Question about Amana Dryers
I have an Amana LE4307W. The problem is the squirrel cage is rubbing against the front cover at one point. What would cause this? How do I fix it?
  • 413 Answers
The drum (squirrel cage) is guided by wheels that have bearings. They are generally located at the bottom of the drum and more than likely you will have to pull the front of the dryer off to see these bearings. they are not very expensive on most older models but are a fair pain to get to. You should probably replace your belt at the same time.
Posted on Apr 08, 2011
Ac squirrel cage fan motor noise
Could be bearings going out, or a squirrel cage rubbing the blower housing, a squirrel cage blade that came loose, or a capacitor.
Jun 12, 2012 | Bryant Heating & Cooling
Take a long time for blower motor to get up to speed
The first thing I would do is to clean motor and squirrel cage. It would be best if you would remove it and take it somewhere that you had a air compressor to blow out motor ports and fins on squirrel cage. Most of the time you can remove by disconnecting modular plugs and removing two or more screws on rail that squirrel cage slids on.
If you can get it out you can use a fine wire brush to loosen dirt and dust from fins on cage then use air to blow out as much as you can.
Your motor may be getting worn so check the bearing by grasping cage and see how much it will slide side to side and if it moves more then about1/8 inch then you are going to need to replace it before much longer. Also make sure that the rim of squirrel cage is not rubbing on blower housing and if it is then loosen motor mounting screws and adjust ,then retighten screws.
I hope this helps you. Thanks
Jan 04, 2011 | Ruud UBHC Air Conditioner
How to remove squirrel cage from motor shaft?
depends on motor most have an allen wrench hole in the side locking the cage to the shaft depending on the size of the cage will determine the size of the allen wrench. You will want to use a green scuff pad to clean the shaft before you remove the squirrel cage and spray WD 40 on it to get it to slide off and on. When installing it be sure to get it back in the same place or you may cause it to rub on something which is a pain to tear it down a second time.
Sep 07, 2010 | Heating & Cooling
When I turn on the A/C or the heater in my my 1995 Regal a sound is made like the fan blades are brushing against something. I believe something fell against the fan. Any idea how to access the fan?
The fan cage(blades) are bad,you will have to replace the squirrel cage,and you may have to buy it as a whole unit to get the squirrel cage.If this was at all helpful,please rate thank you.
Aug 20, 2010 | 1998 Buick Regal
How do I clean a Hawaiian Breeze tower fan?
Unplug fan. Lay the fan face down. Remove the four screws holding the stand to the base. Slide the stand all the way off the cord. Look at bottom of fan and find the small half circle indent just to left of center. There is a screw there, remove it. Go to the hand grip at the top of the back and pry out the two white rubber plugs to reveal two more screws, remove them. Back cover can now slide downward. May take a little squeezing at the center of the grille where internal clip is. Remove two screws at top of squirrel cage. Turn squirrel cage and loosen screw at bottom collar on motor shaft. Tilt the top of the squirrel cage outward slightly and slide upward to remove the squirrel cage. You can slip upper metal bracket off and set aside. Motor is held in by two screws, remove them and flip motor out of the way. There are two screws below where motor sat that hold in base of front grille, remove. Front grille has a series of clips along edges, carefully pry them inward from bottom to top and push grille gently outwards. You can now clean the rear grille, front grille and squirrel cage in warm soapy water and allow to dry. While they are drying, use a vacuum and dust rags to clean interior. When parts are dry, reinstall front grille and reinstall 2 screws. Reinstall motor with two screws. Turn motor shaft so flat notch is pointing up. Recommend to spray a tiny bit of WD-40 or a tiny dab of moly grease on shaft at top of squirrel cage, then replace upper bearing bracket on top shaft. Slide collar end of squirrel cage onto motor shaft and align screw with shaft flat and tighten. Reinstall two screws at bracket at top of squirrel cage. Align back cover just a bit toward bottom, then slide upward and clips will snap into place. Reinstall two screws in hand hold area, then reinstall screw at bottom of cover at half circle notch. You'll need either a magnetic tip screwdriver or a pair of long needle-nosed pliers to get screw in hole before tightening. Feed cord back through base and reinstall 4 screws. It took me about half an hour to do this whole process on each of my two Hawaiian Breeze fans, but they now look brand new and run very quiet.
Aug 05, 2010 | Tower Aloha Breeze Fan
What part makes a clicking noise on the blower
Most GM vehicles have little flaps or doors to redirect the air near the blower motor. If that gets out of place or falls down it will rub on the squirrel cage of the blower fan. Some older cars have insulation in that area that might come loose and rub on the squirrel cage. The insulation sometimes is covered with a stiff paper. Cutting away the stiff paper with allow more clearance.
Jul 14, 2010 | 1998 Chevrolet C1500
Advantium noisy fan
It is probably the external cooling fan that is causing the problem, as this is usually the first one to come on, and the last one one to stop., and usually, these are located at the top of the unit.
Mar 22, 2010 | GE SCB2001FSS Advantium Electric Single...
Noise coming from my blower sounds like something is loose
HI.The blower fan or squirrel cage is rotated by the blower motor shaft, thus, forcing air through the heater core or A/C evaporator core and into the passenger compartment. it is housed in the blower compartment shroud. If the motor shaft becomes unstable, this will cause the cage, or blower wheel, to rub against the shroud, or housing. This will cause the noise you are hearing. The shaft screw may be loose, or the shaft, itself, may be faulty as well.
In most cases, replacing the blower wheel will correct this issue.It would be wise to inspect the blower housing for any loose mounting screws before replacing the wheel.
Nov 18, 2009 | 2005 Pontiac Grand Prix
The squirl cage on the dryer of my model LSE7806
Howdy,
Absolutely should be positively "locked" to the motor shaft. There should be a set screw in the collar of the squirrel cage mount. Either it is missing of has loosened. Please tighten (or replace) this set screw. Also, it is very IMPORTANT to make sure that if there is a flat machined surface on the motor shaft, that you align the squirrel cage (and set screw) so that the set screw will seat firmly and squarely against this flat surface. This design ensures that once properly aligned and set, that the squirrel cage will follow the motor shaft faithfully. Also, it is recommmended to apply some thread sealant (Locktite) to the threads of the set screw so this will not happen in the future. Vibration can be the cause of this.
Good luck,
J
Oct 20, 2009 | Maytag LSE7806A Top Load Stacked...
Dryers Logo
79 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you an Amana Dryer Expert? Answer questions, earn points and help others
