Question about Technics SL-1210 Turntable
I've got to be honest...(in response to your question)
..I've never cleaned the pitch controls before...What is recommended? I work at a radio station and our engineers seem up to the task of helping me clean/replace the pitches...do u think i should stick with a 1200 pro though? I mean, these are well-rounded and knowledgeable engineers, just without technic-specific experience. How often and how (process) need they be cleaned?
  • 515 Answers
The need to be cleaned as much as you play them. If you play them on a daily basis, I would suggest cleaning the pitch faders at least once a month. Also, the studio environment is also a factor. Is it a dusty place, or relatively clean?
You can clean the faders out with an air can, and some Deoxit or other contact cleaner. DO NOT USE RUBBING ALCOHOL.
There are 2 was to clean, blow the air can inside the fader, removing any debris, then spraying your contact cleaner, then spray air again.
Or, you can take the turntable apart, take the pitch control apart, and clean the contact fader inside. Desoldering is required for this. But it's a more thorough cleaning.
Helpful tips can be found here: www.djproaudio.com/Help
Or, you can just buy a new fader, and install <-- easiest method!
- OPTiC
DJ Pro Audio
www.1200s.com
www.repairnyc.com
Posted on Aug 08, 2008
NO AM STATIONS IN MY 1998 JEEP GRAND CHEROKEE, BUT NO PROBLEMS WITH FM. DO I Have to change or repair the radio or the antenna?
A.m. radio stations have a very limited range and honestly modern units include am reception as an after thought. Unless you are within a few miles of the station you probably won't pick it up. That being said if you are close enough and still cannot pick it up then the radio is probably faulty.
Oct 29, 2016 | Jeep Cars & Trucks
Radio has constant high pitcs sound when you hit weather button
This is common on some WR100 models. This means ur speaker is blown, and it wont work anymore. Try buying the new WR120, it has a more stable speaker.
Dec 29, 2015 | Midland WR-100 Weather/RDS Radio
The radio buttons on 09 altima are not responding when u try to change to a new radio station and to cd or radio plus when u put the cd in u can't skip to the next song
First impression is you radio is toast. It maybe some component gone bad on a circuit panel inside the radio. Before you consign it to the deep try "rebooting" it. Most electronically controlled radios have some king of logic and memory boards in them ...so treat your radio like your computer when it starts misbehaving. To reboot the radio disconnect the battery (remove the black/negative lead first then the positive/red lead from the battery), put the key in the ignition and try to start the car (it won't of course but this is to discharge any holding capacitors) and turn on the radio ...again to discharge any holding capacitors. Turn everything off and let it sit overnight if you can. Reconnect the battery. The radio should have lost all saved information (time, stations, EQ settings etc) and may now be responsive to button inputs. If this doesn't work then I'd say the radio is a goner.
May 01, 2014 | Cars & Trucks
My remote radio station tuner button does not work. How do I tune the radio?
Clean the control with electric contact spray, and check the wire connectors inside the fake tank.they need to be clean to allow the signal from tunner control to the radio(just do them all).Also use the key to remove the radio and clean the contacts in there too.Dont clean the connectors with the battery hooked up!Try to tune it after all of this.
May 06, 2010 | 1985 Honda GL 1200 Interstate Gold Wing
Radio and clock will not work. The fuses are good i think.
Check fuses first. please rate as fixed if this solves you rissue. report back results.
VISUAL INSPECTION CHART
Mechanical Electrical
  • Integrated control panel with or without tape player physically damaged, misaligned, any controls inoperative.
  • Digital audio compact disc player physically damaged, misaligned, any controls inoperative.
  • Radio antenna lead in cable, electric antenna or bodyphysically damaged or misaligned connections.
  • Radio speaker mounting/speaker cones physically damaged, misaligned.
  • Radio ignition interference capacitor or radio frequency interference suppression bond misaligned, unclean and no metal-to-metal contact.
  • Mobile telephone transceiver; mobile telephone handset, mobile telephone microphone, mobile telephone transceiver holder cradle physically damaged, misaligned.
  • Open fuses: fuse junction panel fuses 8 (5A), 12 (5A), 20 (5A), 22 (5A), 24 (5A) or power distribution box fuse 17 (20A).
  • Open connectors.
  • Corroded connectors.
Section 15-00: Audio Systems—Service 1999 Taurus, Sable Workshop Manual DIAGNOSIS AND TESTING Inspection and Verification NOTE: Many customers do not understand the limitations of FM reception. Refer the customer to the Owner Guide for information about the limitations of FM radio performance.
Internal diagnostic examination of the integrated control panel, rear chassis unit and audio compact disc player should be left to the authorized radio service center. However, the automotive technician should be able to analyze and isolate radio reception conditions to the proper area or component causing the condition. All radio conditions can be isolated to one of six general areas:
  • antenna system
  • integrated control unit
  • radio speaker system
  • radio noise suppression equipment
  • rear chassis unit
  • audio communications protocol network
Retrieving Diagnostic Trouble Codes (DTCs)
Using Audio System On-Board Diagnostics
The audio system has on-board diagnostic capabilities and is equipped to check for every component available in the system even if this specific vehicle is not equipped with all components. A Diagnostic Trouble Code (DTC) will be set for the missing components. These DTCs can be ignored if the vehicle is not equipped with these components. The battery must be fully charged for proper audio system operation. The ignition switch must be in the RUN or ACC position. Turn the system on, tune in a strong AM station and verify good reception. After an AM station is checked, tune in a strong FM station. The system is now ready to enter the diagnostic mode. Diagnostic Mode:
NOTE: Battery must be fully charged for proper audio system operation and self-test.
Enter Diagnostics mode by pressing SEEK DOWN button first and then pre-set button 3. Hold both buttons for five seconds. This will suspend all normal radio functions, retain the previously selected frequency and display DIAG.
  1. NOTE: To perform diagnostics, press the appropriate buttons as instructed.
    SYSTEM CONFIGURATION SELF-TEST:
    Press pre-set button 1. This will check for connection of all possible devices and log the diagnostic trouble codes for any device that does not respond. The display will flash SELF while gathering the diagnostic trouble codes, then stop flashing when complete. To exit System Configuration Self-test, press pre-set button 1 again. To retrieve diagnostic trouble codes, press the TUNE UP button. This will display the diagnostic trouble codes if any exist. Continued pressing of the TUNE UP button will display the next diagnostic trouble code. Record codes and refer to the following table. To exit the Retrieval Mode, press pre-set button 1.
    CONFIGURATION SELF-TEST CODES Code Description 0 No diagnostic trouble codes logged 1 No response from rear chassis unit 2 No response from tape deck 3 No response from bezel microprocessor 4 No response from compact disc player 5 No response from steering wheel controls 6 No response from rear seat control 7 No response from remote climate control 8 No response from navigation module 9 Read Only Memory verification failed
    Remember, system configuration will test for all possible equipment connections. Inspect the vehicle to determine actual equipment installed.
  1. Integrated control panel display test:
    To enter the integrated control panel display test, press pre-set button 5. This check will light all segments in the integrated control panel. The system will automatically exit this test after five seconds.
  1. Integrated control panel and rear chassis unit identification:
    To enter this test, press pre-set button 3. This test identifies the software level of the integrated control panel and rear chassis unit. The integrated control panel is tested first, followed by the rear chassis unit. The completed test will exit automatically. For code identification, refer to the following table. The display will have two sequences of five codes each. The first sequence is for the integrated control panel, the second sequence is for the rear chassis unit.
    Item Part Number Description 1 — Product Type Code 2 — Product Variant Code 3 — Software Version Level 4 — Software Version Release 5 — Software Version Patch
Apr 23, 2009 | 1999 Ford Taurus
Cobra 148 GTL steady tone though speaker
try rerouting your coax cable and make sure it's long enough
Jul 07, 2008 | Cobra 148 GTL 120-Channels Base CB Radio
PITCH CONTROL PROBLEM
The reset button disables your pitch control and allows the turntable to rotate at TRUE "0" (zero). FYI, these turntables were NOT made for DJing. They were made for radio, studio, and high end home use. They became DJ turntables, because they were perfectly built for the trade. So, the pitch reset button is more of a function best suited for radio stations or a producer who needs to record or play at a true zero speed.
Now, on to your question...
More than likely you just have to calibrate your pitch control. There are various videos on YouTube on how to do this properly. Just do a search CALIBRATING 1200s or similar. FYI, all the Technics SL1200/1210 MK series are the same inside. MK2, MK3, MK5 - so don't worry if you only find videos on calibrating MK2's or MK5s - works the same on all the models.
- TERMiNAL OPTiC
www.DJPROLAB.com
Apr 01, 2008 | Technics SL-1200M3D Turntable
Technics SL-1210 Turntable Logo
256 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
