Question about Air Conditioning and Heat for Isuzu Trooper
The air-conditioner fails to cool after sometime unless I swicth off the engine and start again.
  • 81 Answers
There is a thermo sensor switch that needs to be replaced.there are a lot of places that offer free a/c checks. take your car to one of those places to have it checked for free and have them give you an estimate on replacement cost.
Posted on May 29, 2011
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
Model 24KD0247. Why does it shut off and blink 5 times?
Plz mention it is split or cassette type unit... Tnq
Sep 02, 2015 | Carrier Heating & Cooling
Air conditioner cools for 30 minutes then stops cooling after 20 minutes starts cooling again what is likely problem
The compressor motor is over heating and thermal protection shuts it down , when it cools down it restarts. Restricted air flow over the cooling coils could be the cause. Check filter,Sometimes furniture or other things block the return air vent.
Aug 27, 2014 | Heating & Cooling
2004 mazda mpv engine racing and cooling fan not working
coolant temp sensor tells the computer how hot or cold the engine is so it can regulate the idle and fuel mixture, when it fails there usually is no cooling fan and you will have trouble starting the engine and keeping it running.
Oct 08, 2012 | 2004 Mazda MPV
Danby DB98-26786A window air conditioner will start up and blow cold air..frost forms on the tubes..after a few minutes the frost disappears and the compressor shuts off .. the fan still blows; but no...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Jul 23, 2011 | Danby Heating & Cooling
Sometimes it runs fine and sometimes it overloads my generator
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
The compressor is not starting right every time....the problem is probably the start capacitor for the compressor...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble - Review the Possibilities
heatman101
Sep 09, 2010 | Dometic Rooftop RV Air Conditioner
Our carrier air conditioner failed to cool down the house last night. changed the filter and still struggling to cool house down.
is it cooling some at night but none during the day basically ? Outside unit clean also ? Good airflow ? if yes on all of these feel the copper pipes that go inside the house from the outside and once a/c has been on for a few minutes the large line should be very cool or cold to where it would condensate.. Sometimes it may take up to 15 minutes..
Aug 20, 2010 | Carrier 38CKC024 Air Conditioner
1996 Buick Roadmaster rough start sputters and
Check the mass air flow sensor (clean both heated wires with carb cleaner and Q-tip). Remember...cleaning does not always work...sometimes they are actually bad. Also check map sensor. Check for vacuum leaks at all hoses and fittings. If engine rpm drops sufficiently, engine vacuum will drop which may have caused a/c malfunction (controls work with vacuum signal) so I wouldn't worry about that 'till the run problem is dealt with.
Jul 30, 2009 | 1990 Buick LeSabre
Panasonic casette air conditioner-display error temp 'CHECK'
Check that your water pump is working and not blocked up as the unit will keep swicthing off if it can not get rid of the water.
Nov 24, 2008 | Panasonic CW-C60RU Air Conditioner
CHECK ENGINE LIGHT ON, AUTO ZONE SAYS COOLING FAN SHORTAGE
If the fuse is blowing there is too much resistance in the cooling fan moter. Replace JUST the cooling fan motor and the fuse. The A/C always turns the cooling fan ON when turned on. That is why the A/C messes up when the fan motor is bad. Replace the fan motor and the A/C problem will be fixed too. :)
Aug 07, 2008 | 2004 Chevrolet Cavalier
Carrier Weathermaker gas 8000 will not ignite
1. check indoor unit wiring.
2 check sensar of thermostate.
3if not change thermostate
Mar 25, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
Air Conditioning and Heat for Isuzu Trooper Logo
156 people viewed this question
Top Isuzu Vehicle Parts & Accessories Experts
Randy Ohler
Rick Wrieden
Rick Wrieden
George Agios
George Agios
Are you an Isuzu Vehicle Part and Accessory Expert? Answer questions, earn points and help others
