noise you hear is the defrost this is the first thing to check, defrost control and its components, is it properly shutting off or stuck on during operation - the next thing to check is for possible sealed system problems / small leaks, door gasket seals, etc.
The fact that it started to work once you manually defrosted is the key here - an over forsted evap will cause the problems you describe most commonly - so have your defrost system checked completly and properly - that should solve the problem. followed by checking door gaskets, damper and sealed system - if only part of the coils are frosted as opposed to the entire surface, that usually a clue to sealed system leak - yes 10C is quite warm for a refrigerator. It should be between 34F-40F, optimal is 34F. And freezer section no warmer than 10F, optimal at 0F (-18C)
Posted on Aug 24, 2009
I have Zanussi Frost free fridge freezer 3 years old. Bottom of freezer compartment below shelf is filling up with ice. The freezer appears very cold. The fridge seems less cold.
There is a timer which defrosts fridge daily . Put on manual . replace switch . check door closing , defrost , check defrost element .
Apr 08, 2014 | Refrigerators
Zanussi frost free fridge freezer we have had two zanussi fridge free freezers in the past month that do not drain away the water from the fridge. The water builds up under the vegetable drawers and...
this is a common fault with them, when packing them some of the packaging blocks the pipe. if you use a net curtain thing that hold up the net curtain push it down the hole up and down a few times then look at the drain away at the bottom of the fridge take the bits out. should be fine then. it happen alot and to deferent makes and models.
Sep 16, 2013 | Refrigerators
I have a zanussi frost free fridge freezer and the fridge is not cold but the freezers fine
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Sep 01, 2011 | Zanussi Refrigerators
Can i turn the freezer part of my fridge of so i can defrost the bottom part n leave the top part on , i have a zanussi electrolux
no your model is a single compressor which runs both frdge and freezer.. freezer is supposed to be frost free however freezing elements can be overwhelmed with frost if door has been left open. there is a drain hole behind the back panel of the freezer that can block or freeze up causing water to flow in tp the freezer and turn to ice. complete defrost and check that drain hole is clear to fix it.
Jul 24, 2010 | Zanussi ZEBF250W Bottom Freezer...
Zanussi frost free fridge freezer leaking water at back
May 15, 2009 | Refrigerators
Fridge making a purring sound then stopped working
Yes, I think you have a problem that can be fixed easily by a repair technician. The sound as you described it could have come from the air circulation fan in the freezer compartment striking ice. As the ice builds up it could have stopped the fan from rotating and air flow to the refrigerator compartment.
Nov 27, 2008 | Zanussi Freezers
I have a zanussi fridge freezer combination, it is a frost free model, Im developing lots of frost in the freezer which never used to happen and the fridge is not getting cold, some condensation does...
Hello Mr Barnard
Welcome to fixya
You said, You have a zanussi fridge freezer combination, it is a frost free model, And you're developing lots of frost in the freezer which never used to happen and the fridge is not getting cold, some condensation does appear inside the fridge, it is 2years old.
Frost could mean a few things.
Is the freezer cold but the fridge not?
If so the freezer may be so full that the articles are covering the air vents in the back that share the cold air with the fridge.
I've have seen the freezers packed to the hilt!
More things to check.
Is the condenser in the back or under the front of the fridge. If it is under the front of the fridge you must remove the plastic grill`(The condenser is the thin black metal tubing that runs back and forth to make up your condenser). This needs to be free of dust and have air passing over and through it!
they sell refrigerator brushes for this at the hardware store.
I have had customers that never ran the brush under there ever and had 1 to 2 inches of dust and lint
under there between the tubes.After a few hours it was cool the next day it was cold!
The freon level pressure should be checked in case you have a leak.
The thermostat may be bad.
Let me know what works for you.
Huuum
Please remember to leave a rating!
Oct 05, 2008 | Refrigerators
Brand new refrigerator not cooling
ok what he was trying to say is that the freezer does all the cooling for both sides as nothing in the fride side cools and in order for the fridge to reach its proper temp the freezer should run any where between -0 to-10 then the fan in the freezer draw-es air from the fridge and cools it and circulates to the fridge now i need to know a few things is the compressor running is the freezer fan running do you see any frost on the back wall of the freezer section is the fan running in the back that's near the compressor to cool the condenser coils then i can better advise pleas hold my rating till we are done where did you purchase the unit
Jul 22, 2008 | LG LRTBC1825T Top Freezer Refrigerator
Refrigerators Logo
67 people viewed this question
Top Zanussi Refrigerators Experts
Felizardo Erilla
Felizardo Erilla
Colin Stickland
Colin Stickland
tony denham
Level 1 Expert
Are you a Zanussi Refrigerator Expert? Answer questions, earn points and help others
