Question about Frigidaire Washing Machines
Frigidaire Gallery Front Load Washer Motor not working. The timer cycles, water flows in and drains, door locks and unlocks, etc, but the motor never moves. I can hear clicking (relays?) by the control knob as if everything is working ok... Is it definitely a bad motor?
  • triggle Apr 07, 2011
    Is it possible to check the motor itself without power? perhaps resistance or continuity or something (assuming it has been removed already) Otherwise I can re-install to test. The connection to the motor is a 20 or so wire coupling going into a small control box. Two of the wires have voltage all the time. difficult to test the rest when the motor is installed.
  • Frigidaire Master
  • 43,501 Answers
The best way to check is to use an electrical meter and check for power going to the motor....if you have power and the motor does not run then the motor is bad...
It is also very possible that the motor is not getting power and that a relay is bad...that could be much more difficult to track down...
heatman101
Posted on Apr 06, 2011
  • Frigidaire Master
  • 1,902 Answers
Hello & Welcome to FixYa
The motor needs replacement and testing it won't help, but if you want you can test it for 120vac while its unplugged. Please get back to me if you have any other questions.
Kevin
Posted on Apr 07, 2011
I have a Frigidaire FTF530FS washer with a problem. The Timer gets stuck in between the drain and the spin cycle. It occurs when the timer dial is about 3 o'clock. I replaced the drain pump, the door...
Good Morning kvojik, thanks for your post!
From my understanding your Frigidaire front load washer is getting stuck between the drain and spin cycle. I noticed that you have replaced many components within your washer and continue to experience this issue. I would not advise to manually advance any part of the washer because this could cause issues within your washer. It could be a potential issue with the motor. At this point you may want to reach out to a technician for proper diagnosis and repair. This will help you to avoid any further part purchases. -Matt
Feb 21, 2015 | Frigidaire FTF530FS Front Load Washer
I have a Frigidaire FTF530ES1 front load washer that doesn't spin or agitate. The door lock light comes on and I don't think it is that. It fills with water, then you can hear the clicks for each cycl
Good Morning Vickie,
I understand that your Frigidaire washer, model# FTF530ES1, will not spin or agitate. I also see that the door lock light came on so you checked the door latch, due to it not unlocking right away. Now, you have removed the back panel and restarted the cycle, to find out that the motor is not coming on. There is a possibility that it could be the motor, or it could be something completely different that is causing your washer to not spin or agitate. I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your washer and determine why it is not spinning. I hope this is helpful.
-Best Regards-
WP
Jun 16, 2014 | Frigidaire GLTF2940ES Front Load Washer
Front load frigidaire washer wont do anything but fill with water and drain and the door wont lock
Hello Cheryl Watson - Not quite sure I understand the issue. If the unit is filling with water and draining immediately, with no tub rotation or movement, more than likely there is a failure with the motor circuit (i.e. the motor, motor control board, belt, wiring or door switch). Consult a professional for an accurate diagnosis and to assist with the repairs.
Feb 04, 2013 | Frigidaire ATF6000ES Front Load Washer
Frigidaire Gallery Series # GLTF 2940FS The washer stopped running in mid rinse cycle. When I try to start it a clicking sound occurs.
You will need to check the drain pump and make sure there is nothing obstructing or restricting the flow of water.Once you know that is clear and the problem returns then you might have to change the main control board and possible the door lock.Also make sure to check the motor and all the wiring the motor.
Dec 22, 2010 | Frigidaire GLTF2940ES Front Load Washer
Door will not close
Make sure you are allowing the washer to completely finish its cycle before opening the door. It is normal for the door to lock at the end of a cycle. The locking mechanism keeps owners from opening the door before all of the water has been drained. If the door on the washer is locked, select the "Drain" or "Spin" options on the front-load washer. This will completely drain the water from the system and unlock the door, allowing you to open it.
Thank you !!
Jul 09, 2010 | Frigidaire ATF6000ES Front Load Washer
Can't get the door open
Thank you !!
Jul 06, 2010 | Frigidaire ATF6000ES Front Load Washer
Door lock light is on door is not locked and
Thank you !!
Jun 19, 2010 | Frigidaire GLTF1040A Front Load Washer
Frigidaire affinity door will not lock when door is closed or register door is not closed when open
Apr 21, 2010 | Frigidaire ATF6700F Front Load Washer
Washing Machines Logo
133 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
