Question about Vaultz VZ01002 Locking Cash Box
Safe will not open with correct combination. - Vaultz VZ01002 Locking Cash Box
I cannot open my safe I had turned the wrong combination and then tried to open with the correct combination but have tried many times with no success
You have either damaged the lock, or changed it to something other than the correct combination. Try settings, just slightly different to the "correct" one. If nothing else works you will need to call somebody to fix the lock.
Dec 29, 2017 | The Home Security
I forgot yo open a security box. Please let me know how.
1 You will need to find out the combination. The first thing to do is to move the entire dial that is in the lock to the right. This will let you know that all the wheels are disengaged. 3. You will need a stethoscope. Each time you turn the dial, you reach the point of the combination number you can hear a click here. You should make notes considering the numbers you can read on the dial each time you hear two clicks. This will help you know the length of the combination. You must use a stethoscope to listen carefully and precisely where the clicks sound. 4. Repeat the process. Then repeat the process considering the number of clicks you hear in the process, repeat several times to make sure you're right about the number of click. This information should be represented in a chart in order to know the numbers of the combination to open safe. You have to start testing the clicks generated by the box when the dial is turned, the dial should be at zero.
5. Combine data to open safe. With the data obtained when listening to the clicks generated by the dial, you should start making combinations and test them in the safe until you get the perfect combination that will help you open the safe. Example if when turning the dial you could hear 3 times two clicks, ie the combination of the safe must have 3 numbers. Consider the exact numbers you could see on the dial when you heard the clicks. Then you must have something like this in your notes (2, 65, 34). Start combining them and try in the safe until you find the right combination, start making patterns and discard. Then those copied in your notes will be the secret code numbers that will open safe. It is very important that you have been very careful when listening to the clicks and that this process has been done several times to be sure that these numbers are correct. Now you can make patterns, considering the numbers that you raise in the example, such as: 2.34,65); (34,265); (65,2,34) and so on until finding the correct one. That is why you need to write down all possible combinations and tosa trials. Remember the success of, without opening your safe, without a locksmith, and also considering that you do not have the possibility to call a manufacturer. Be: • Listen carefully to the sounds of the clicks you hear in the safe. • Avoid other sounds that may distort your ability to listen carefully • Record exact numbers where you clicked • Be patient and test your combinations. You must have on hand the instructions of the manufacturer of the safe, if you do not have it, look on the web since surely the manufacturer has a page where you can find this information. You could also call the manufacturer and prior identification will give you the key to your safe. Otherwise and if you've tried all the possible combinations and you just can not do it, call a locksmith. You no longer have a bad life and recover your valuable items, open safe can generate waste of time but if you strive you will stay with great satisfaction.
Aug 13, 2017 | Cell Phones
What does it mean if the red and green light flash together???
Do you have a key ??? try your combination and A or B
Open with key insert new batteries and reset combination.
Feb 14, 2015 | Honeywell Safes Top Opening Drawer Safe...
How do I lock my safe?
If you have it open and you know the combination you should be able to close it and turn the opening handle and spin the dial to lock the door. But do not do this unless you for sure KNOW what the correct combination is because if you do not and you get it locked you will not get it unlocked. Run the combination while it is opne now to be sure it is fully opened etc. which it sill need to be to lock it.
Sep 19, 2014 | Home Security
How do I change the safe's combination?
with door open, remove panel on back of door. remove the nut holding the three wheels in place and mark original location and then relocate the pin on back wheel. Reinstall nut. test visually to make sure you know the correct combination and be able to open it without watching the wheels in the door before closing and latching it again.
May 16, 2013 | Sentry Fireproof Security Safe Combination
I have a sentry fire safe and the plastic gear where the handle turns the safe open has been stripped. I have the correct combination and have replaced the batteries but i cannot get the safe to open
If someone attempts to open the locked safe by forcing the safe handle to the open position it can strip the plastic gear. So even if you have the correct safe code and the batteries are fully charged the safe will not open. If you can lay the safe on its side (hinge side on the floor) gravity and banging the side of the safe with a hammer may cause the bolts to unlock. Unfortunately, if this doesn't work you will need a locksmith to open the safe.
Good luck.
Terry Whin-Yates BA Hons (Criminology)
3rd Generation Master Locksmith
25+ Years Experience
BC Security License : B4227
604-773-5625
http://www.mrlocksmith.com/
Nov 24, 2010 | Sentry Safe Fire-Safe Home/Office Safe
Thought I knew the 4 number combination, now locked inside. I do have the key. However, safe not opening. What is the exact procudure for combo?
Without wishing to state the obvious, I feel that I must do so. A safe is called a safe for a very good reason. If it was easy to get inside without the correct key or combination then by definition it would be unsafe.
If you have lost the combination and the key doesn't work then you can either try every combination until you get lucky or you must consider calling out a locksmith who will usually open the safe destructively (often by drilling out the lock) or even by using an angle grinder on the hinges.
Sep 17, 2010 | Office Equipment & Supplies
Vaultz VZ01002 Locking Cash Box Logo
206 people viewed this question
Top Vaultz Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Vaultz Office Equipment and Supply Expert? Answer questions, earn points and help others
