Question about Uniden Bearcat Pro PC68XL CB Radio
I have a BC350A. It cuts in and out, and won't broadcast instantly, like when new. Powers up ok and will eventually play ok. tried several diff. locations in the house-no help. tried a second ant. -no help.\r\n G. Nickels
    Guru:
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 98 Answers
Try cleaning the knob, it may have dirt in the Volume,Squelch. Spray Tuner cleaner inside knobs (After removing knobs off top, may have to take off cover to do this) Make sure unplugged when cleaning it. Make sure speaker wires soldered good. Change speaker to new one --if possible. Get a outdoor antenna with a Booster for scanners. Try to see if antennuator is on radio..It may be switch that says 0db--10db selector. make sure its on 0db for indoor types...10 db for outdoors. Adjust sqelch until it stops hiss--keep it 2 notches above hiss for weak signals.
Posted on Apr 08, 2011
Testimonial: "Sounds like a workable solution. I'll give it a try,tomorrow. Thanks!"
1994 Mazda PU Truck sometimes won't start if shutoff for 5-10 minutes.. Several tries later, it will start. spark seems ok, it gets enough fuel for a second, but then poops out. fuel pump shuto
Well there is no shutoff relay, but there is a fuel pump relay that powers the pump.
I would check it first. The computer grounds the relay for 3 seconds when you crank the engine to boost fuel pressure. Once the engine starts the pump is powered only if you have oil pressure.
Apr 12, 2013 | Cars & Trucks
Scosche fm transmitter FMTD8 not playing mp3 files on Flash drive
I bought the fmtd8 scosche transmitter. If you're like me ,you tried to play music from you're cell phone first. That worked just fine. Then I made an sd card with a few hundred songs on it. P.S. I left the audio cable plugged in the the transmitter. The sd card with mp3. songs would not play for anything. After 2 days of trying,I finally decided to unplug the audio cable.. Voila!!!!! Instant sound.
Dec 28, 2012 | Car Audio & Video
My ABS and TRAC off light keeps coming on what is happening
You need to have the rear axel differential oil serviced. Metal dust has collected on the speed sensor resulting in loss of speed sensor signal. Damage to Trac Lock friction plates can occur which is very expensive. The diff. lube should have been serviced at 80,000 miles. Check the maintenance schedule in your owners manual for info on miles and intervals
Jun 07, 2017 | 2003 Chrysler Town & Country
I have a rca truflat i can't get the dvd to play
are you sure you have plugs and source input the same.the tv has several diff.inputs look on back what inputs you are using then go in menu move input to the same
Dec 24, 2011 | RCA TruFlat 27F520T 27" TV
Car was rinning perfect. One day it would not start. there was nothing, no clicking ,bell and guages were working. Jump start was nothing. Installed a new battery there was nothing. Went bact back 2 hours...
It sounds like you have an issue with your PassLock security system. I had the same with my 2002 Impala. Key turns OK, but won't start, won't crank. Wait 20-30 minutes, and car starts normally. There is usually a clue from the Battery and Security lights.
The problem starting to happen once a month, and eventually 1-2 times a week.
There are several write-ups on this problem for several GM cars for 2000-2006(?). Search this website, and search the web.
The official solution is to replace the ignition switch. The best solution is to bypass the Pass Lock system. I went ahead and did a full bypass, which involves cutting wires and adding resistors to the ignition circuit. I have not had a problem since.
Aug 19, 2011 | 2004 Chevrolet Impala
My old d-link router works fine. I bought a new DIR-615 but it won't connect. My computer won't "see" it. I followed all directions several times.
Make sure that the broadcast SSID in your router is enabled. Try setting it up again and make sure all necessary settings are set, or it might be the settings in your computer itself, let me know what type of computer you are currently using so i can check.
Jul 03, 2011 | D-Link DIR-615 Wireless Router
The TV is less than 4 months old and problem started after first month. It powers off for anywhere 3 to 8 minutes. Vizio Logo is flashing until it powers up again. Last night it started after 45 minutes...
Take it back where u bought it exchange it for a new tv.This tv have a major issues,with the board that call the tv Tuner signal board.This is the board the take in the incomming broadcasting signal wire plug into this board to produce a picture out of the incomming broadcasting tv signal.
Apr 02, 2011 | Vizio M470NV 47 in. LCD HDTV
NAD C541i CD Player plays but the sound cuts out for an instant every 10-20 secs. It eventually goes away, but it is annoying when you first play a disc. Any help appreciated.
hi, i've had a few nad C541i's and not so long since the sound on one of them cut out for milliseconds and on some occasions the sound would make the noise very much like a severely scratched vinyl record, i thought it was a faulty laser so i tried another KSS-213C laser out of a scrap kenwood and the fault persisted. to cut a long story short, i took the main PCB out and there were various dry joints. once these were resoldered i was blessed with a fully functioning player. hope this helps?
Nov 16, 2008 | NAD C541 CD Player
Have Kenwood CD UD-405 not used for many years. Will not now play CDs or sometimes a few tracks then cuts out stating *NO DISC". Seems fine electronically. Tried switched on for several days to remove...
Seemed to have solved problem by using lens cleaning disc. Had no effect at first but kept trying it and eventually started working. Many cut outs but kept repeating and eventually played without cut outs.
Sep 08, 2008 | Audio Players & Recorders
Uniden Bearcat Pro PC68XL CB Radio Logo
124 people viewed this question
Top Uniden Radio Communications Experts
Jason
Steve
eradiostore
eradiostore
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
