Question about Bosch SDS-plus BULLDOG Xtreme Rotary Hammer 11255VSR
Chisel bit will not lock in. still hammers great but falls out constantly.
    Problem Solver:
  • 13 Answers
Are you sure you are locking it in right? The STS locking mechanism on most of these tools is sometimes hard to do, you have to sometimes really push hard while turning it until you hear an audible "click" to know it is seated.
Posted on Apr 06, 2011
The bit doesn't want to release from my dewalt hex demolition hammer
The first ring is pos 88 remove but wait ,! first solvent clean the whole head and the fitting part of the chisel try first before take any operation on the chisel to shift the rubber gasket on the bit with a little screwdriver if its cleanwet before all and then remove pos 88 a locking ring then look good on the parts order of your right powertool diagram setting of your hammer.
If its cleaned and the parts are removed from the
25992752-43ehxo1h3ibdcleqehq3fi4z-2-0.jpglocking sleeve wher the chisel is in place the chisel with whole hammer in a vise and only then if the 2 locking devices out the locking sleeve are removed take a
bench hammer with the point on the front part pos 94 between chisel and hammer sleeve and with a heavy mallet on the bench Hammer the machine from the chisel.
Dec 04, 2015 | Dewalt Hammering
How do I get a drill bit out of the shaft of my rotary hammer drill snapped in it. No bit showing.
unmount the locking rings pins or ball of the toolholder while chisel is inside its possible make the parts short time hot with a burner not to long (where safety glasses ) and leather apron in case of splinters that can come off . spray some wd 40 on the hot part before use a bench vise to set the chisel in with machine on it and the beveled edge of the benchhammer on the front of the tool holder and with a second hammer beat the other site on the benchhammer to work slowly the machine will come off from the chisel. in most cases the drill guide has been worn out from the chuck in case off a cheap rotary hammer it make no sense to do it all. because it has had it working hours on it.
Oct 19, 2015 | Rotary Drills
Can't get bit out of hitachi h65
A vise is a must (do a safety goggles) hard steel on hard steel can deliver hot splinters at this job, put it the chisel with the machine fixed cross in a vice place the chisel lock on the machine open and slam a fist hammer slowly machine of the tool down.
Jun 07, 2014 | Hitachi H45MR 12lb. SDS Max Chipping...
Makita sds max avt --when it is on the chisel only mode it still revolves like in drill mode . What has caused this ?
If the bit turns freely it's possible you have the change ring in the forward position. The HM0860C is a demolition hammer, not a rotary hammer so the bit should not be rotating under power for any reason. On the HM0860C the changing ring on the nose does slide forward to let you choose and lock the chisel bits in 12 different angles. Check to make sure the change ring is in the locked position.
Jun 30, 2012 | Makita HM0860C 11lb Demolition Hammer SDS...
Do all sds drills have chisel function?
The SDS designation relates more to the type of chuck on the tool for the bits than to the tool/drill itself. There are both chisels and drill bits with SDS-Plus and SDS-Max shanks, SDS-Max being the the larger of the two. As far as the tools go: Demolition hammers will only hammer and can only use pointed chisels, scaling chisels, scrapers, etc, not anything like a drill bit that requires spinning to work. Rotary hammers can hammer and rotate the bits. Rotary hammers have a selector switch with two or three positions; one for hammer only for the above demolition bits, one for rotary hammer for use with carbite tipped drill bits, and some have a position for rotation only. The rotary hammer is a more versitile tool but more expensive because of extra workings inside.
Feb 17, 2011 | Garden
Bosh Brute jack hammer It does not hold chisel bits when locked in.
I have a rockworth arpd 1700 breaker and need new points and chisels any idea where i can get them from ive looked every where.
Oct 17, 2010 | Bosch 11304K Brute Breaker Hammer
Stuck chisel
if you have access to a vise I would lock the chisel in it and pull on the release collar and then take a dead blow hammer and "tap" on the drill to try and pull it away from the chisel.
Jun 28, 2010 | Bosch 11265EVS 158 Spline Combination...
Hammer not moving back
Do you mean with a load on it. or without? In other words, while the air hammer is pointed downward, if you put (example, the chisel tip) against a surface to be cut/hammered/etc., it doesn't work? Because, under normal circumstances, it won't work while pointed downward unless the chisel tip is actually against something. If it's doing that under load, though, have you checked the chisel you're using? If the shaft of the chisel is broken or marred, it may not be smoothly traveling the way it should. If it's okay, you likely have a broken piston inside.
Jun 05, 2010 | Chicago Pneumatic Chicagopneumatic Air...
Drill/chisel drops out when useing
if it is the pull-back locking system to hold in the chisel, or drill bit, then the locking- clutch mechanism is worn and needs replaced
Jul 22, 2009 | Makita HR3000C Electric Rotary Hammer
Bosch SDS-plus BULLDOG Xtreme Rotary Hammer 11255VSR Logo
370 people viewed this question
Top Bosch Hammering Experts
John Trevino
snowycreek
Are you a Bosch Hammering Expert? Answer questions, earn points and help others
