Question about LG LSC23924 Side by Side Refrigerator
Hi, the freezer door will not stay closed. need to push the last 1/2 inch, sometimes it pops out again that 1/2 inch. nothing in freezer to stop it closing. Door need adjusting?? Greg
  • Gregory Ludlow Apr 06, 2011
    'Hi,
    Fridge seals are perfect,
    Its still looks like something holding it out/pushing it out.
    Have emptyied freezer but still not closing positively
    Greg
  • 4,323 Answers
Hi
If the refrigerator is not properly leveled the doors will not close easily, the front side should be a little bit higher than the rear side. If that's how it is, then the issue is with the hinge lever that seems to have gone bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Posted on Apr 07, 2011
Bottom freezer door will not stay closed.
Check the hinges and the door seal. If you need parts Sears service center online has a great parts locator for kenmore
Feb 18, 2014 | Hardware & Accessories
Freezer Door
There is usually some adjustment on the hinges. Your is termed buttbound, the door at the hinges is too close so it makes the door pop open. Take everything out of the inside door shelves if there are any. Slacken the mounting screws a little and pull the door away from the frame, make sure it sites square and tight, and then tighten up the mounting screws. With a freezer, i would also suggest fully defrosting it first.
Mar 15, 2017 | Refrigerators
When I close my side x side frig the freezer door pops open
This happens because the refrigerators of today are air tight, the fresh food door pushes the air into the cabinet as it closes and the air has no place to go but up the air vent into the freezer and "pops" open the freezer door. First thing is make sure the freezer door is capable of closing properly and is not rubbing or catching anywhere. I sometimes add a washer or 2 to the center hinge under the freezer door so it doesn't rub anything. Put a little Vaseline ( or food grade silicone lubricant ) on the hinge side of the seal. I then raise the front of the refrigerator so that the front of the refrigerator is a little higher than the back of the refrigerator. Never level a fridge with a level. Once you have the door closing properly and front slightly higher than the back...let the fresh food door close from 90 degrees on it's own and the freezer door may "pop" open a little but will close again on it's own...and stay closed once all is set up properly. We see this more often now and have no trouble with the door staying open again after setting up the refrigerator properly.
Oct 17, 2012 | Kenmore Side by Side Refrigerator
The freezer door will not close tight
Hello, check the freezer sliding door rail. Removed everything in your freeze then gently slide out the freezer door. Check the bottom of the freezer for food items that may have dripped into the bottom of the freezer. Now, the check the roller rails along each side of the freezer there could have been widget that got smash by the roller on the freezer door, if you find this smashed widget--he not drunk--he is dead. Scrape the those roller rails and clean the and get all the globs,ice cream, widgets, pieces of other different types of freezer flub.
Next, set a level on the freezer door and see if the bubble is point forward, if not then screw up the front two leveler in the front of the freeze--one on each side in the front of the freezer/refrigerator. I hope this help you. GB...stewbsion
Oct 24, 2011 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
GE Profile freezer door problem
I wil let you know of things you can do to solve this.
Hope this helps, Thanks Sea Breeze
Sep 22, 2009 | Refrigerators
Freezer door pops open
there's nothing wrong w/your dr seal. add a then layer of silcone or vaseline to the seal. this will make it sticky again.
Jul 14, 2009 | Refrigerators
Doors creak loudly when closed and pushed from the outside. Don't when open.
This short solution may help solve your creaking problem. First thing is make sure the freezer door is capable of closing properly and is not rubbing or catching anywhere. I sometimes add a washer or 2 to the center hinge under the freezer door so it doesn't rub anything. Put a little Vaseline ( or food grade silicone lubricant ) on the hinge side of the seal. I then raise the front of the refrigerator so that the front of the refrigerator is a little higher than the back of the refrigerator. Never level a fridge with a level. Once you have the door closing properly and front slightly higher than the back...let the fresh food door close from 90 degrees on it's own and the freezer door may "pop" open a little but will close again on it's own...and stay closed once all is set up properly. We see this more often now and have no trouble with the door staying open again after setting up the refrigerator properly. Putting vaseline insid the hinge pins too is a good idea.
Let me know if I can assist you better, Thanks, Sea Breeze
Apr 27, 2009 | LG LFC21760 Bottom Freezer French Door...
How do you level the kitechenaid side by side
Hope this helps solve your problem, Let me know. Thanks, Sea Breeze
Feb 27, 2009 | KitchenAid (KSRD22FKST) Side by Side...
Freezer door won't stay shut
This indicates that you do not have good airflow and return airflow between your freezer and refrigerator sections. That is why the pressure from closing one door is causing the other one to pop open.
Check the drain tube on the back of the machine to make sure it is not clogged or blocked with frozen water inside. Also check any return air flow vents inside the unit for clear ice.
Jan 18, 2009 | Refrigerators
LG LSC23924 Side by Side Refrigerator Logo
134 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
christian nielsen
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
