Question about Briggs & Stratton Briggs Stratton Lawnmower Lawn Mower Short Block
I have a 5.5 OHV Briggs & Stratton and it only runs good when it almost fully choked or half choked. There is one adjustment screw on the carb., but when I adjust it , it does not seem to run any better. When the choke is open it kills. What's wrong?
    Novelist:
  • 111 Answers
The carburetor needs to be cleaned. There is something in one of the passages that is keeping it from running correctly. To do this you will need a can of carburetor cleaner (spray) and a very thin wire to probe in all of the holes of the carburetor. First, take the carburetor loose from where it mounts to the engine. Then take the wire and probe all of the holes in the carburetor, and also the holes in the fuel bowl nut (if any are present). Then shoot the carburetor cleaner through the holes to remove any loose particles of dirt or debris and to make sure the passages are clear. After you have done this, then you will need to blow through the holes to make absolutely sure that everything is removed that could be blocking either fuel or air from passing through the carburetor. Re-install the carburetor back onto the engine, and check to see if the unit is running ok. If at this point the carburetor is still not running correctly, you may have to replace the carburetor. When you go to the parts counter you should have the MODEL, TYPE, and CODE off of the flywheel housing. These numbers are stamped into the metal. I hope this helps you out.
Posted on Apr 07, 2011
Briggs & stratton v-twin engine cuts out
acid dip rebuild carb make sure fuel selinoid on bottom of carb moves freely
Sep 07, 2012 | Briggs & Stratton Briggs Stratton Intek V...
Started engine prior to hurricane season . It seems to run good only in choke , adjust toward run and it quits!! thanks
If it only ran good with choke then that means the engine is running too lean and not getting enough fuel. You need to remove, fully disassemble, and thoroughly clean the carb. Or you could also just install a brand new carb if you don't have experience working on carburetors.
Jul 17, 2011 | Briggs Stratton IC Horizontal OHV Engine ...
I have a Intek Twin 24 ohv engine. It will only run smooth if the choke is half open. If the choke if fully opened, the engine is unsmooth and revs high to low by itself. I tried cleaning the carb but...
I had problems with my 20hp v twin.The fuel was the problem.I stopped using fuel with ethanol.Problem solved.My 60 hp Evinrude had the same problem.Ethanol was responsible for eating away gaskets and o-rings.This stuff also eats away at some aluminum carbs.Thanks congress for voting to add this **** to our fuel.Wish you would pick up the repair bills too.
Nov 13, 2010 | Briggs & Stratton Briggs Stratton Intek V...
I have a Briggs and STatton 24 OHV intek motor on a craftsman lawn tractor. I got it on sale and when I got home it ran rough. The fuel line had collapsed or was plugged with some white powder. I took off...
It sounds like the fuel mixture is running very Lean..There are usually two adjusting screw screws on the carburettor that control the mixture. A Larger one is for the Main Jet and a smaller one for the Idle Jet. There is also an adjusting screw on the throttle butterfly to control the idle speed.
To adjust setup, start with at least a half tank of fuel, and have engine at operating tempurature (That is warm but not overly Hot). As a starting point, loosen (anticlockwise) Main Jet screw about half a turn, to richen mixture,so that engine will run without choke. Run engine at full speed and adjust main jet for highest smooth speed without engine missing due to mixture being too lean or rich.
Allow engine to idle and the adjust Idle Jet Screw for smoothest idle. Idle Speed screw may have to be adjusted if idle speed is too high/low.
Sequence above may have to be repeated to get best running. If engine hesitates sometime when sudden load is applied but then picks up, try adjusting Main Jet by 1/8 to 1/4 turn richer until it handles the load without faltering.
Aug 22, 2010 | Briggs & Stratton Briggs Stratton Intek V...
3.5 Briggs with not run at full throttle
same problem, was told it was the jets, are your symptoms as follows
runs at low throttle, will only run at full throttle if fully choked
dies if choke is relieved
Apr 15, 2010 | Briggs & Stratton Briggs Stratton Intek V...
21hp intek v-twin runs only with choke on full
You are not getting enough fuel.... by choking it you are enriching the mixture with less air , more fuel.Some where in the fuel system or carbureator something is still plugged.Or the mixture screw is too far in.
Oct 30, 2009 | Briggs & Stratton Briggs Stratton Intek V...
I have the exact same problem on my 7hp briggs for a genny
Your carburetor is dirty. Need to be take apart and cleaned with carburetor cleaner.
Oct 06, 2009 | Briggs & Stratton Briggs Stratton Intek V...
22 hp Briggs Intek will not run at full speed without choke on
sounds like you sucked up dirt in the carb needs to be taken off and cleaned
Jul 17, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Carburetor adjustment
have you checked the air filter,if that is clean I think I would replace the carb, diaphram.
May 05, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Briggs & Stratton Briggs  Stratton Lawnmower Lawn Mower Short Block Logo
951 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
