I have a reznor uh150lg and i need a wiring diagram all the power goes into one box and should all blacks be tyed togather or should some be separated
  • 4 Answers
What box are u talking about? The junction box or wiring connections @ the unit. If u are not electrically familiar with the unit. Call someone who is qualified. Fooing around with electrical components and wiring them wrong could cause more damage. Systems work on several different voltages and not knowing what to do could damade your controlS or transformer.
Posted on Apr 06, 2011
I need to know how to put these wires back togather on my 1965 Ford Deseial Tractor
this is a difficult request but generally if the wire have been cut the wires of the same color will be able to be rejoined ok
so any red wires are generally power wires so connect to red wires and black are earth wires so connect black to black and so on
you local ford tractor service dealer may have a schematic for the wires in an old manual
a judicial use of a multimeter is also a good idea
try -going google and typing in-- wiring schematic wiring diagram for --- your make and model of machine and see if there is a pdf version available
Aug 10, 2015 | Ford Cars & Trucks
Replacing motor on my ruud furance
you should have a wiring diagram on the top of the motor to tell you what each wire does. compare both motors and see where the wiring goes.
Nov 08, 2014 | Heating & Cooling
My chevy 1500 will not start i saw smoke on passengers side took off the box under the hood and there was a black wire that went to a red wire it was burent in half put them back togather than burnt i
That wire was probably a fuseable link which is a wire that acts like a fuse.
You may have to trace the wiring to find the short and you may need a shop manual to get all of the diagrams.
It could be a short in the alternator or a long list of other things.
Sep 25, 2012 | 1991 Chevrolet C/K 2500
4 lamp t5 fixture, 1 black wire, 1 white wire, 1 red wire. how do I wire this
Don't forget this is a 240v appliance so it must be fed from a 240v circuit breaker. Once you have a 240v circuit breaker you need to run 12/3 wire with ground from circuit breaker to a box near your fixture. The 12/3 wire with ground will have; 1 black, 1 white, 1 red and a bare ground wire. With the circuit breaker OFF, hook the wires up respectively to the same colors and ground the bare wires togather with a green ground screw in the box. Turn circuit breaker on.
Nov 25, 2010 | Solar Flare Vho T5 4ft 8 Lamp Fluoro Grow...
10-3 w/ ground wiring diagram
your 2 hots phase wires RED and BLACK need to go to the L1 and L2 terminals,the white goes to the "N" neutral terminal and green or green w/yellow stripe is case safety ground---now at the breaker the RED/BLACK are connected under each one of two screws on the breaker the white goes to the NEUTRAL BUS BAR on the palel surface where all the white wires are already, also the green goes to the neutral bus bar,this only applies if this is the MAIN house power panel, is you wire it to a sub box panel then the neutral must be isolated from the sub panel chassis and ground can still be connected to panels case
Oct 04, 2009 | Dryers
How to wire 3 switches in a 3 gang box
WARNING: Do not attempt to do this work unless you completely understand the information provided below. If in doubt call an electrician.
Always make sure the power is disconnected from all possible sources before making any connections. Your description of the problem indicates that there may be multiple power wires coming into the same box. In that case local codes may require that the box be partitioned to prevent exposure to voltages up to 220 volts.
You need to determine where each wire goes to know how to connect them together. You cannot rely on color alone. If the power supply runs through the box to the loads then most (but probably not all) of the white wires will be connected together. If the power runs to the load boxes first then none of the white wires in the switch box should be connected together. They are used to run the switched/dimmed power back to the loads (and should be taped to cover the white in the box). In that case each switch has its own power input and they should not be tied together. A wire (could be black or white with black tape) brings power from the load box, gets connected to the input terminal of the switch and the corresponding black wire carries the switched power back to the load. The fan/light switch will have one power in and a switched power out for the fan and another for the light. The 3-way will have one "power" in (or it could be the final power out to the light) and two "carrier wires that connect to the other 3-way switch. If the power supply goes through the switch box then there will be at least 10 wires in that box. In that case see the attached diagram: a5fa64a.gif
Sep 23, 2009 | Cooper Industries Cooper Wiring 2158V 3...
I need the wiring diagram of pump it has 5 pins coming out of pump
hello, i holding a wiring diagram central locking system,model 201,it have a 6 pin,
  • pin no.1 brown goes to ground
  • pin .no 2 black ignition on
  • pin no. 3 red permanent 12 volt
  • pin no. 1 yellow trunk lid switch
  • pin no. 2 blue driver door switch
  • pin no.3 green passenger door switch
hoping it"s help to solve your problem,ty
Apr 28, 2009 | Mercedes-Benz 190-Class Cars & Trucks
Heating & Cooling Logo
80 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
