Question about Samsung DVD-HR720 DVD Recorder
MY DVD-HR720 HAVE NO POWER SUPPLY, CAN YOU PROVIDE ME THE POWER SUPPLY DIAGRAM.....
OSD IS BLINKING
bad micro probably. could be power supply,might be better to replace
http://www.shopjimmy.com/
Sep 06, 2012 | Samsung DVD-HR720 DVD Recorder
Tip
Recommended blank discs to use
Please can someone recommend a "DVD-R" and "DVD-RW" to use with the DVD-HR720 DVD Recorder. Please can you also list where to source the particular discs. Thanks.
on May 25, 2008 | Samsung DVD-HR720 DVD Recorder
How do you record a TV show every week without
You should have some kind of series link ICON that you can press so it remembers
Jan 12, 2010 | Samsung DVD-HR720 DVD Recorder
Faulty power supply board
I have exactly the same problem. Indeed the power supply was defect. I have repaired it. Now the display is working but it is still not working : It displays LOADING... and that's all. Probably the controller card (the one with the LSI LOGIC chip) is also defect. It is impossible to repair, it has to be replaced.
I think this recorder is not 'CE'.
Sep 25, 2008 | Samsung DVD-HR720 DVD Recorder
Power supply down
my samsung dvd-v1000-vcr do not turn on
Jul 29, 2008 | Samsung DVD-HR720 DVD Recorder
NO VIDEO OUTPUT ONLY SOUND
I tried searching but am unable to find one.
Apr 02, 2008 | Samsung DVD-HR720 DVD Recorder
DVD-HR720 DVD
double check connections match on both ends tv and dvd also check the input on the tv sure you video cable is on the same one you audio cable is on.
Mar 16, 2008 | Samsung DVD-HR720 DVD Recorder
No cyrilic subs in divx
no lead hd..solo lead constanst......... failed firmware hd..dvd-hr720 samsung..
Dec 20, 2006 | Samsung DVD-HR720 DVD Recorder
Dvd file system
The first is rather easy. You will have to finish the DVD to get it working. After copying a title, finish the DVD and put in you computer's DVD player. Either the film should start to play or you will be prompted whether you want to show the contents or other options. If either of this happens, you are good to go and you can copy the Video_TS folder which should be visible to your hard drive. Done it several times.
The second solution is something I try to figure out myself but it seems DV in is really IN and not OUT....
Best,
Marty
Oct 16, 2006 | Samsung DVD-HR720 DVD Recorder
Samsung DVD-HR720 DVD Recorder Logo
59 people viewed this question
Jerry Greenberg
Jerry Greenberg
