Question about Memorex Ultra Traveldrive - 160GB USB Hard Drive
I have a Memorex Ultra Drive connected via USB to a Windows XP machine. It shows up in My Computer as a folder but then disappears again. It does this repeatedly. The drive is formated as a FAT32. How can I keep it alive? I have looked for drivers online but I think it is actually a plug and play device. I can hear the drive spin when it comes on. But clicks off when it stops. It does this on-off sequence in 5 second intervals.
    Sergeant:
  • 236 Answers
As you have described that your Memorex Ultra Traveldrive re-appears repeatedly, indicates that the communication between your computer and your external hard drive is intermittent. The FAT32 format does not produce these types of issues. What we can do first is identify what causes the problem.
Assuming that the hard drive in your Memorex Ultra Traveldrive is in good shape:
Troubleshooting Method #1. Try connecting your Memorex Ultra Traveldrive into another USB port. If the problem persists, use another USB cable for your external hard drive. If the problem still persists, you will have to replace the external casing of your external hard drive. If your external hard drive works with the other USB port perfectly, most likely, the USB port where you originally plug into of your Windows XP machine needs to be checked. That USB port might need some repairing.
Troubleshooting Method #2. Try connecting the external hard drive into another computer and perform the same troubleshooting as Method #1. If your external hard drive works with other computers perfectly, most likely, the USB port where you originally plug into of your Windows XP machine needs to be checked. The USB port might need some repairing.
If the problem only occurs with your Windows XP machine, assuming all USB ports are in good shape, your Windows XP needs to be checked for some software issues.
I hope this works for you. Kindly reply/comment for further assistance. Good Luck!
Thanks for using Fixya!
Mongkey
DELL Tech ID #456563
TIPS: Is your computer slow? This might help
http://www.fixya.com/support/r8158906-diy_manual_pc_tune_up
(for Windows only)
Posted on Apr 06, 2011
Unable to access my folders and files from WG passport ultra external drive. How to fix it?
Try connecting to a different USB port and restarting computer.back USB ports are better than front ones as they connect directly to motherboard.do not panic but if this still locks out then you must connect to another computer or laptop as first stage.usually these happen when someone switches off the main machine whilst it is still writing to the external drive which can corrupt a file and cause unread ability.one you have access run a quickscan to fix files and folders on the external drive.get back to me if none of the above fixes this problem and I will point you towards some some ware to correct further likely problems.
Mar 02, 2015 | Ultra Computers & Internet
Transferring files via external hard drive to new computer
You just need to connect the external hard drive to the new computer. Once it has connected and Windows recognizes the drive it should pop-up with the window asking what you would like to do (select the option to View Files). Also at this time open the folder on the new computer that you want to store the back-up files in. Make the external hard drive folder and the new computer folder sit side-by-side. Then while holding down the CTRL button on the keyboard click each file you want to move. When you are done selecting them - right click on any of the file selected and on the pop-up menu select "copy". Now go to the folder on the external drive and right click the mouse again and from the pop-up menu select "paste". This will just copy the file, that way you can keep the files on 2 different hard drives in case something happen to 1 of them.
Austin
We-Supply.com
Jul 22, 2013 | Memorex Ultra Traveldrive - 160GB USB Hard...
My computer has stopped recognizing my drive
Hi Take a look HERE first as it covers most common issues.
If you still have issues write back here and lets see what else we can do to get you going.
Bob
EXMOD
It would be very decent of you to consider the quality of our expert’s answers and judge them accordingly as you pass through FixYa.
Mar 08, 2010 | Memorex Ultra Traveldrive - 80GB 80 GB...
I have a brand new 1 gb memorex travel drive that I'm suppoed to go to memorex.com to download the drivers. It's not available onlnioe anymore and memorex is tying to send it to me via email but the file...
Windows XP and Windows Vista and Windows 7 should have "built-in" support for this Memorex device. Just connect it to a USB-port, and see if it is recognized -- it should be!
Nov 09, 2009 | Computers & Internet
Is there driver/ software for Win ME for the Sansa Clip mp3?
a friend told me that if the device shows as"connected" when hooked up (it does) AND the battery charges correctly (it does), then (a)the USB connection had enough juice; and (b) the PC recognizes it - i just had to FIND it. device manager/ MyComputer: nada; same for ANY file/ folder with "sansa" or "sandisk." working thru WMP (Windows Media Player), however, I discovered that drive E - for a portable hard drive, NOT currently connected via USB - was STILL showing up in the "Copy to CD or device" field. sure enough, it was the SanDisk clip player (even though it was NOT under the "Recognized Portable Devices" subsection). without using the installation disk at all, it downloaded tunes just fine. *note: the installation disk seemed to be an .exe file ONLY for the Rhapsody music service. as noted above, it was unnecessary. also - my USB ports are 1.1 and not 2.0, and package stated USB 2.0 was a "minimum requirement" - not true*
Jun 17, 2009 | SanDisk Sansa Clip MP3 Player
Some pc's don't recognize my travel drive
I have a USB hard drive, and I have noticed that on some systems the current Draw on the USB port is too high for systems with unpowered / Low power USB ports, and therefore it doesn't work for that system,
this issue can be bypassed by using a "powered" USB hub
Mar 24, 2009 | Memorex Ultra Traveldrive - 160GB USB Hard...
Detected With Error Code 10 in Device Manager in Windows XP
Have you tried also plugging in the DC usb cable into the traveldrive? I was having problems where my computer wasn't working properly with my drive unless I had it either plugged into a powered usb drive/hub or I had the DC plug in as well.
Jun 04, 2008 | Memorex Ultra Traveldrive - 80GB 80 GB...
Nexstar IDE to USB, Will Not Show Up
Hello
Have a look at the link below, it should be of help.
Click HERE to navigate.
Please feel free to let me know of you have any further questions.
Kind regards
Lock123
Apr 06, 2008 | Vantec 1 Bay NexStar 3 USB 2.0 External...
Won't show files
I can't get Windows Media to recognize the device.
Mar 09, 2008 | Memorex MMP8565 MP3 Player
Memorex Ultra Traveldrive - 160GB USB Hard Drive Logo
289 people viewed this question
Top Memorex Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Piyal Perera
Piyal Perera
Jax Planet
Jax Planet
Are you a Memorex Computer and Internet Expert? Answer questions, earn points and help others
