Question about Motorola Two Way Radio
We have two motorola CDM1250 two-way radio installed in the same room .Seem to be getting feedback in one unit when the other unit mic is pressed. it does not happen when the other unit mic is pressed. At this stage have replaced both mic and the unit themselves without any success. Both radio units are programmed on different frequency with a 250khz bandwidth separations
  • Motorola Master
  • 1,654 Answers
You might check your antenna locations, connections, coax and cables. Feedback is sometimes cause by two or more transmitters being too close together (or bad coax/connectors). In the case of mobile radios, this would depend on the location of the external antennas. One radio may be more sensitive than the other, or a PL (private line) code is blocking the interference on the radio which appears to not have a problem. Feedback is caused by RF (radio frequency waves) in the environment. We suggest looking for the leak, and/or repositioning the antennas to be futher apart.
Best regards.
Posted on Apr 08, 2011
Not talking far
Check your antenna set up and connections. Make certain all connections are tight. Have you changed anything about the antenna recently, such as location, or stinger length?
Feb 13, 2014 | Motorola CDM1250 Two Way Radio
Too much feedback
Can you explain your terminology? Feedback or Standing Waves? Typically, Feedback is audio feedback through the speaker and back into the microphone of the CB or out of the external speaker into the mic. It can also be RF Feedback that is caused when the system. If it is audio feedback, it could be that someone has installed a T
"talk back" option and that's why you are getting feedback, if it's audio feedback.
Jun 03, 2013 | Cobra 18 Wx St Ii Mobile Cb Radio
External speaker no function
You have the correct external speaker connected, or a generic?
Some radios require certain external speakers to work properly, and generic speakers aren't always the solution.
Motorola 2-way radios of the model you have, may well come under this bracket.
Other than that, all I can suggest is: join yahoo group specific to your radio Make/Model, and the team there will advise you what's best for your radio, plus you can download manuals, schematics and other goodies for your radio and it's all free.
I hope That this has been of use to you.
Best regards,
Peter
Aug 10, 2012 | Motorola CDM1250 Two Way Radio
My passport 250 goes into protect mode on occasion. The other night at a gig it would clip into protect as soon as I sent a signal from the mic or guitar. It works fine at home. Is the unit sensitive to...
These seem to be tempermental. I would look for radio frequency interference from nearby transmitter leaking into your guitar cable or mic cable that puts this on the ragged edge of feedback. DO NOT boost highs with the EQ... You can get supersonic feedback that you can't hear, but puts the amp into limiting. Any audio input can start the feedback. These amps are VERY hard to work on due to the packaging. A lot of people have smoked their units and then require repairing.
May 24, 2011 | Fender Pd250 Passport Deluxe 250watt...
Cdm1250 ignition on wire radio stays on
I dont understand your question, but ignition wire wich is conected at pin 10 in the accesory connector must be conected to the ignition, fuse is recomended for security reasons but you can use a 1 amp fuse, this line is just a sense to get the radio on or off folowing the ignition
Jan 07, 2010 | Motorola Radio Communications
Motorola maratrac mobile radio A7 control head problems
Hello scooter 34 1,
Are you able to get a new mic for your radio? Because I really think the problem is in the mic. Here is a test buy a cheap replacement mic that can be used with your unit and swap it out with your current mic. 9 time out of 10 this will solve the problem. If not the problem may be with the sensor switch inside of the unit itself, the sensor switch detects when the mic is activated, it avoids the galvanic response of the metallic switch in the mic. The switch could have malfunctioned. However I repeat, that I believe the mic has malfunctioned.
I hope this helps,
Shuttle83
Oct 29, 2008 | Radio Communications
Motorola v3i mic problem
your head unit probably does not have a mic you have to get one for the radio not the phone
May 22, 2008 | Motorola Mobility V551
Motorola VHF radio GM339
Your radio is equivalent to the US version named the CDM1250 or CDM1550. The instruction manual for these radios is available on CD from most Motorola dealers.
Apr 03, 2008 | Radio Communications
Motorola   Two Way Radio Logo
98 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Greg Cann
Greg Cann
SHARCNET-USA
SHARCNET-USA
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
