Question about Samsung SyncMaster 910T 19" LCD Monitor
My screen is offset to the right - Samsung SyncMaster 910T 19" LCD Monitor
  • densputer Apr 07, 2011
    no buttons r workin on the monitor
    none of the buttons on the monitor are working
  • Samsung Master
  • 3,530 Answers
Welcome to Fixya
Adjust the H and V position of your screen. Press menu on your LCD and go to Image select H position or V position. Here's the manual of your monitor.
Thank you for using Fixya!
Posted on Apr 06, 2011
  • Jose Cada
    Jose Cada Apr 07, 2011
    what do you mean by "no buttons is working"? Are you getting any response when you press the buttons? if none then you need to have the monitor reoaired. Problem there might be the mainboard where the buttons is seated.
Monitor image became offset to the right. How to fix this?
Have you tried telling the computer that you want a single display and not dual?
Dec 19, 2013 | ASUS VW192S Monitor
Wavy green lines and offset during convergence calibration
There is whats called a convergence IC that is going bad inside this TV set. There is only one for all three tubes and the IC number is STK 393-11- and can be purchased here http://www.electronic-repair-kits.com/STK393-110.html You will only need to order one. If you are handy and can solder this should correct your problem. One very important thing is, before you reinstall the new convergence IC, make sure you use a good coating of heat sink compound on the back of the new IC. If you do not, the IC will fail within a short time frames. Only if you are good with a soldering gun should you attempt the repair. If you are not, this repair should run you about 300 bucks or so. Also if you are handy, there are seven capacitors that go bad inside a board called the DM board. These will go bad very soon so while your in there these should be changed as well. If you need info on how to change these capacitors, let me know and leave an e-mail and I will send you the pictorial on how this is done. the IC change you will need to find that, but I do have a service manual if you need one also to help you along if you can follow the schematic. Good Luck
Nov 01, 2007 | Mitsubishi WS-55511 55" Rear Projection...
Initial set up of delonghi ESAM6700 and it will not go past insert water spout stage. Even when spout inserted it does not recognise and we cant continue setting up the machine as it simply reads insert...
OK, I can answer this one... the same thing happened to me. It would not recognize the water spout. No beep when inserted, but it would beep if you inserted the milk container. Looking into the receptacle, I saw that the switch for the milk container is offset to the right, and the switch for the water spout is offset to the left. All I had to do was carefully bend the lower tang on the water spout that activates the switch to the left a little bit. It looked perfectly straight, but was just offset to the right enough to miss the switch.
Hope this helps someone.
May 08, 2011 | DeLonghi Prima Donna Avante ESAM6700...
Image on LG 42PC5D-UL is off center toward right side of screen after replacing main board eax38589402 from LG 50PC5d-UL. Both boards have same part number.
You've got to go minto your main menu and in the screen position settings you will be able to correct the horizontal offset and the verticle offset. You'll also hve the option of resetting all values to factory default but, I would suggest the former first. Thanks, Dana
Jan 15, 2011 | LG 42PC5D Television
Just bought an Adidas Seoul Watch ADH2044 and can't set the time. I've looked in the manual that came with it and online and can't find anything to help. The Adidas website isn't any help either.
Figured it out - Press & hold 'A' then press 'D'. THEN press 'B' to toggle through the selections to set T1. T2 (for another time zone) is up or down in the offset. Good luck!
btw - A, B buttons are from top to bottom on left and C, D are top to bottom right
Jan 07, 2011 | Adidas ADH1572 Watch
The screen is offset slightly on the right hand side, how do i get the whole screen back
hi you should be able to...right click anywhere on the desktop, ( not on an icon ) click properties, then go to settings and then adjust the resolution settings and that should sort it out for you...hope that helps please vote thanks
May 11, 2010 | Toshiba Satellite Pro A200-EZ2204X...
Touch screen controls offset by an inch
To Try To Test It,Go To Main Menu Then,Seting Then,Systum Settings Then Move Over 1 Then, Press Dionostics Then Touch Screen
Jul 11, 2009 | Magellan Maestro 4040 GPS Receiver
More than 256 characters in a cell in Excel
If a RANGES
\r\n
Named Ranges. SheetLevel Named Range, Named Constants, Named Formulas ,Relative Named Ranges ,Dynamic Named Ranges ,Advanced Dynamic Named Ranges .
\r\nWorking With Ranges. FindLast cell/row/column etc.
\r\nFormula Reference Changer. Absolute to Relative etc.
\r\nSpecialCells Method
\r\nExcel Named Range Manager $
\r\nOFFSET RANGES VBA
\r\nReturns a Range object that represents a range that?s offset from the specified range. Read-only.
\r\nexpression.Offset(RowOffset, ColumnOffset)
\r\n\\"expression\\" is required and should be a Range object.
\r\n
\r\nRowOffset: Optional Variant. The number of rows (positive, negative, or 0 (zero)) by which the range is to be offset. Positive values are offset downward, and negative values are offset upward. The default value is 0.
\r\n
\r\nColumnOffset: Optional Variant. The number of columns (positive, negative, or 0 (zero)) by which the range is to be offset. Positive values are offset to the right, and negative values are offset to the left. The default value is 0.
\r\n
\r\nExample
\r\nSub OffsetMe()
\r\n MsgBox Range(\\"B2\\").Offset(RowOffset:=-1, ColumnOffset:=2).Address
\r\nEnd Sub
\r\nIs the SAME as;
\r\nSub OffsetMe()
\r\n MsgBox Range(\\"B2\\").Offset(-1,2).Address
\r\nEnd Sub
\r\nOFFSET FORMULA
\r\nReturns a reference to a range that is a specified number of rows and columns from a cell or range of cells. The reference that is returned can be a single cell or a range of cells. You can specify the number of rows and the number of columns to be returned.Syntax = OFFSET(reference,rows,cols,height,width)
\r\n
\r\nExamples
\r\n=OFFSET(C3,2,3,1,1) Displays the value in cell F5.
\r\n=OFFSET(C3:E5,0,-3,3,3) Returns an error, because the reference is not valid.\", \"style=\\"background: #FFFFFF;padding: 2px;font-size: 10px;width: 550px;\\"\");" style="FONT-STYLE: italic" onmouseout="GAL_hidepopup();" href="http://www.ozgrid.com/forum/autolink.php?id=5&script=showthread&forumid=8">cell is formatted as Text, then it will display the #### when the text is over the limit. Reformat the cell to General and the text should again show.
Right click on the cell, click Format Cells, under the number tab, choose General.
Also, this ####, will occur is the cell width is to small.
May 16, 2008 | Microsoft Excel for PC
Display is offset
on the menu you might have an auto button that wil recenter and size your monitor screen
May 11, 2008 | Computers & Internet
Red is offset
Check out this link:
http://www.fixya.com/support/t261950-43h71
I offered some help to another person with the same problem and gave him a couple of good websites that will help.
I helped a friend with this problem. We fixed his set for about $25. The shop quote him $400.
Take a look and let me know if you need more help.
Dec 20, 2007 | Toshiba 55H70 55" Rear Projection...
Samsung SyncMaster 910T 19" LCD Monitor Logo
78 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
