Question about Vacuums
My dvd player will not play discs that have been released in 2009 to present. It will read DVD/video but won't move from the main screen with the company's logo on it. What should I do?
Hoover carpet cleaner f5915905 the handle release won't lock. what should I do ?
Repairing the Hoover Steam Vac Deluxe - YouTube
? 6:01
https://www.youtube.com/watch?v=QBtWcC4gqjY
Apr 21, 2009 - Uploaded by general0ne
I think Ill make one for the Dual V steam cleaner and provide some tips on maintenance. Good job ... The ...Missing: lock
Dismantling the Hoover Steam Vac Deluxe - YouTube
? 6:16
https://www.youtube.com/watch?v=sul52ULCR90
Jan 12, 2010 - Uploaded by general0ne
Dismantling the Hoover Steam Vac Deluxe. general0ne .... Aftercleaning the screen as shown on the video ...Missing: f5915905 ‎lock
Nov 29, 2015 | Hoover Vacuums
When I am playing a DVD and want to stop it over night, what button do I push on the remote?
You can just press the stop button, but make sure you keep the DVD player on overnight. In the morning just hit play and the movie should resume where you left off.
Jul 28, 2011 | Vacuums
I got a brand new cd/clock radio (above number), and I can't get the cd player to work. Makes a sound, but won't play disc.
Hi! since you've just purchased your unit, it's under WARRANTY period. Please don't touch or try opening the unit. Return the unit where you purchased and tell them exactly your problem. You don't have to pay anything. Bring with you the warranty card and Official Receipt. Thank you.
Jun 14, 2011 | Vacuums
When trying to operate the dvd player it states no read disk when there is a disk in the player
Yes, the DVD player will start with "loading" while it tries to read the disc and figure out what kind of disc it is.
The new-er players will read all sorts of discs, but I have an older one that will only read DVD and MP3 discs.
Any DVD player should be able to load and play an original DVD, but not all will comply if it is a backup copy of your DVD.
If your player refuses to recognize the original DVD, it's time to get rid of it. The cost of repairing it will exceede the cost of a new one.
May 27, 2011 | Vacuums
I bought my dvd player from Malaysia but I am using it in Middle East where I am currently residing. Initially, we are able to play all dvds (which we bought original) but suddenly, it kept popping a...
Are you using WMP or any third party players to play the dvds ?
I suggest you to check if the DVD region code is set to one (US) or not. If not, change it to one.
The region can only be changed five times, before its set permanently.
How do I change my DVD region?
DVD movies are encoded for different world regions, and your DVD-ROM drive must be configured for the appropriate region in order to play the DVD.
If you have DVD-decoder software installed on your computer, you can usually change the DVD region setting in the DVD decoder program. Follow the instructions in the program's Help file for changing the DVD region setting.
If you have a software or a hardware DVD decoder installed on your computer, you can use Device Manager to change the DVD region setting in your DVD-ROM configuration:
1. Click Start, right-click My Computer, and then click Properties.
2. On the Hardware tab, click Device Manager.
3. In the list of devices, double-click DVD/CD-ROM drives, right-click the DVD drive for which you want to change region settings, and then click Properties.
4. On the DVD Region tab, make the desired changes.
You must be logged on as an administrator or be a member of the Administrators group in order to change the DVD region.
Note that the DVD region for most DVD-ROMs can only be changed up to five times, and the number of changes still available is located on the DVD Region tab. If the tab shows that you can only change the setting one more time (Changes remaining = 1), you won't be able to play DVDs that use a DVD region that is different from your last selection. If you run out of opportunities to change the setting (Changes remaining = 0), contact your DVD-ROM's manufacturer to reset this value.
Also install DVD decoder as an issue with codec or DVD decoder could even cause the issue with DVD region code.
http://www.microsoft.com/windows/windowsmedia/player/plugins.aspx (Also applies to Windows 7)
Mar 26, 2011 | Vacuums
Have LG dvd player. When i insert any dvd it does not hold the dvd and opens immediately, however it does not keep opening when power on. I open the cover to obser the problem, i found that when dvd is...
Dear Friend,
All DVD / optical media player operates on LASER beam. When you insert media ( disc) it will try to "Sence" media by switching on the LASER beam. Beam will be reflected from the media and give information about its type and size.
If there is some dirt ( generally dust) LASER beam will become weak and may not provide enough information to the player so it may not rotate.
What you have to do is switch of the player and unplug it. Clean Lens of the LASER pickup with a swab of fine cotton or use lens cleaner CD.
After some time. Restart the system and you will find working normally.
If there is no result, take the system to good technician.
I hope this is useful to you.
Thank you for visiting FixYa.
Dec 24, 2010 | Vacuums
I set up my ONYX SW2300XS which I recieved as a gift (so no reciept) for the first time today. At first it was working well, I inserted a dvd and it played well. I played with the zoom and the skip...
Solution: Return it back!
I had other problems and decided return it.
At first it looks so good: HDMI, SD...inputs and so on.
But operation completly screwd up.
It is a SHAME !
Ed
Nov 16, 2010 | Vacuums
How to take protect mode off HT-TZ212 samsung dvd player
The protect mode as it means is the safety cut off due to a possible error or shortin in the DVD.
You must have to identify the fault before we can conclude on the position of the fault.
So start from the power supply chek votages, if the main voltages are present. Remove leads to the DVD drive and check, if OK then the drive section is faulty. But fault can vary from the AV section to the decorder stage and to the drive.
The microprocessor control is however working as it indicates the fault.
So proceed by elimination
Sep 08, 2010 | Vacuums
Vacuums Logo
22 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
