Question about Dell Poweredge 650 - P4 3.0GHZ, 1GB/40GB PC Desktop
I am trying to upgrade my PE650 from a Celeron CPU to a P4 2.8GHz. Once I change the CPU the server will not run the BIOS. I just get a blank screen with all the fans running. Do I need to reset the BIOS to Factory Defaults?
  • David Petry Apr 06, 2011
    Can you get into your bios by hitting F8 or F12 at start up? Will it start in safe mode?
    Scholar:
  • 95 Answers
First of all, open your case with the power unplugged and check to make sure you plugged in every part of the motherboard to the power supply. Look for white plugs.
If that doesn't work, try this:
1. Go to this website and scroll down to Figure 5-2. http://support.ap.dell.com/support/edocs/systems/pe650/en/sm/jumpers.htm
2. While the computer is off and unplugged, use the picture as a reference and move the jumper on your motherboard to NVRAM_CLR.
3. Plug in your computer and boot it up. Wait at least 15 seconds then turn off the computer and unplug it.
4. Change the Jumper back to it's original position on the motherboard.
5. Plug in the computer and run the BIOS
Thanks, Rodrick
Posted on Apr 06, 2011
Changing CPU - Celeron with Pentium 4 - the PC does not start. Is any switch to modify on mainboard ?
may have to check that its compatible and if so you probably need to upgrade motherboard bios to support new chip. Put old one back in update system bios then install new one if supported. Have run into this many times.
Jul 04, 2011 | Computers & Internet
ASUS CUSI-M ACPI BIOS Revision 1007 run very slow when i wana use 1024 by 768 pixel.how i can solve this problem.my processor speed is 700 MHz. 2.is it possible AMD 1.3 processor connect with this...
Getting you're system to display 1024 x 768 resolution depends on the graphics card. If you’re using the onboard VGA you will have poor display.
Suggest you use a PCI (White slot) graphics card with its own memory onboard. You will also need to make a bios setting change so the system boots to the PCI card and not the VGA.
Asus no longer provides support for this MB including drivers and bios.
You're board also supports slot A (For AMD), processors.
Only Intel Celeron and Intel Pentium III. Socket 370
see link provided;
http://www.cpu-upgrade.com/mb-ASUS/CUSI-M.html
Max CPU supported (With out over clocking);
http://www.cpu-world.com/CPUs/Celeron/Intel-Celeron%201100%20-%20RB80526RY005128%20(BX80526F1100128).html
In order to run this CPU you would need to update the bios to rev 1009. You'll find rev 1009 at the next link; http://www.userdrivers.com/BIOS/Asus-CUSI-M-BIOS-1009-With-LAN/
From what I've read it is possible to Get an AMD slot A CPU into a socket 370 MB. (Don't hold me to this though. This is a first for an old dog.
Any one of these PCI graphics cards should function on you're MB; http://www.tigerdirect.com/applications/Category/guidedSearch.asp?CatId=28&sel=Detail;55_158_2872_2872
Hope you find this helpful
Mike
Jun 04, 2010 | ASUS SiS Chipset CUSI-FX Motherboard
I have an Intel D845HV motherboard running with a
In short, yes you can upgrade to a P4 cpu but from the compatibility chart at Intel support, it looks like the upper limit for this older board is the P4 2.6GHz.
Note: Even at that, running the P4 2.6 would require a BIOS upgrade to P12 or greater.
Luckily, the following link has the information you seek: (for BIOS info, click the "BIOS Version" link in the upper right corner of the compatibility table provided)
Intel D845HV CPU Compatibility
I hope this info is helpful!
Mar 08, 2010 | Intel D845HV (735858149143) Motherboard
Upgrade PCChips M925
According to PCChips, the maximum CPU & memory supported for all three is the Intel P4 Northwood (HT) 3.06 GHz 512K,533FSB,Socket 478 and 2GB (2 x 1GB) DDR 266.
Be sure you have the latest BIOS version for your motherbaord.
M925ALU (V7.3) must have BIOS : 030703s
M925G (V8.0) and M925G (V9.1b) must have BIOS : 050510s
Hope this helps you out.
Jan 09, 2010 | PC Chips (M925G) Motherboard
Pentium 4 3.4 GHz S478 800 FSB cpu compatibility?
motherboard does not support this UPGRADE of processor, Regards
Apr 08, 2009 | Computers & Internet
I want upgrade
hello, i would install the cpu you wish to use, then see how it runs. and then do a bios update. this may work,if not the motherboard may not be compatible with the cpu upgrade, (propriatory equipment sometimes does not allow such upgrades) like hit or miss! i hope this info helps,and you get the dell to accept the faster cpu. good luck! glen
Feb 15, 2009 | Dell Pentium 3, 500 MHz Pentium III-M...
Toshiba Satellite M45-S169 CPU Upgrade
the chipset will support pentium M processors and some pentium 4 notebook processors. the bios should recognize the processor's new speed and should be able to support a 533mhz fsb. as long as your celeron is not soldered to the socket, you should be fine with the upgrade.
Dec 24, 2008 | Toshiba Satellite M45-S169 Notebook
Cpu upgrade wont happen
Ok i checked the ASUS website and looked up the CPU compatibility list for your board here:
http://support.asus.com/cpusupport/cpusupport.aspx?SLanguage=en-us
But unfortunately that particular CPU doesn’t seem to be supported. Must be something to do with the technology inside the CPU or the amount of L2 cache or something like that. (it would require some rather intensive research to find out exact reason why...
And when searching for ASUS motherboards that are compatible with that CPU it comes up with this short list;
AP120-E1
AP130-E1
PSCHL009
AP140R-E1
P4RD1-MX
Did you clear the cmos when installing the new cpu before powering it up?
i know the CPU you have now runs at 400FSB and the new one runs at 800FSB But that board supports both speeds so that shouldn’t be a problem.
What type of RAM do you have ?
maybe check owners manual for memory compatibility chart for new 800FSB CPU
Have you tried the latest beta bios from ASUS site :
I can not guarantee that it will work but it is worth a try.
http://support.asus.com/download/download.aspx?model=P4S800D-X%20&f_type=34&SLanguage=en-us
NOTE: Updating the bios can be risky and should only be done to resolve compatibility issues or things like that (or to add CPU support) In the rare event of a power failure during bios update your motherboard could become permanently unusable. (Always use a brand new floppy and follow the instructions to the letter when updating system bios)
Nov 22, 2008 | ASUS P4S800D-X Motherboard
Upgrade cpu
According to the product website your board supports all intel socket 478 cpu's. Maybe you bought a faulty cpu ?
M266A
  1. Socket 478 for Intel® P4 processor
  2. VIA® P4M266A chipset
  • FSB 533MHz
  • Supports Hyper-Threading Technology
  • Hybrid Booster - a safe overclocking feature
  • 2xDDR 266/200
  • Integrated ProSavage8 3D Graphic
Socket 478, Intel® Pentium 4 / Celeron
- FSB 533/400MHz
Jun 22, 2008 | Asrock M266A Motherboard
Upgrade the processor on a Toshiba equium l40 series from a celron M
The core2 duo chips will be a different socket to your celeron cpu so can do that unfortunately. You may be able to upgrade to a faster cpu of the same socket type but will probably need a bios update for it to run at proper speed.
Unfortunately laptops arent really designed to be upgraded at all bar extra ram/hd/dvdrw.
Hope that helps?
Dec 26, 2007 | Toshiba Celeron, 2.50 GHz (P000396980)...
Computers & Internet Logo
55 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
