Question about Garmin StreetPilot c530 GPS Receiver
Garmin nuvi 350
Forgot pin numbers
  • Anonymous Apr 25, 2009
    i don't remember my pin number i been trying on the web site and i don't have the solution please help me
  • 59 Answers
Return it to owner. Or else go to the owners secret location where the GPS will unlock itself.
Posted on Sep 04, 2009
    Brigadier General:
  • 4,090 Answers
Some GPS manufacturers provide a feature, which allows the GPS owner to assign a unlock access code or PIN to their GPS.
The PIN is designed to prevent your GPS from being used by an un-authorized user. It was also meant to be used a a deterrent to thieves, making the GPS useless if stolen.
When you set up the PIN, you will be asked to enter in a code. After you enter the last digit, you will be asked again for the code. This is to make sure that both entries match and verifies that the PIN that you requested will be the one written into memory.
Your PIN is written into non-volatile memory..... it's not a file that is accessible via USB communications between the GPS and a PC. You can't clear it by disconnecting the power or disconnecting the battery or letting the battery run down. There is no jumper or switch inside the GPS to reset it, so don't waste your time tearing your GPS apart in an attempt to clear it.
Now, after you set the PIN, you will be asked to set the "secure" location. This can be anywhere.... your work location, home, local gas station, school, etc. In order to set the secure location, your antenna must be up and you have to have a satellite lock. If you don't have a lock, the "set" key will be grayed out until you acquire a lock.
The secure location is your "back-up key" in case you forget your PIN. If you have forget your pin, all you have to do is physically go to the secure location. Make sure your antenna is up and that you have a satellite lock. When you are in the secure location, your GPS will NOT ask you for the PIN when you turn it on. You'll then be able to reach the main menu and change the PIN and secure location to something else if you desire.
If you have forgotten both the PIN and secure location, you are out of luck. You'll have to send your unit back to the manufacturer to have it unlocked. The manufacturer may charge you for this service.
Note: If you do send the unit back to the manufacturer to be unlocked and you are found not to be the original & rightful owner of the GPS and it's determined to be stolen, the manufacturer may contact law enforcement (they're policy on this is right on their website under FAQ's).
Posted on Aug 16, 2009
SOURCE:
SOURCE: My Garmin nuvi 350, North America, will not show picture.
don't know I to use the garmin 350
Posted on May 05, 2008
  • 16 Answers
SOURCE: garmin nuvi 250 forgot pin number, what do I do
It has to go back to garmin, the pin is written to non volatile memory, so a power interruption wont erase it. Garmin will reset it, if you are not the original owner and it is reported stolen Garmin will notify the police.
Basically the memory has to be flashed by garmin, sorry it is not what you want to hear, but don't dammage your gps trying to reset it by opening it up, that only voids the warranty and will cost you more money.
Posted on Aug 11, 2009
  • 23 Answers
SOURCE: i forgot the pin number to my garmin gps and garmin wont give it
You can call the guy you purchased your Garmin univ 205 from and unlock the PIN and change it from the location he set the PIN at.
Good Luck
Posted on Apr 03, 2010
SOURCE: I forgot pin # for my garmin nuvi 265W (MAPS of
new pin code
Posted on Aug 07, 2010
  • 1514 Answers
SOURCE: My Garmin Nuvi 780 is
It may be possible to clear the pin or may not be. You can find details of how to clear it, when it's possible, at http://www.fixya.com/support/r6240807-remove_forgotten_pin_from_garmin_nuvi
Posted on May 29, 2011
Forgot password cant get it unlocked need to do a master reset
if you forgot your pin number you must return to the SECURITY LOCATION...... the security location is where you first set up your gps....( your home or office ) then the unit will automatically unlock for you, remember to reset your pin number when unlocked..
Other than that you would have to send your unit back to Garmin with the proper receipt of ownership.
Nov 09, 2010 | Garmin Nuvi 350 Car GPS Receiver
How to unlock gurmin
this is the tips for you to unlock
follow this instruction:
  • Step 1 Lock the screen by touching the "Lock" button. To unlock the screen, press the "Power" button.
  • Step 2 Lock the device by pressing the wrench icon, then "System" and "Garmin Lock."
  • Step 3 Press "OK." Then enter a four-digit PIN when prompted. Select "OK."
  • Step 4 Drive to a security location then press the "Set" button. Now each time you turn on the Nuvi, it will ask for the PIN. Enter it when prompted or drive to your security location.
  • Step 5 Send the Nuvi to Garmin to get it unlocked if you forgot both the PIN and the security location.
  • Jun 23, 2010 | Garmin Nuvi 350 Car GPS Receiver
    I forgot the pin number to my garmin gps and garmin wont give it
    Good Luck
    Apr 03, 2010 | Garmin nuvi 205W GPS Receiver
    Okay when i went to turn on my Garmin nuvi 260 it ask me for a pin or password and i forgot it. Then it says to go to your safe location and i dont remember if i set one of those. So how do i unlock it?
    Your safe location is where you entered the PIN number (probably your driveway). If it still won't unlock, send it to Garmin with your original receipt from an authorized Garmin dealer and they will reset it for you. There is no master unlock for the Garmin units, it must be reset by Garmin.
    Oct 12, 2009 | Garmin nuvi 350 GPS Receiver
    I forget my pin number and i can't open the screen
    Go to your secure location (safe zone),
    the pin will not be on it then.
    or if you didn't set it or don't know it,
    Garmin Repair's only.
    Regards.
    Jun 26, 2009 | Garmin Nuvi 350 Car GPS Receiver
    I do not remember my code to unlock garmin nuvi
    You have to take your unit back to your Safe Location where you set your PIN number (usually your home). Otherwise, you'll have to send it to Garmin with the receipt to have it reset.
    Jun 18, 2009 | Garmin nuvi 250W GPS Receiver
    Forgot my pin no.
    Resetting the unit does NOT reset the PIN. Even a Master Reset will not reset the PIN. You have three options for unlocking a PIN locked Garmin:
    1 - Enter the correct PIN
    2 - Take the unit to the location at which the PIN was entered
    3 - Send the unit back to Garmin
    Apr 30, 2009 | Garmin Nuvi 350 Car GPS Receiver
    Garmin nuvi 350
    Take the unit back to the "Security Location" you set and it will automatically unlocked. You can then change the PIN number.
    Jan 02, 2009 | Garmin Nuvi 350 Car GPS Receiver
    I forget my pin for my gps garmin nuvi 350 please canhelp?
    HI
    AS LONG AS YOU CAN PROVE OWNERSHIP OF YOUR NUVI WE CAN ASSIST YOU WITH THIS PROBLEM
    Hi. Please look us up on EBAY.CO.UK
    MGA-TRADING
    We offer the best value and quickest repair service around for the Garmin Nuvi
    Unlocking the PIN on the 300 series Nuvis is usually straight forward and the unit can be turned around in a few days!
    Regards
    MGA-TRADING
    Dec 10, 2008 | Garmin Nuvi 350 Car GPS Receiver
    Did you find a way to unlock the garmin?
    The only way to unlock a PIN locked Garmin is to enter the correct PIN number or take the unit to the location at which the PIN was set. Your only other option is to return the unit to Garmin.
    May 07, 2008 | Garmin nuvi 350 GPS Receiver
    Garmin StreetPilot c530 GPS Receiver Logo
    171 people viewed this question
    Top Garmin GPS Experts
    Marvin
    Marvin
    Jean-Luc Steffann
    Sheldon Dedek
    Are you a Garmin GPS Expert? Answer questions, earn points and help others
