Question about Carrier Heating & Cooling
I need a wiring schematic for a carrier heat pump model # 4082030300B0
  • 4 Answers
Contact carrier. Give them the specs and they will send u a electrical schematic
Posted on Apr 06, 2011
Carrier 38tra036 air conditioner
Have you looked on the door of the unit?
Jul 07, 2017 | Carrier Heating & Cooling
What size capacitor in a Carrier Heat Pump 38yh036300
This is a three ton heatpump must likely it is a 35/5uf capacitor. But if you can read compressor tag it will tell you size it requires and also fan label will do some for it.you will need to ask for a dual capacitor from supply house make sure you pay close attention to hoe wires hook up so you can wire in new on before removing wires make sure you have high voltage turned off to unit.take pic with phone this will help when you rewire
Mar 10, 2015 | Carrier 52CQ-312-4 Comfort Series Heat...
Need heat pump wiring diagram for carrier 38yka030300
All Carrier has on this is installation instructions & field wiring. If your heat pump is freezing up, then check your defrost board to see if the timing jumper for checking the freezestat is set to 30,60, or 90 minutes. If it is set to 90, then set it either to 30 or 60 for the board to check the freezestat more often to go into defrost. Then again, the system could be a little low on refrigerant.
Dec 19, 2013 | Refrigerators
Carrier OEM to Honeywell Programmable Tstat - NEED HELP
you likely have a "two stage" system, but not a two stage heat pump. the first stage is probably the heat pump itself, and the second stage is the auxilliary resistance heat that suppliments the heat pump at lower temps. if i knew the terminals that are available on the new stat, i could advise you on the proper wiring.
Jan 27, 2013 | Carrier Heating & Cooling
Where can I find a copy of the schematics for an older model carrier heat pump
Find your closest TOTALINE (Carrier parts dept) and see if they would be kind enough to give you a web link or print it out. You can try the carrier website, parts but I think one has to be registered with carrier to access that information.
May 06, 2009 | Heating & Cooling
I have an older Carrier Heat Pump which I am trying to update the thermostat control with a Hunter model 44550. The problem is that the wiring to the current thermostat is as follows, G= green wire, R=...
JUMPER STAYS BETWEEN RC AND RH SO YOU HAVE INCOMING POWER FOR BOTH COOLING AND HEATING. THE WHITE WIRE YOU SAID C IS COMMON AND SHOULD BE USED IF POSSIBLE TO COMMON TERMINAL ON NEW STAT . IF THERE IS NO COMMON, THEN CAP IT BUT YOU'LL BE CHANGING BATTERIES EVERY FEW YEARS. I LIKE THE STATS WITH A COMMON POWERED OFF THE TRANSFORMER BUT YOURS MAY NOT HAVE A COMMON. THE GREY WIRE CONNECTED TO THE E TERMINAL IS FOR EMERGENCY HEAT. IT KILLS POWER TO THE HEAT PUMP, HEATS THE HOUSE ON IMMEDIATE CALL FOR HEAT WITH JUST THE INDOOR BLOWER AND THE INDOOR HEAT STRIPS. THIS PREVENTS ANY DAMAGE OR INCREASED DAMAGE TO THE COMPRESSOR IF YOU SUSPECT A PROBLEM.YOU SHOULD HAVE A TERMINAL ON THE NEW STAT THAT IS MARKED E OR PERHAPS X2 OR W3. THAT IS WHERE THE GEY WIRE GOES. IT IS POSSIBLE THE WIRE CONNECTED TO W DOES THE SAME THING AND YOU CAN GET BY WITHOUT THE GREY WIRE CONNECTED.ALSO SELECT SINGLE STAGE HEAT PUMP. SINGLE STAGE COOLING AND TWO STAGE HEAT . FIRST STAGE HEAT IS YOUR HEAT PUMP AND SECOND STAGE IS YOU STRIPS.
Oct 26, 2008 | Carrier Heating & Cooling
Old Ruud Air Conditioner
all heat pumps follow the same schematics universal get a hold of any heat pump schem and you should be able to aplie it to yours
Jul 03, 2008 | Ruud UBHC Air Conditioner
Heating & Cooling Logo
161 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
