Question about Refrigerators
I have a future frost free fride frezzer ff200e and my fridge has stopped working and theres ice on bottom of freezer.i have read that this is a fault on this model and defrosting mite help.how do i clear the tube in the back that should relese the ice
  • Refrigerators Master
  • 43,501 Answers
Check out these tips...they can help you figure out what is going wrong with your refrigerator
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Apr 06, 2011
Hotpoint Future fridge freezer - freezer working well but top of the back of the fridge has a large build up of ice ??? And doesn't appear to be keeping the food cold enough
here are lots of things that can cause cooling problems. One of the most common causes of poor cooling in a frost free refrigerator is a defrost system failure. In such a case one or the other compartment may appear to be keeping proper temperature but that too may change in a short period of time. The fridge compartment's temperature rise is usually (but not always) the first to be noticed. Frost" and "Ice"
There is a difference between "frost" (a white, snow-like substance) and "ice" (usually clear and solid). When referring to what is seen during an inspection, please keep this distinction in mind as the possible causes for each are often very different. The Defrost System
Inspecting the (usually rear) wall of the freezer compartment for a frost build up is necessary. (In the case of many GE top freezer models, check the freezer's bottom panel.) If there is a frost coating on it, it is often a sign of excessive frosting beneath it. Sometimes however the evaporator cover panel will actually need to be removed (see the illustration below) before an excessive frost build will visible.
The refrigeration system's evaporator (cooling) coil is usually in the freezer compartment. This evaporator will periodically frost over and have to be defrosted by means of a heating system. When the defrost heating system fails, the frost can accumulate to such a degree that airflow throughout the appliance is hampered. There may be just enough air circulation to cool the freezer section but that will eventually stop too.
Sep 28, 2016 | Hotpoint Refrigerators
Gss201emdww fride not cold
Check the back freezer wall if there is frost then you have a defrost problem
Dec 23, 2013 | Refrigerators
Ice accumulates on the bottom of the frezzer
if frost free freezer then maybe drain tube plugged up with ice.defrost freezer and restart (unplug till ice melts)or drain hose is dirt plugged
Nov 23, 2011 | Samsung RS2630WW Side by Side Refrigerator
Fridge wasn't cooling but freezer was working, now both aren't
Hi,Your husband did good job, after cleaning and vacuuming, did freezer (bottom) have excessive ice?, if there's excessive ice in bottom, after cleaning, you have a defrost problem, but if there're no ice in freezer after cleaning, you got freon (gas leak) , there's a condensate loop, that passes through ref. body, from compressor that naturally develop, freon leak after few years, by rusting, normally it can be by- pass. vacuum and refill with freon, if there's no freezing, but compressor running, you'll need a mechanic, you got a freon leak. good luck.
Aug 10, 2009 | Amana ABB1927DE Bottom Freezer...
Sheet of ice forms in bottom of freezer
Frost free fidges are supposed to stay frost free because the automatically defrost regularly. When they do this they may drain water down to the bottom of your fridge. Look for a tray that catches this water underneath the unit. Make sure yo keep it emptied. If you live in a very warm climate you may be getting a lot of humidity inside. There may be a switch that you can change for lower moisture.
Jul 01, 2009 | Freezers
Fridge on Zanussi ZX56SI has stopped working but freezer fine
check in your frezzer on the back wall if its all frosted up u have a defrost problem u can unplug and let thaw fgor 4 or 5 hrs plug back in and wilkl work till u can have it serviced if no frost u might a bad fan or a damper control
Mar 18, 2009 | Zanussi ZX56 / 4 Bottom Freezer...
Bosch Frost Free Frdge Freezer Icing Up
Switch off fridge. Put a pedistal fan in front blowing into the cabinet and leave until all ice has defrosted. Locate the drain hole in the back of the freezer compartment, try to defrost ice which blockes up about the first inch or two of this pipe. If water does not run through you need to force it through with a turkey baster. This should sort your problem. ratemeplease
Mar 12, 2009 | Freezers
Frosting & water dripping from freezer in Frost free freezer
Hi, You will find that your problem relates to the defrost heater in the freezer. You will need to take the drawers out and remove the back panel to access the evaporator. There is a foil heater that lays underneath the evaporator and it will need to be changed. Along with the klixon that controls it. This will ensure that both parts are good. Your problem will then be fixed no more water!
Good luck................
Dec 30, 2008 | Freezers
Fridge wont stay cold in the bottom.
Your frost free is not defrosting properly. There should be no ice buildup in the freezer section. Frost in the freezer section stops air circulation to the refrigerator section.
Jun 28, 2008 | GE Refrigerators
Open Questions:
Refrigerators Logo
186 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
