Front mic port and headphone
Numan 1208B Mid Tower ATX Case front mic and headphone port color code
  • 983 Answers
To connect your front panel header you must refer to your motherboard manual ...
it will given in detail with the pin diagram how to connect ....
check the motherboard compatibility some motherboards dont support working of the back panel header and front panel header at same time especially the old motherboards ....
almost all new motherboard supports working of both the panel headers at the same time if the motherboard supports multi streaming...
thank you
any doubts you can reply me
i am always here to assist you
bye
rate my solution
Posted on Aug 06, 2008
Power button switch
Send a request to the following email address. Mention the exact model number like you did in your question and request a replacement front panel on/off switch. rma@raidmax.com
Nov 19, 2013 | RaidMax AURA ATX-927WB Black SECC Steel...
How do I open the front plate of the Orion 201 tower to replace the 90mm LED case fan?
There are plastic tabs on the inside of the case (near the front) that need to be "popped out" in order to remove the front panel.
Feb 21, 2011 | Azza Orion 201 black/silver SECC Steel ATX...
Hello, I recently purchased all new computer components, including a Diablotek EPIC ATX Mid Tower case. I have the system complete and running. At first I plugged a USB device into the front left USB...
Hi Red,
I had a similar problem on a different case though.They might have similar causes.
The front usb port circuit board was connected to the MB with a ribbon cable. The prior owner had the cable attached backwards. It worked fine, until you plugged in a USB device, instant crash.
Can't say for certain this is what is happening with you, but it is a possibility.
I'm sure you already know, pin 1 is the striped cable. On the board pin 1 has an arrow.
Best regards
Mike
Feb 05, 2011 | Diablotek CPA-802 ATX Mid-Tower Case -...
Azza Orion front fan problem
Put some oil in the fan motor or check if any wires may hitting in the fan while running
Jun 15, 2010 | Azza Orion 201 black/silver SECC Steel ATX...
Front usb ports
Have a computer store look at it they may be able to help you put the wwires in the corect spot.
May 03, 2009 | XG Viper 2 ATX Mid-tower Gaming Case...
Power Up ATX Mid-Tower case TC3j-4032 P Wiring
The front audio in this case does not support HD sound. To get it to work you must instal the "HD Sound Application" that came with your hardware and disable the "Detect Front Panel Jack Detection" option. You'll have to manually switch between the two inputs.
Mar 09, 2009 | Computers & Internet
Don't want to use my headphone, is there a way that i can just use my integrated computer's microphone
Hey,
Yes, sure, in the program you use the mic, you need to change the input or mic setting to the proper input, it debends. But try other inputs untill you find the right one.
Let me know if you need anything else.
Thanks,
Ekse
Feb 22, 2009 | Sky Hawk Computers (PSR5601W-SL) ATX...
Front headphoes and front usb ports
maybe the wire connection of your front panel audio is not connected to your motherboard, try to have it checked by a pc
technician.
Aug 09, 2008 | ASUS Vento 3600 Dream Extreme Gaming ATX...
Front headphone and microphone jack don't work.
Based on what you've submitted, I'm listing a number of solutions which may or may not help. Try the following:
1.) Double-check the color coding on the jack to the port and ensure they match.
2.) Go to Start Menu>>Control Panel>>Sounds and Audio Devices. If it says you have "No Audio Device", then we have a problem.
If it says you have an audio device, tinker with the tabs and settings until your sound output is good.
Please let me know if this helps. If you need further troubleshooting, feel free to ask me directly! Take care.
Aug 07, 2008 | Sky Hawk Computers (PSR5601W-SL) ATX...
Computers & Internet Logo
811 people viewed this question
David Payne
David Payne
