Question about HP Photosmart 2410 All-In-One InkJet Printer
When printing a picture the picture comes out with streaks or lines on it. it just started doing it within the last couple of days. I've reset the print alignment & clean the print cartridges with no aveal
    Guru:
  • 352 Answers
Posted on Apr 06, 2011
Bizhub c200 printing with streaks of red and blue lines what to do
If that lines are consistent with the red and blue and it does not appear during black and white print that means the cleaning blade in the affected color units need to be replaced
May 16, 2014 | Konica Minolta bizhub 250 All-In-One Laser...
Ink streaks
Ink streaks are usually caused by a buildup of died in on the print heads. There are two print heads in that unit. Remove one at a time and look for build up - clean it if you find any. Once you finish cleaning both print heads you will need to do a print head cleaning routine in the HP software to clear out any in clogging the print nozzles.
Oct 01, 2012 | HP Officejet 6500 Wireless All-in-One...
When I print pictures on my kodak g600 easy share printer dock I get faint streaks(lines) on the pictures I have printed.
right click the printer, select properties, and select reset cartridges or print a test page.
Jun 15, 2011 | Office Equipment & Supplies
Laser printer horizontal streaks go away after a few pages
The operating principles behind laser printers are fairly simple. In fact, Brother machines more closely resemble large copiers than conventional laser printers, this is why they are so reliable.
There are a couple of things to look at:
On the drum unit: is the imaging drum worn or scratched? When did you last clean the corona wire?
If the drum is scratched or otherwise with defect it should be replaced. If the corona wire is dirty it can fail to properly charge the drum and lead to print defects.
On the toner cartridge: Does the toner roller have any noticeable lines or banding in the toner?
Behind the toner roller is a "Doctor Blade" that ensures an even and consistent coating of toner. If there are lines in it they can produce print defects as well. Lines would be likely caused by toner accumulation on that blade. If there are lines, are you are careful, you may be able to clean the blade by gently and slowly scrubbing the non adhesive end of a post-it note between the toner roller and the doctor blade where the lines are.
Jan 15, 2010 | Brother HL-2070N Laser Printer
Black lines or smudge marks\running down the prints
Hello sir;The streak line from printing also should be from copy, because the line come from imaging unit, check the meter count if close to or over 50,000 then replace drum and drum blade, it will take care the problem.
The brother printer you need to replace imaging unit( drum unit).
Jun 01, 2009 | Brother Office Equipment & Supplies
Vertical streaks when printing pictures
vertical lines on prints usually means either the drum's cleaning blade is not cleaning the drum (or the drum is damaged) or the fuser is scored. scored means that the protective coating on the fuser rollers is damaged. I would check the rollers on the fuser (the hot part of the printer right near the paper exit) for any lines on it, if you look at your prints, you should see them in the same location on the fuser. if you do not see any lines on the fuser rollers, then replace the drum.
May 24, 2009 | Dell Office Equipment & Supplies
My Olympus P400 Printer comes out with streak on the left side
If a hard reset of printer electronics does not restore proper operation there may be an inherent defect in the unit causing this.
Sep 05, 2017 | Office Equipment & Supplies
Print page on SCX4100- streaking lines
Clearly bad toner cartridge. After long periods of time, the cleaning blade dries out. This cleaning blade works just as the wiper blades of your car. When they wear or dry out, you get streaking water lines in the windshield. Most manufacturers print an expiration date on the consumables wichi you can check before purchasing. Also try not to stock more consumables than those you plan to use within 6 months.
Nov 03, 2008 | Samsung SCX-4100 All-In-One Laser Printer
Pictures taken during the day come out VERY bright, even white
Might be worth flicking through all the settings menus for a few minutes - look in particular to see if you've got it out of Auto into Manual Exposure, or if somebody has accidentally selected a "brighten everything up by a couple of stops" mode. A.
Jun 24, 2007 | Casio EXILIM ZOOM EX-Z60 Digital Camera
My Canon i960 printer is printing red streaks on the pages
It's possible that the heads need to be replaced. That's one disadvantage to the printers that don't have the heads contained within the cartridge.
Feb 26, 2007 | Canon I960 InkJet Photo Printer
HP Photosmart 2410 All-In-One InkJet Printer Logo
85 people viewed this question
Seeker5211
Seeker5211
