The paper is jammed and I need to get into the rollers to get it out but I can seem to get inside machine?
  • Steve Allison
    Steve Allison Apr 06, 2011
    No brand name+no model number=no response.
    Master:
  • 395 Answers
Depending on what makes and model. Usually you can do by remove the print cartridge, look for inside. It can be on side or on back too. good luck
Posted on Apr 06, 2011
agnelkj
  • 210 Answers
SOURCE: paper jam
hi,
try this....
> unplug power chord
> open the rear access door
> remove the paper jammed
> close the rear access door
> plug the power chord
> try to copy
thanks and regards
agnel
Posted on Mar 18, 2008
shivam4529
  • 150 Answers
SOURCE: Paper not feeding in the
After so much paper goes thru the rollers they pick up dust and dont stick. Some models you can unplug and then use a q tip soaked in alcohol to clean the roller. Others require you to take them apart to clean. If you have to take it in to get fixed then check out the new ones from a computer store. Sometimes its cheaper to get a new printer than go get yours repaired or cleaned. If you do decide to have it done look really close when they get done and ensure the rollers were cleaned with alcohol. Otherwise they mihgt still have a oil coating on then and that causes them to slip also, especially on photo paper. They will argue in some places that the alcohol will dry out the rubber and it will age and crack. Altho this is true I have yet to see a dry, aged or cracked pickup roller, even 15 years in the business. I think thats because it takes longer to age and crack a rubber roller than it does to just wear out the machine. Jonathon
Posted on Jun 18, 2008
SOURCE: phaser 860 screen says "paper jam - open front cover to clear"
I posted a problem with the phaser 860 paper jam. I found 2 broken sensor flags and am ordering the parts.
Posted on Mar 19, 2009
  • 13433 Answers
SOURCE: paper jam ,no paper jam found Dell 1815dn
give this a try
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Posted on Jun 12, 2009
SOURCE: Paper jammed at exit rollers of Canon D860. Paper
You can download the repair manual for a similiar Canon printer, the iR1200-1500, on Ebay for $ 3.00 to $ 5.00 and this will tell you how to take apart the printer. I had the same problem and the manual allowed me to remove the fuser assembly and clear the jam. If you prefer, Canon sells the Image Class D860/880 repair manual for you printer for $54 plus shipping. The Ebay dealer also included the parts maunal, which is a sepatate charge from Canon.
Posted on Jul 18, 2010
Samsung SCX 4623F " Paper Jam Inside"
If you wish to get some details; check the site linked here. Pull up older posts.
Jul 05, 2016 | Office Equipment & Supplies
Paper jams in back of machine?
you have an obstruction either a piece of paper between the rolllers or the secondary feed rollers are not turning.... open the machine and follow the feed path ...take a piece of paper and manually feed the paper with the machine in the off position look at the feed rollers then the secondary rollers( usually two small rods with rubber sleeves kissing each other ...if you can look at the sides on the machine( inside the cover) see if the gears ( usually white ) can turn or mesh correctly... if you do not see any obstruction then these rollers are not turning when they are supposed to when you press the print button. 90 percent of these problems are paper jams if no jam something is not activating the feed rollers
Sep 05, 2014 | Brother IntelliFax-2820 Laser Fax
I am getting a "paper jam" signal but can find no
This seems to be fault in the transport of the paper in the rollers. So if you have used any adhesive sticker printing, it is possible that some glue has got clogged into the rollers. If not there can be some jammed paper in the rollers or the mechanism.
So start this work only if you are mechanically able with the right tools.
Remove the covers to get access to the mechanism . Remove the motor drive assembly , the fitting of the motor to the mechanism. Once this is removed the rollers can be turned manually so that you will be able to feed a paper to see the progress of the movement while studying if there is any obstruction or damage to the paper.
There is a in-detect sensor, usually an opto-coupler , make sure this is not clogged or dirty as this IR detection feeds the signal to the processor for starting the motor drive feed.
Reassemble but make sure the rollers are aligned to be in equal gap to feed the paper without a side pull. Now you must print and see if the fault has changed. If not repeat the above work to confirm the area of obstruction.
Oct 30, 2010 | HP OfficeJet 6210 All-In-One InkJet...
My printer is eating my paper and it wont print. It seems like my paper is getting jammed inside and then I have to yank it back out.
on the back side of the printer is a door to access the jammed paper check out if any of the paper piece is got there already jammed and due to this other papers passing through that area are getting jammed.if that area is clear then its gear problem which pulls the paper
There are rollers that cling on to the paper and move it through the machine. When the rollers are worn down they do not grip the paper. For a short fix you can get something rough like sandpaper, brillo pad, etc, and gently scratch the rollers to give them some traction. This will temporarily solve your problem until you can get the rollers replaced.
thanks
Nov 11, 2009 | Lexmark X2690 All-In-One InkJet Printer
Paper jams no matter what stock I use; Lexmark e232
Slipping paper feed rollers is probably causing the jamming. Remove the paper tray and tip the machine back so that you can access the feed rollers from underneath. A good technique to isolate this problem is to remove the rubber feed tires, turn them inside-out and refit them. If it now works OK you need to get new feed rollers.
Jun 01, 2009 | Lexmark E232 Laser Printer
Fax machine says Rec. Paper Jam
Check the paper, is it loaded correctly? Have you fanned the paper to break the production bond? Is the paper a good quality? Remove all of the paper and check inside for any foreign objects.(paper clips, staples) Reinstall paper. Mark the top sheet of paper with an x, press the copy button, does it even try to pull in the paper?
If yes, the pick up rollers are likely dirty, and need to be cleaned, remove the paper and clean the rollers with some isopropal alcohol, and a soft cloth. (available at a drug store) Retry
If it doesn't try at all, then turn machine off and unplug it for a few minutes,re connect, power up. Any change? if not machine has a feed problem that may require a Tech to look at.
Hope this is of some help.
Ed
Apr 20, 2009 | Canon CFX-L4000 Plain Paper Laser Fax
Paper Jam with no access to clear
you will need to remove the fuser module from the machine and open the fuser to remove the wrinkeled paper inside the fuser section. then reinstall the duser in the reverse way
Jun 25, 2008 | Brother MFC-8440 All-In-One Laser Printer
Paper not feeding
If there is no paper jammed inside the machine, then look at the "paper out" roller, this is the last roller in the paper path. I would suspect it is out of alignment.
May 11, 2008 | Brother IntelliFAX 2800 Laser Fax
Brother 4100e paper jam
Can be tricky people usally damage the fuser rollers removing this jam with pliers/tweezers, it has concertined and stuck after fuser rollers and before exit rollers it will be stuck on the switch best bet is to dismantle properly and remove fuser then dismantle fuser and remove jam, another thing to be concerned about is why did it, three seneraros, Damp paper going threw fuser dries and crincles(use fresh paper from sealed packet), fuser is worn(have fuser replaced), just a bad bit of paper (just have fuser jam removed. Fusrr runs on 240v, covers break easy
Oct 15, 2007 | Brother IntelliFAX 1270E Plain Paper Fax
Paper jam
There are several things that can cause a paper jam error, even though there is no paper stuck. The most common is that the paper pickup rollers are worn or dirty, and can't grab paper. Even though there is no paper jammed in the machine, it will show the error message. The solution is to clean the roller with alcohol and a lint-free cloth (don't use paper towels). If the roller is very worn, you will need to replace it.
Feb 04, 2007 | Canon Image Runner 1630 Copier Copier
13 people viewed this question
jasbo
jasbo
