Question about Viper Vehicle Parts & Accessories
The alarm light stay's on but the alarm does not beep or set
  • Viper Master
  • 625 Answers
It sounds like your alarm is in valet. Open any dooor, press lock, unlock, lock. The LED light should go off and you should be able to arm the alarm with the chirps active.
Posted on Apr 13, 2011
Alarm keeps sounding every 2.5 minutes, it works fine on electric, gas and battery and is 12 months old.
Fridge keeps beeping: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.html
May 03, 2015 | Refrigerators
Why does my Hotpoint ff187e frost free fridge freezer lights flash and the alarm sound even after reseting them as per manual. rest them ok for a while but then restart what's the problem?
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Cause of Beeping Noise in Frigidaire Refrigerator eHow
Jul 27, 2014 | Hotpoint Refrigerators
Fridgidaire freezer stop beeping
Good Heather, thank you for your inquiry! If the temperature of food rises to an unsafe level, the buzzer/beeping will sound and the red light, if equipped, will also glow. First, deactivate the alarm to the unit by unplugging it or flipping the household circuit breaker. Wait approximately ten minutes and then turn on the unit. After deactivating the alarm and the unit has run approximately four hours, the red light/alarm should go off on its own. If the red light/alarm continues to stay on, the freezer may possibly have a communication problem with the control board, temperature control or a wiring harness. If this is the case, I would recommend connecting with an experienced technician to determine the underlying cause.
Jul 22, 2013 | Frigidaire Gallery 24.6 Cu. Ft. Chest...
My ignition switch light stays on and alarm does extra beep when set on. I think it a bypass warning. Now the alarm goes off randomly. I had the headliner redone. Do you think I have a short?
if there is a short in the overhead light it can cause issues with the alarm arming, bring it back to the person that did the liner and have them fix the light.
Sep 26, 2012 | Cars & Trucks
I do not know how to set the alarm for my Sangean RCR-1 alarm clock.
Alarm settings can be made with clock/radio on or off.
The Alarm Clock/Radio is equipped with two independent alarm
systems each of which can activate the Human Wake System Buzzer
or turn on a preselected radio station.
Using Alarm with a Preselected Radio Station:
Select desired station using + or - Tuning Button [18] or select one
of the 1-7 presets.
Set the desired volume level using Alarm Level Adjustment [9]
Select alarm system 1 or 2 by pressing the alarm button [14] or [15].
Display will blink with selected alarm
Press alarm set button [16]
Display will blink showing selected alarm hour and alarm mode
and beep
Press alarm Mode button [20] to select alarm mode
Use + or - button [18] to set alarm time hours.
Press set button [16] to set minutes using + or - button to
set minutes.
Press alarm days selections 1-7 (Sunday-Saturday) to select
alarm days.
Display will show the days on which you wish to be awoken by the
radio alarm.
Pressing alarm button 1 or 2 will confirm settings and a beep and
display indicates radio alarm is set.
Note:
If alarm days or alarm mode are not selected display will blink
all the days for a few seconds indicating the alarm is not set
and the alarm will not be activated.
If you would like to be awoken to the station you are presently
listening to press alarm button 1 or 2 for more then 2 seconds.
This allows the station you are listening to be stored into
memory. Then follow above procedures.
Using Alarm with HWS Alarm Beep:
Display will blink with selected alarm Press alarm set button [16]
and beep
set minutes
alarm days.
buzzer humane alarm
display indicates buzzer humane alarm is set.
Note:
Cancelling Alarm Setting:
Alarm functions can be cancelled:
and beep
Press alarm Mode button [20] one or two times (depending if you
were in the alarm radio or alarm buzzer mode) till display blinks.
Press alarm 1 or 2 button again to confirm alarm cancellation.
The symbol will stay on the display for about 2 seconds
and disappear.
You may also select days you wish to be or not to be woken after
pressing the Set button while display is blinking. Press 1-7
(Sunday-Saturday) of button [19] to make a selection.
This is the figure of your device and you can find which button where is:
Thanks.
gylacz
Jun 10, 2011 | Sangean RCR-1 Clock Radio
My explorer when i set the alarm it should only beep once to set the alarm; but sometimes it beeps twice which means the interior lights stays on for awhile. The worst is at night because passerby's can...
the lights are on a timer so they should go off in a minute or two, this is normal, it is for the driver to see and have visuals as well as safety. also to see if criminals are hiding in car upon entering. whats the diff ? when it is light outside for 12 hours they can see in as well. Now if a door on the vehicle is ajar the interior light will not turn off. mine does the same thing but i dont seem to have any problems, If you have a big concern or you think there is a malfunction other than the normal operation of the system before, then you should contact the ford dealer as the tranmitter box may have a malfunction
Jan 16, 2011 | 2003 Ford Explorer
The fridge beeps constantly and then the light goes out. any suggestions?
the light goes out??? are we talking about the interior lights, or dispensor lights???, and whats bl;inking (if any while "beeping") sounds as if perhaps a door/light switch has failed, and in which case the intereior light would stay on for more then 2 min(beeping "open door alarm", and after 2 min for safety reasons the lights turn off as not to "cook the food"
Jan 14, 2009 | KitchenAid (KSRD22FKST) Side by Side...
Vehicle Parts & Accessories Logo
470 people viewed this question
Top Viper Vehicle Parts & Accessories Experts
Kevin Daniels
Tre Elkins
Shehu Pro
Shehu Pro
Are you a Viper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
