Question about Samsung HP-R4262 42 in. Plasma Television
Samsung 4254 Plasma keeps shutting itself off and then clicks like it is trying to turn itself back on. Sometimes it does turn back on and then shuts off again and keeps doing this over and over. The TV is 3 years old.
Take the back off the tv follow the power cord it will connect to an electrical board. Look at the board carefully you will find a few capacitors look at the top of the caps they should all appear flat if you see any that are bulged or expanded then more then likely that is your problem. I just had the exact same problem with my 50 inch plasma and I fixed it. I removed the back of the tv located two swollen caps unsolder them from the board tested them with a meter and confirmed that the larger 50volt 1500 uf 105deg was indeed burnt and the smaller swollen one 35v 1500uf was still good but changed it anyhow just because it looked like it didnt have much life left.
Posted on Apr 06, 2011
  • dojr413 Apr 15, 2011
    I agree with marky always look for caps first but also if your not confident in changing out caps or unsure how to test you can always buy the whole power supply board on sites like eBay.com and shopjimmy.com
    Problem Solver:
  • 5 Answers
I just picked up the same tv today I noticed after a couple min it shuts off and clicking same as yours. I took the cover off and it seemed to stay on longer but same thing. Then I tried running a small fan next to the power supply and It ran no problem for an hour straight you can try this without taking the cover off and aim it at the top air vent on the back cover. Runs flawlessly now. I am going to Look into stealing a fan out of another plasma I have laying around or ordering one that will match a voltage I can splice into off the power supply board preferably the smaller the voltage the better. It's a pretty crappy design for a samsung. I don't know if this will help you or not but good luck.
Posted on Apr 19, 2011
I have a Samsung Plasma PN63A650 that has worked 4 8 years, until today. I turned it on, stays on for 14 seconds, then turns off for 8 seconds. Would not respond to remote commands either
Easy fix for new Samsung TV switching on and off power ...
? 4:41
https://www.youtube.com/watch?v=H0cG3lzjuw8
Sep 15, 2012 - Uploaded by alwaysafix
My tv turns on and off by itself the minute I plug in the cable. ....Samsung E6030 led tv hv blinkin red light issue ... capacitors are looking good ...
Help PLEASE! Samsung Plasma Turning On/Off Repeatedly.
michiganstate.247sports.com > Topics
247Sports.comMy Samsung Plasma HDTV (approx 3.5years old) has some issues as of late. When Iturn the tv on, invariably, it starts to turn off and back on repeatedly.
Samsung Smart TV turning off - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - I have a Samsung plasma 60 inch model number PN60E6500EFXZA TV. It began to turn itself off every 5 minutes, for the past few days. I was able to factory ... Samsung TV Keeps turning off and on.
Jun 11, 2015
Samsung TV Keeps Shutting Down
Jun 11, 2015
Samsung Plasma TV turns off by itself
Jun 22, 2011
My Samsung 50 in PN50B650 turns off by itself then on again ...
Apr 30, 2010
More results from www.cnet.com
Jan 13, 2016 | Samsung Televison & Video
My TV randomly switches itself off and the red light flashes continously and i have to pull out the plug. its getting more frequent
Samsung TV Keeps Shutting Down - Forums - CNET
CNETJun 11, 2015 - When I turn the TV on for the first time each day it shuts itself off within 30 seconds. ... green light flashing red light is [standby term] green light is [lamp]flashing. samsung plasma 850 picks up other remote signals?
Jun 12, 2015
Samsung LED UN55B7100 turns off on its own.
Jun 11, 2015
Volume goes automatically to 0 on my Samsung LCD TV
Jun 10, 2015
Why TV turns off by itself?
Jul 12, 2012
? 4:41
My tv turns on and off by itself the minute I plug in the cable. .... Samsung E6030 led tv hv blinkin red light ...
Dec 25, 2015 | Televison & Video
My plasma turns itself off for about 10 20 mins
It seems that your unit has some sort of Thermal PSU fault, or a problem that is shutting down the Power Supply Unit, PSU. This happens so that no further damage, and possible fire will occur. After it shuts down and the faulty component(s) cool down, it restarts again until it once again goes critical and shuts down again only to repeat the cyle.
You need to take the unit to a reputable service centre/man and ask for a firm "Quote" for the work to be done.
Jan 21, 2010 | Samsung HP-R5072 50 in. Plasma HDTV
I have a hp t 4254. it randomly turns itself off
There can be several causes for this, few of which you can do anything about. However, a few things to try:
1) Replace the batteries on your remote control.
2) Try resetting the logic functions on your tv by unplugging it for a minute, then plugging it back in.
3) Try covering up the infra-red receptor on the front of your TV to see if you're getting unwanted signals from the receptor. taping a piece of foil over that area is perfect. If it doesn't stop after doing these two things you'll probably need to take it to a shop.
4) If this does stop it, then look for unexpected signal sources. Have you added a remote control extender? Added a new device to your audio-video system? Changed to a new remote?
I hope this helps. Joe
Dec 23, 2009 | Samsung HP-T4254 42 in. Plasma Television
My 50 inch samsung plasma tv turns off and on by itself. it also clicks while this happens.
My Samsung 52" plasma TV will shut off while watching TV. It will do it repeatedly and we have to turn it back on. Is it overheating and shuts down? How can this be fixed?
Oct 27, 2009 | Samsung HP-R4262 42 in. Plasma Television
I have a Samsung FPT5084 Plasma TV and it keeps shutting off
It could be the power PCB, but it is hard to say over the internet.
I am looking for one with a good screen since mine got cracked (don't ask LOL) so if you are interested in selling it let me know.
Thanks
yrk2.7t AT (replace with @ symbol) gmail.com
Jul 29, 2009 | Samsung FPT5084 50 in. Plasma HDTV
TV shut off and won't turn back on??
Sounds like my Samsung. Searched web and said to check the capacitor (good thing there was only one capacitor) rated at 100 uf at 450 volts. Measured at the capacitor - has only 380 volts. Have a 150 uf and 220 uf at 400 volts. (Samsung's capacitor was 450 v.) Worrisome, yes. Tried all combination, but only 150 uf plus the 220 uf would work. Measured 390 volts.
Nov 07, 2017 | LG 42PC3DV 42 in. Plasma EDTV
Keeps turning off-Philips 50PF9431D
63 inch samsung plasma turn off then back on buy its self
Nov 14, 2007 | Philips 50PF9431D Television
Samsung HP-R4262 42 in. Plasma Television Logo
1,089 people viewed this question
Jerry Greenberg
Jerry Greenberg
