Question about Husky Husqvarna Chain Saw 240E w 16in bar
I have a husky 240e saw and i just rebuilt the carburetor and it will crank up and go dead and i pull it a few more times and it will do the same thing so what should i do now and i have blowed it out real good
  • luckypupblue Apr 07, 2011
    i have checked my gaskets and they seem fine but when i take off my fuel line that goes to my carburetor then it shoots gas but it just wont stay primed up i checked the spark on it last night and its fine and it has a new plug
  • 784 Answers
Check all casgets between carburetore and cilinder. if not helping check idle settings. check plug and spark. If not helping is possible faulty crancase sealings!
Posted on Apr 06, 2011
  • Husky Master
  • 2,239 Answers
The 235/240E had major main bearing problems, the bearing cage on the clutch side breaks up and pinches the piston ring in, if the machines has a good spark and clean carb, i would be looking to check the it is mechanically sound, unfortunatley this means a full strip down, let me know if you need more help, i have done very many of these machines.
Just had it serviced and it wont start
Ok, let's test it. We need 3 things for a motor to run. Fuel, spark and air/compression.
This first test you always start with as it will eliminatethe need to test for spark and air.
Spray some carburetor cleaner, gum out, into the plug hole
Reinstall the plug
Spraysome into the carburetoras well.
Now give 2 slow pulls, then pull it as u normally would.
If it starts but only runs for a few seconds, you know it's definitelythe carburetor... if that's the case then it needs to be adjustedwith the adjustment needles on the carburetor, which I can help you with as well.
Let me know how you made out
Brian
Oct 08, 2015 | Husky Husqvarna Chain Saw 240E w 16in bar
Yes that saw does exist..! What is your question regarding it.?
Mar 16, 2014 | Husky Husqvarna Chain Saw 240E w 16in bar
Idle screw husqvarna
Can be located on the carb.! it is on the left hand side of the saw below the primer bulb but above the L/H screws
Mar 08, 2014 | Husky Husqvarna Chain Saw 240E w 16in bar
Won t crank
Sounds like it will crank but just won't start. Almost always a carburetor adjustment if your gasoline is not deteriorated (old).
Pull the spark plug and prime the cylinder with a teaspoon of gas. Try again. If it fires in a few pulls and then won't fire on the next few, your carburetor isn't supplying enough or any gasoline.
Jan 08, 2014 | Garden
I have a 240 husqvarna saw have used 3 tanks of gas now it wont prime
The primer pulls fuel from the metering side of the carb, if there is no fuel here it is because either the fuel filter in the tank is blocked, or the fuel hose is trapped, or the non return valve in the carb itself is stuck, this can happen if the saw has been left with a rich oil mixture left in it.
Jan 20, 2013 | Husky Husqvarna Chain Saw 240E w 16in bar
Even though i have rebuilt the carb on my husqvarna 240e saw its a zama carb and it still isint doing right it will crank up and give it gas and it dies, a person told me that the 2 cycle carburetors have...
It will be set at base settings, you will need to fine tune from there, the mixture screwsrequire a special tool to adjust them part no. 530035560 the screw heads have a star not a screw driver slot, max free running speed should not exceed 12500 +- 500 rpm they are not the easiest machine to tune due to the X Torque cylinder design.
Apr 15, 2011 | Husky Husqvarna Chain Saw 240E w 16in bar
I just rebuilt my zama carburetor on my husqvarna saw and it still doesnt run right and i have blowed out my fuel filter and checked all lines and even tried to adjist the carburetor and it still cranks...
Check there are no kinks in fuel line.
Make sure that the air filter isn't blocked.
Check the throttle cable is operating the throttle plate in the carburettor ok.
Ensure chain isn't too tight.
The carburettor should be a tight fit on the air inlet manifold.
It's possible that some of the jets could be blocked in the carburettor. You can try and clean these with compressed air but ensure you remove any seals gaskets, springs on the diaphragm pump , primer bulb etc as they can be damaged by the pressure.
You can also buy
an aerosol can of starter fluid at your local autoparts store. This is sprayed into the carburettor to clear any partial blockages.
Apr 14, 2011 | Husky Husqvarna Chain Saw 240E w 16in bar
Member Discussion on Husqvarna 240e Chainsaw Idle Adjustment I have a new 240e and cannot keep it running. It will start, after many pulls, and one of two things happens. After running for 30...
Its not an idle screw adjustment issue, it is a mixture screw adjustment issue, unfortunatly there is a special tool to adjust the mixture screws, pt no. 530035560 ( available from Hysqvarna dealers ) once you have this tool you can make an adjustment to the L screw on the carb, undo ( anti clock wise ) this screw ten minutes on a clock face ,this will richen the muxture, and should make it more stable on idle.
Oct 07, 2010 | Husky Husqvarna Chain Saw 240E w 16in bar
Hi there, I got the Husky 240e, with only ~4h of running. my problem is that the chainsaw starts smoothly but when pressing the throttle it is suffocates and turned off. When gently squeezing the...
The symptoms indicate lean running, so check the fuel filter for plugging and the fuel lines for decay or other damage. Husky seems be having troubles with our ethanol treated fuel and may require some warranty attention. We have a year old 435 Husky that would not start after about 3 days of excellent running--warranty replaced the carburetor which seems to have us working well now. Good luck!
Aug 09, 2010 | Husky Husqvarna Chain Saw 240E w 16in bar
Husky Husqvarna Chain Saw 240E w 16in bar Logo
266 people viewed this question
Top Husky Garden Experts
Steve
Ted Maxwell
Andrew Taylor
Andrew Taylor
Are you a Husky Garden Expert? Answer questions, earn points and help others
