Question about La Pavoni Pub V1 Espresso Machine
I need 120 v 1500 WATT TRIANGULAR FLANGED 2 PRONG HEATING ELEMENT FOR A PUBV1
    President:
  • 1,618 Answers
You can check with Espressopartsnw.com or crossroads espresso(coffeestuff.com) they are the pavoni distributors.
Posted on Apr 14, 2011
I tested my hotwater heater and my heating element ohms read 15.6 / 240 volts do i need to replace the element?
http://waterheatertimer.org/How-to-test-water-heater-element.html
What is wattage rating of element?... printed on end of each element
If element is rated 3500 watt, then 15.6 is ok
4500 watt should be around 12.3
BUT you also have to test element for short to ground, as shown in link above
Gene
Aug 25, 2014 | Water Heaters
Rheem 71 40d
Probably not. The wire and circuit breaker would both have to be upped in size. Then the thermostat's may not handle the extra amps. The higher watt element won't make the water any hotter, but will make the recovery of hot water faster.
Mar 04, 2014 | Water Heaters
Heating element keeps going out
Make sure the water fittings on the top of the water heater are not two dissimilar metals...this causes electrolysis. If you do, you need a dielectric union to connect the two metals ie copper & galvanized steel
Dec 02, 2013 | Eemax Heating Element 240 Volt 9500 Watt
Change a four prong cord to three prong cord, dryer heats, turns but does not dry, vents have been cleaned
test this steps and fix it. God bless you
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Read more: http://www.appliancepartspros.com/repair-help/dryer-repair-help.html#2-2#ixzz2ab3IwDXf
Jul 31, 2013 | Frigidaire FEQ332E Electric Dryer
How do I test the heating elements on Bosch Powerstar AE125 with multimeter
Product manual shows electro-mechanical thermal cutout page 9 but offers no troubleshoot steps except to say that overheating is cause.
http://waterheatertimer.org/pdf/Bosch-AE115-AE125_manual.pdf
http://www.bosch-climate.us/files/201009211859150.EP-23_Removing_and_replacing_element_assembly.pdf
Test elements:
Remove both wires off element.
Set multimeter to read ohms.
Watt and volt rating appear on side of each element.
Ohm = Volts squared divided by wattage.
For example:
Assume 240Volt circuit (240 Volts squared = 57600)
Assume 9000 watt element > check side of element for rating.
So 57600 divided by 9000 watt element = 6.4 ohms
http://waterheatertimer.org/images/ohm-reading-for-emements.jpg
Have you de-limed this unit?
Is there a check valve causing closed system in the plumbing, that might also cause decreased water flow?
Are there reduced-flow faucets or clogged aerators?
What happens when suspect cut-out element is no longer connected? The unit should continue heating.
Sep 25, 2012 | Bosch PowerStar AE125 AE125 Whole House...
Heating element 887013 replace
Question posted under Rheem water heaters
Rheem parts guide does not show that part number with either flanged or screw-in type.
If this is ordinary tank-type electric water heater, copy following link to see step-by-step.
http://waterheatertimer.org/How-to-replace-water-heater-element.html
Otherwise, add a comment or re-post question and include type, brand and model of water heater as shown on product label.
For example Atwood, or Under-counter, solar-assisted, tankless etc.
Sep 01, 2012 | Rheem Water Heaters
My heating element is not working. How can I get a replacement.
I experienced the same problem. My heating element was not working. After a Continuity Test, the Heating Coil was dead and needs replacement. I asked Masterbuilt if any heating coil replacement parts were available. They said "no", but they could offer a discounted sale on a new Smoker for about $175.00. I am still looking. A local appliance dealer said the internet was the most likely place to find one. After looking on the internet, I can't seem to find one yet. If you know of any, please let me know. Call (616) 772-1332 and ask for Bob. Thanks
Jul 10, 2010 | Masterbuilt 20070106 Electric Smoker
Ruud Electric Furnace Cannot Reach Setpoint - "Watt Restrictor"?
unfamiliar with watt restrictors.
heat strips have 2 safety devices, a thermal overload, they get to hot they shut off, cause not enough air flow increase fan speed this device is auto reset. a fusible link a fail safe to thermal over load, no reset and sometimes replaceable. if this does not help would like to ask you a few questions. one of the buildings i take care of has 200 + reem/ ruuds all electric heat. if a part is defective replace, please do not by pass. safety frist.
Mar 02, 2009 | Ruud UBHC Air Conditioner
Transformer 110-220
Less expensive to replace the heating element. But if you already have a 1000 watt transformer then just go that route
Feb 22, 2009 | Coffee Makers & Espresso Machines
Coffee Makers & Espresso Machines Logo
76 people viewed this question
Top La Pavoni Coffee Makers & Espresso Machines Experts
billconfused
Pieter Vleeshouwers
Pieter Vleeshouwers
NOEL
NOEL
Are you a La Pavoni Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
