Question about Plustek Office Equipment & Supplies
I am using Plustek M12 Scanner in the last 2 days I scan & click finish & nothing happens. I cannot open Digiscan to see if anything is saved.
I just installed the software yesterday so I noticed the same thing except that just after installing it a window popped up giving some default settings I changed my preferred format to "JPEG" and then selected an already existing folder for the images to go to as could not create a folder using the window ... so your image files are probably ending up in a default folder ... the manual is available for download from Plustek ... it is zipped by RAR ... so you will have to download a program from http://uberdownloads.com/7-zipe.html to open it. I have not done this yet ... stumbled on your posting while looking for the same thing so I think the solution to both our problems is in the manual ... good luck
Posted on Sep 04, 2008
SOURCE:
Still looking for plustek optic slim m12 driver for windows 8
Try to install with Win 7 Drivers.
downloads.plustek.com/downloads/english/driver/OpticSlimM12V4301_12L.zip
Dec 24, 2013 | Plustek OpticSlim M12
I have an old (prox 4 year old) Plustek M12 and want to instaal it on my W7 desktop. Can you give me instructions to do it?
Hi!
First you need to download the drivers for your scanner.
Here's a download link for you. Please copy it into your browser's addres bar:
http://plustek.com/oeu/support/drivers-and-downloads.html
In order to find your M12 please use the first option on the site and type M12 into the search box.
Choose your exact model from the 3 (M12, M12 corporate or M12 Plus).
Only the first and the third have drivers for Windows 7.
After choosing the model, you will get acces to download the driver (OpticSlimM12V4301_12L.zip for M12 or OpticSlimM12V4302World.zip for M12 Plus).
Please download and unzip the driver.
Then please run the INSTALL.exe and follow all the steps suggested by the installer.
If it requires a restart please do so.
If you need more details please post again as comment to this.
Hope it helped,
Bogdan
Sep 30, 2011 | Plustek OpticSlim M12
HAVE A REV SCAN 192001 BUT COMPUTER WILL NOT CONNECT TO SCANNER I DO NOT HAVE INSTALLATION DISC
Disconnect the scanner from your computer and go to Plustek's website (http://plustek.com/)
Download the driver that matches the scanner model and the version of Windows you are using.
Double click on the driver file you downloaded and connect the scanner when prompted or when the driver finishes installing.
If this helps please vote for my solution.
Nov 30, 2010 | Plustek OpticPro UT12 Flatbed Scanner
I need a driver to install aborrowed optislim scanner without waiting for the person that gave it to me to get the cd to me
Here is a link to Plustek's drivers and support website, just chose ur model and OS.
http://www.plustek.com/usa/support/download.asp
Hope this solves ur problem and plz dont forget to vote :)
Nov 04, 2009 | Plustek OpticSlim M12
Hp scanjet G2410 not sending email documents to outlook express
scan using Scanner and Camera Wizard
1.From "My Computer" right click the appropriate Brother FAX, MFC or DCP machine.
2.Select Get picture using Scanner Wizard.
3.Click "Next" at the welcome screen.
4.Select the save options that you require and click "Next".
5.The Wizard will now start to scan using the settings you specified.
6. Select the "Nothing. I'm finished working with these pictures" and click "Next".
The images will then be saved to the the location that you specified in step 4.
later you can attach the scanned file to your outlook express.
Sep 03, 2009 | HP Scanjet 4470c Flatbed Scanner
Negatives scan as negatives and not as pictures with the plustek 7300
In the Twain driver for your intellscan, there should be a selection for the type of scan. It should be set to "black & White Negative" or "Color Negative". The program you use to edit the scanned file should be able to change it to a positive if the scanned result is still negative. Programs such as Photoshop, Paint shop Pro etc can use Twain to have the scanner scan directly into them. There the phot (negative) can be edited and saved.
May 30, 2009 | Plustek OpticFilm 7300 Film Scanner
Plustek wont scan
no the problem is check the path u mentioned in the scanner preferences and settings i mean the folder mentioned to store the scanned images after the scan , scanner is given a path to store these images by default check and change that path to other location on hard drive and everything will be ok if the problem persists then update ur driver from plustek website
Feb 24, 2009 | Alestron OpticSlim M12 Path-Through...
Scanner will not scan
Various things[as usual] can affect the performance of a USB device, so check these out. 1.Too many USB device hooked up drawing power from the system - So if it is not in use -unplug it. 2. The driver and or software for the device has corrupted.- Re install 3.Too many programs of a similar nature [graphics in this case] running and confusing resources.- shut down those not in immediate use. Do check the Plustek website for the latest driver[s] A Golden Rule for clean and simple computing is if you are not using it - shut it down. Come back with this one let us all know how it goes.
May 19, 2007 | Alestron OpticBook 3600 Flatbed Scanner
104 people viewed this question
Top Plustek Office Equipment & Supplies Experts
Thomas F. Schneider
Chris Medina
Ekse
Are you a Plustek Office Equipment and Supply Expert? Answer questions, earn points and help others
