Question about Frigidaire FGQ1442ES Gas Dryer
Dryer has power, panel lights come on but dryer will not turn on. Any ideas?
  • Frigidaire Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Apr 06, 2011
WHY IS DRYER TURNING OFF AND 4 LIGHTS ON PANEL FLASH
Good Morning Friend,
I understand your Frigidaire dryer, model# FEQ1442ES, runs for about 10 minutes then turns off. I also see, that when it turns off, all the lights on the front panel are flashing. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 22, 2014 | Frigidaire FEQ1442ES Electric Dryer
Dryer will not turn on - checked power at outlet - it is ok - light does not turn on inside either. There is a light vibration if you plug it in ( if your hand is by the control knob - will a slight...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
heatman101
Nov 21, 2010 | Maytag PYE2300AY Electric Dryer
Last night I dried multiple loads of laundry . . . the dryer worked fine. This morning when I pressed the button to turn it on nothing happened. The control panel is completely blank, as if the dryer is...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Aug 24, 2010 | Kenmore Elite HE4 Electric Dryer
I have no power dryer interior light works but nothing on panel?
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Aug 03, 2010 | Kenmore Elite HE4 Electric Dryer
My inglis dryer don't work as if it's not getting any power.
make sure the bulb is good.the internal wireing needs to be checked for any disconnected plugs or broken wires.you can alos check a small white thermal fuse on the blower wheel housing located behind the rear panel on the left side of the machine.if this is bad you will not have any power to turn the unit on.you can disconnect the two small wires from the fuse and connect them together and then try and start your machine.
Sep 18, 2009 | Dryers
Kenmore dryer model 64602 wont turn on???
Check the thermal fuse on the rear of the dryer.
Remove the rear panel. The thermal fuse is 1 and 1/2 inches long by 1/2 inch wide. White in color and located just left of the dryer exhaust vent. 2 purple wires. Jump the wires together and start the dryer. If it runs, replace the thermal fuse.
May 25, 2009 | Kenmore 73952 Gas Dryer
Maytag dryer sdg515daww stopped working.
I assume this is Gas dryer from the model number having a G.
The door switch may cause the problem. If its not running the dryer thinks the door is open? And the light will also stay off. You can jump around the wires on the door switch and see if it works then if so its switch time.
I don't think a thermal fuse should have anything to do with the light. But that's not a bad idea for quick trouble shooting if a manufacturer would do it. Use a volt meeter to verify the voltage you may have enough for the timer to make noise but not enough to make it turn and the dryer to run.
If there is power then try rotating the tub slightly. The motor may have stuck. Don't turn it too far unless you know which way the drum turns. and try alkways to turn it that direction. Keeps your belts on.
If this helped you please rate me accordingly and good luck.
Mar 13, 2009 | Maytag MDG2706A Gas Dryer
Dryer will not start
Your dryer may not be receiving adequate voltage to start. Make sure your dryer is plugged in. Also, check the circuit breaker panel to make sure all the circuit breakers are in the correct positions. Or check to make sure no fuses in the fuse panel are blown. Try plugging something else into the same outlet. If it won't work either, then there is likely something wrong with the power outlet. Any of these could be the reason power is not getting to your dryer. Also, refrain from using an extension cord to plug your dryer in.
Nov 13, 2008 | Whirlpool GEW9250 Electric Dryer
Maytag Dryer med9700sqo
You have thermal fuses that may have went bad. How long has machine been in use,and is your dryer venting all clear of lint and debris?
Sep 23, 2008 | Maytag Neptune MDE6700A Electric Dryer
Won't Start
do you have the power cord correctly hooked up and have the correct voltage ? is the white wire in the middle? you should have 120 volt with red-white . 120 black- white and 240 black-red... careful with electricity it can hurt and kill you. let me know if you fix this one...krazytech
Sep 16, 2007 | Frigidaire AEQ6000ES Electric Dryer
Frigidaire FGQ1442ES Gas Dryer Logo
201 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
