Question about Garden
Working on a ventrac 4200 diesel 31 h.p.turbo diesel.Had blown oil out exhaust when brought in.Added a little oil,checked radiator,added about about 1 gal.coolant and it started running out exhaust pipe.Pulled head but head gasket seems ok.Sending head out tommorow to be checked for crack.What do I need to check in turbo?Seals and turbine itself?Engine skipped bad and blew out white smoke.Middle cylinder was really wet.Any ideas?
mighty thor
  • 51 Answers
SOURCE: Not getting gas to combustion chamber, leaking gas from exhaust
Definitely the carburetor. Take it off and look for something clogged. Look carefully at the gaskets. Look for water and dirt in the float bowl.
Posted on Nov 24, 2008
Caesarfix
  • 141 Answers
SOURCE: engine runs but has steam coming out of exhaust pipe
water inside pistons increases compression, You do not have bad piston rings and not burn out intake or exhaust valves, your compression is fine, but You have a blown Head Gasket or a crack for sure
Posted on Jan 22, 2009
yotaguy
  • 232 Answers
SOURCE: water in oil
I have yet to see a cracked head on a 22R,so more than likely a blown head gasket,unless you overheated and warped the head and worst case a hole between the cylinder wall and water jacket(this is pretty rare).The only way to tell short of using some expensive tools or taking to your local shop is to pull the head and inspect the gasket for leakage wich is generally fairly obvious(separation of the gasket layers,oil and water between water and oil passages)and checking the head deck for warpage.If there is obvious leakage in the gasket you're looking at a top end gasket set if the head is slightly warped you can get away with a thick graphite head gasket,I personally use these as they are very forgiving on slightly warped and scratched head decks and inepensive also,but a severly warped head will require milling at a machine shop or replacement.
Posted on Apr 09, 2009
SOURCE: TRACTOR BLEW WHITE SMOKE, AND STARTS TO SPUTTER
The oil breather hose connects from the crankcase to the carburetor. If the breather assembly on the crankcase gets plugged, oil can be pulled into the carburetor through the breather hose. Try removing the breather assembly from the crankcase and cleaning it in gasoline, followed with a blowout with compressed air. You can also just replace the breather assembly and hose.
Posted on Apr 19, 2009
  • 376 Answers
SOURCE: I have gas going into my oil. 17.5 Briggs solenoid on carb bowl
The problem is the float needle and seat are leaking. It is not shutting off the gas when the bowl is full. The bowl fills up, then runs down the intake through the intake valve into cylinder, past the rings into the crankcase. Fairly common problem. Just replacing the rubber tipped needle probably will not stop the leak. The pressed-in brass seat needs to be pulled out and a new one pressed in also. Possibly there is some trash or rust in the carb that has gotten between the needle and seat, but in my experience, it usually takes replacing both to fix.
Posted on Jun 25, 2009
I got a tata 407 turbo but the performance is poor it also smokes black and the fuel is black can some please help
Best I can tell this is a diesel truck? I know diesel, but
depending on age could be injectors, possibly Diesel injection pump hopefully not. The fuel is black? Someone is putting old engine lubricating oil in the fuel tank. It will increase the problem of black smoke. It may also have a bad smell because of the engine oil. If the turbo is not spinning properly (high pitched whine) the bearings may be bad and it's not getting enough air into the engine. This would also explain the smoke problem. Take it to a Diesel specialist!
Mar 05, 2015 | Tata Cars & Trucks
I have a Isusu 2.8 with 2c toyota diesel turbo engine and was having broken camshaft standing almost 3 years i replace the camshaft new oil filter and oil it dont want to start at it's own i put a...
for starters...this thing has set for 3 years and you did not put fresh fuel in it???. diesel will jel up over time..it needs totally cleaned out and fresh fuel added..put enough in it to run about an hour.. and recheck everything..may need to add cetane booster to the fuel..
Dec 15, 2013 | Cars & Trucks
Ventrac problems
that ventrac if i'm not mistaken has a turbo on it. Make sure the turbo is ok. That is a great motor and should have plenty of power to run all attachments
May 29, 2013 | Garden
1991 Cadillac Fleetwood. The heater was working on passenger side but not that warm. Added antifreeze. Seems to be leaking it. Keep adding. gone thru 2 gallons. How do i get heat.
If you've added two gallons of antifreeze, you need to find out where it's going. Make sure the antifreeze you are adding is diluted with water in a 50/50 solution. Pure antifreeze has little freeze protection and boils quickly. If there is no visible leak, check your oil for coolant contamination. Fill the radiator and leave the radiator cap off. Put the heater controls on hottest setting, but do not turn the heater on. Start the engine and watch the coolant. If the coolant level drops, add more to full. If the coolant is flowing thru the radiator when you first start the engine, the thermostat is stuck open and needs to be replaced. If the water is not flowing, then keep an eye on it and wait for the thermostat to open. Add antifreeze to keep the radiator full. Look for air bubbles or lots of foaming in the coolant. That would indicate a blown head gasket and the reason you are losing antifreeze. If there's no bubbles, and the coolant level stays full, put the radiator cap back on and see if the heater is working better.
Jan 11, 2011 | 1991 Cadillac Fleetwood
2002 Malibu,V6, approx 120,000 miles. Air cond, heater & defrosters do not work. Couple of days ago, car overheated suddenly. Drove car after water was added to resevoir. Drove & temp spiked &...
white smoke usually means blown head gaskets,have radiator fan checked,water pump,check coolant for oil in coolant,could be blown in between cylinders,causing coolant to go out exhaust,have compression check done on cylinders.
Dec 31, 2010 | 2002 Chevrolet Malibu
Which oil can be used to lubricate an turbo of a 2003 jetta tdi, can this be added in the fuel tank
PLEASE DO NOT add any oil to the fuel,use redexe/wynns diesel additive to clean the lines/injectors/turbo vanes,but burnt oil will stick to the turbo vanes and could cause failure.....just use 10/40 semi synthetic oil as normal and change regularly.also let the car tickover for a min or two after a HOT run....
Nov 02, 2010 | 2003 Volkswagen Jetta TDI
97 marquis, owner stated car shut while driving, oil light came on he added oil, car the cranked, drove home, next day while driving car shut off again, same problem, adds oil(but doesn't check dipstick,...
yes that is a sure sign of a blown head gasket! water and anti-freexe is heavier than oil and settles to bottom and will not mix with oil and will be the first out of the holel!.
hopefully this help you. good luck man
Oct 25, 2009 | 1995 Mercury Grand Marquis
My 2000 diesel 2.o freelander propshaft was recently repaired. The turbo has suddenly failed sending oil all over the engine. 1st there was a big cloud of black smoke. Engine revved very high. refused to...
Hi ,
Not easy this one,when your turbo failed the oil feed to the turbo bearings continued to feed engine oil into the intake side(could not turn off),the engine is then Un-governed and free to rev way above maximum limit,it has then massively over heated, the oil treatments are unlikely to cause this problem ,usually down to not letting the Turbo "wind down " after driving,The best course of action is to replace the engine and turbo charger and have the induction pipes and intercooler properly cleaned ,there are no cheap fixes for this you were just unlucky.
Jul 11, 2009 | 2005 Land Rover Freelander
Oil coming out of exhaust and whistling turbo
it sounds like your turbo has packed in firstly the oil seal in your turbo has failed thats why ur seeing oil from exhaust & the whistling from turbo is the vanes in turbo breaking up so i would advise not to use car until new turbo is fitted & inter cooler pipes and inter cooler itself are checked & cleaned for swarf from turbo you can check turbo by disconnecting turbo pipe &inspecting turbo vanes (fins) to see if broken up or any damage to chamber.
Feb 14, 2009 | 1991 Peugeot 405
Garden Logo
203 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
