Hi! I have the Targus Chill Mat AWE41US and the cable is not working properly at all... it's just broken... I saw I needed to open it up... but i'm really not good with anything like that. Do you know what kind of cable it is for me to replace it?
    Guru:
  • 811 Answers
I did some research and found your product and replacement parts are Click Here Thanks for using FixYa! John
Posted on Apr 06, 2011
How do I get the additional usb ports to work on targus awe0101us1 chill pad
Does your laptop recognize the extra USB ports? If no, try updating your drivers.
Jan 15, 2015 | Targus PA248U AWE01US Chill Mat and four...
Targus chill mat won't work
it is definatly either a wiring issue or a cpu issue
Mar 18, 2014 | Targus Chill Mat PA248U Laptop Cooler
Lost the targus notebook chill mat power cord (usb from computer to the mat). Where can I find a replacement?
hi this can be purchased from somewhere like radio shack specs are Output: 5V 2000mA, centre is + positive so really just your standard adaptor will do, this also comes from the targus site hope that helps
Oct 02, 2010 | Targus Chill Mat PA248U Laptop Cooler
Targus Chill Mat. I keep getting error with windows 7 that the device is not working properly. It operates but an error keeps popping up every 10 seconds. So I can not use it. What is the fix?
Belkin makes a surge plug that has usb powered ports.
this is a Gr8 option it takes the poering off the pc.
this should fix ya up.
Good Luck
Happy Computing
Jan 10, 2010 | Targus AWE19US Chill Mat XC for Laptops
Targus Chill Mat Fan On Fritz
The fan rotor is stuck due to accumulation of dust. Take out the fan and clean it. Put a few drops of alcohol or lacquer thinner on the rotor/bushing assembly while manually turning its blades to loosen the hardened dirt until the fan freely spins like the good one. If it does not work, replace the defective fan if spare is available.
Aug 19, 2009 | Targus Chill Mat PA248U Laptop Cooler
Power cable problems, also
open it up and splice the current power cable and connect it permanently to the USB connector. The problem is the power plug gets loosened after some time and can't make a proper connection.
May 24, 2009 | Targus Chill Mat PA248U Laptop Cooler
Chill mat
i have 1 as well and it broke too. this is http://computers.pricegrabber.com/laptop-accessories/m/1754767/
right?
if its the cord's thats broken, its most likely the switch, more specifically the soldering where the wire connects to the switch is prolly broken. i just sawed my switch open w/ a knife, and took a look. now if a wire is loose in the switch, u can either solder it back on, or (in my case i always have the fan on anyway cuz of my **** dell computer overheating) rip the wire off the switch completely and just connected it w/ aluminum foil.
Mar 24, 2008 | Targus Chill Mat PA248U Laptop Cooler
Targus chill mat not working properly
This problem is being caused by a wire becoming disconnected from the switch in the usb power cord. The easiest way to solve this problem is to open the switch using a flat blade like a knife, and either reconnect the loose wire yourself or to completely remove the switch and connect the wires together completing the circuit and allowing the fan to operate. I hope this helps.
Oct 30, 2007 | Targus Chill Mat PA248U Laptop Cooler
Computers & Internet Logo
52 people viewed this question
David Payne
David Payne
