Hi sire i just want to ask u about my advent netbook 4490 the sound sometime not good i wonder whats wrong with it ?
  • 27,725 Answers
If you are having problems with your sound
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Posted on Apr 06, 2011
What is the red light on an advent 4213
probably wrong adapter, change with another one if you have any , or use universal ones
Feb 20, 2013 | Advent Netbook
How to change cpu in advent 4490
are you going to change same cpu model type? if yes then it will work. if you are not going to install same type of cpu then you have to consult a computer technician cos it might not work.
Sep 20, 2012 | Advent Netbook
I bought a new battery for my advent 4490 net book .the battery worked fine on the initial charged tht it already had but now whn the battery is now left with the 9% charge in it , i plug in my charger and...
I I have the same issue and i took my netbook to more than 4 electronic engineers, all of them said that doesnt seem there is a problem in my netbook though.
Mar 31, 2011 | Advent Netbook
Where is the wireless key for an advent netbook, i,m trying to go wireless and unable to find it
Hi
There are several different models
so you could try this
press the blue FN bottom left the same time as the top F2 above the no 2 key
or sometimes its on the front of the laptop and sometimes its next to the power switch
hope you find it
please let us know if you do
Feb 01, 2011 | Advent Netbook
My Advent netbook keeps asking me to reboot it. How do I do that?
For rebooting your netbook. Click start and then shutdown and then restart. This will reboot your netbook. If it doesn't shuts down press and hold the power key for 5 seconds or more and it will be turned off.
May 23, 2010 | Advent Netbook
I have an Advent 4490 Netbook (Windows XP). The internal webcam has stopped working. I select Fn-F12 and a message says the webcam is switched on, but it is not working. No light either next to webcam. Can...
Hi! try to check if the driver for the webcam is installed on the machine, go to start->right click on my computer->properties->hardware->device manager. Check if the driver is there, uninstall and reinstall the driver by following the steps below:
Drivers
1.Click Start > My Computer.
2.Double-click the icon for XP (C:) drive.
3.You may see a message saying "These files are hidden". Click the Show the contents of this folder option.
4.Double-click the Applications folder.
5.Double-click the Drivers folder.
6.Inside this folder you will see folders for each device you can re-install, for example, Audio.
7.Double-click the folder and look for an icon called Setup.exe or Install.exe.
8.Double-click the icon and follow any on-screen instructions to re-install the driver.
9.After installing drivers it is recommended that you restart your computer.
***you have to run a program or a software (yahoo messenger, etc) for you to test if the webcam if it is working or not***
hope this helps...
May 22, 2010 | Computers & Internet
How to I get new of lcd screen for netbook advent 4214
Hi , I don't know if you are in the UK but I have just found this on EBAY.COM - Link.
http://cgi.ebay.com/NEW-10-LCD-WSVGA-LCD-SCREEN-FOR-ADVENT-4211C_W0QQitemZ280384449499QQcmdZViewItemQQptZUK_Computing_LaptopAccess_RL?hash=item4148372bdb
I hope this is ok , and I have help you.
If you need more help, please ask.
Regards Anthony
Feb 01, 2010 | Advent 4211c Notebook
Can't use built in webcam - Advent 6651
hi
read you problem.
to fix this up you have to follow few steps.
1.check if the driver for this is installed.it is there in system properties.
2.if it is installed try reinstalling the driver as it may not be installed properly.
3. if even after these things it dont work then check the webcame settings .
thnx
Jul 01, 2009 | Advent Netbook
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
