Step by step on how to format using windows 2000....ty:-)
    Scholar:
  • 95 Answers
1. Turn on the computer and insert your windows 2000 operating system disk.
2. Restart the computer, and follow the instructions to boot from a disk
a. You may have to go into the bios set up and set your boot device to the CD drive depending on
your motherboard
3. Once you have successfully booted from the CD drive, Windows will run some set up files, be patient.
4. When it is finished, the partitions that are currently installed on the hard drive are listed. Highlight each one and hit 'L' to delete.
5. Once all partitions are deleted, and you are back to the list, hit 'C' to create a new partition.
6. It will give you a formatting option for a quick or a full format. I would choose full.
7. Let it run for about an hour and come back to the windows 2000 set up screen.
8. Follow the instructions to set up windows 2000
9. Be happy
Posted on Apr 06, 2011
How would i go about formatting a computer?
How to Format a Computer
Want to know how to format a computer hard drive?Need to learn how to format your computer and start with a clean slate? Formatting a disk prepares the surface of the drive to accept and store data. Computers are often formatted before they are sold, donated, or returned to an employer. Likewise, computers with viruses or errors can be formatted and returned to their "out of the box" settings.
Warning - Formatting hard drive information does not permanently erase the data. Even after a computer has been formatted, deleted files can be easily recovered. If you want to permanently wipe your hard drive by completely overwritting hard drive data, check out WipeDrive.
How to Format Computer Quick Links:
How to Format a Computer with Windows XP
How to Format a Computer with Windows 95, 98, & ME
Wipe All Data Before Formatting
Reinstall Windows XP
Reinstall Windows 95, 98, & ME
Create a Startup Disk
The first step in learning how to format a computer with Windows XP or 2000, is to insert Windows CD and restart your computer.
Your computer should automatically boot from the CD to the Windows Setup Main Menu.
At the Welcome to Setup page, press ENTER.
Press F8 to accept the Windows XP Licensing Agreement.
If an existing Windows XP installation is detected, you are prompted to repair it. To bypass the repair, press ESC.
Use the ARROW keys to select the partition or the unpartitioned space where you want to create a new partition. Press D to delete an existing partition, or press C to create a new partition.
Type the size in megabytes (MB) that you want to use for the new partition, and then press ENTER, or just press ENTER to create the partition with the maximum size.
Select the format option that you want to use for the partition (Recommended: NTFS), and then press ENTER.
After the Windows Setup program formats the partition, follow the instructions that appear on the screen to continue installing Windows.
How to Format a Computer with Windows 95, 98, or ME
To reinstall Windows, you will need a Startup Diskette and a Windows Installation CD.
Download the Startup Diskette Creator
Note: We recommend using the Startup Diskette available on this page. Other Windows Startup Diskettes may not work with the following steps.
Once you have your Startup Diskette, insert it into the floppy drive and restart your computer.
Select option #1 - Start the computer with CD-ROM support.
After a minute or so, you will see "A:>_".
Type "fdisk" and press Enter.
If asked to enable large disk support, select Y for Yes. (Note: Some versions of Windows 95 may not be compatible with large disk support. Select N here if it does not support the FAT32 file system.)
Select Option #1 - Create DOS partition or Logical DOS Drive.
Select Option #1 - Create Primary DOS Partition.
The drive integrity will be verified.
Unless you are planning to make multiple partitions, select Y when asked if you want to use the maximum available size for the partition and to make the partition active.
The drive integrity will be verified again.
When completed press the Esc key to exit fdisk.
Without removing the floppy disk, press the reset button on the computer or press the keys Ctrl then Alt then Delete and release them together. This will restart the computer.
Again, select the option to Start the computer with CD-ROM support.
When you see A:>, directly above it is a message about your CD-ROM drive. It will tell you the letter assigned to your CD-ROM drive, take note of it.
At the A:>, type "format C:" and press Enter.
Press the Y key then the enter key when asked if you want to proceed with the format.
The format will probably take some time, so be patient.
You will be asked to choose a Volume Label, which is a name for your hard drive. It has no effect on the operation of your computer, you may choose any name you like.
How to Reinstall Windows XP
To reinstall Windows XP or 2000, imply insert Windows CD and restart your computer.
If your hard drive has not been formatted, Windows XP will walk you through the formatting process described above
Your computer will automatically boot from the CD and begin the installation process
How to Reinstall Windows 95, 98, or ME
After formatting your hard drive as described above, insert the Startup Diskette into the floppy drive and restart your computer.
Place the Windows Install CD into the CD-ROM drive.
Type "E:" (where E is the letter assigned to the CD-ROM drive) and press the Enter key.
Type "dir" and press Enter. You will see something like the following:
Volume in drive E is 020409_1121
Direct
Dec 15, 2011 | ASUS Computers & Internet
Tip
How to format a computer with windows xp.
<span> <ol> <li>The first step in learning how to format a computer with Windows XP or 2000, is to insert Windows CD and restart your computer.<br /><br /></li> <li>Your computer should automatically boot from the CD to the Windows Setup Main Menu.<br /><br /></li> <li>At the Welcome to Setup page, press ENTER.<br /><br /></li> <li>Press F8 to accept the Windows XP Licensing Agreement.<br /><br /></li> <li>If an existing Windows XP installation is detected, you are prompted to repair it. To bypass the repair, press ESC.<br /><br /></li> <li>Use the ARROW keys to select the partition or the unpartitioned space where you want to create a new partition. Press D to delete an existing partition, or press C to create a new partition.<br /><br /></li> <li>Type the size in megabytes (MB) that you want to use for the new partition, and then press ENTER, or just press ENTER to create the partition with the maximum size.<br /><br /></li> <li>Select the format option that you want to use for the partition (Recommended: NTFS), and then press ENTER.<br /><br /></li> <li>After the Windows Setup program formats the partition, follow the instructions that appear on the screen to continue installing Windows.<br /></li></ol></span>
on Nov 23, 2010 | Computers & Internet
Tip
Thanks,
Bhautesh.
on Mar 03, 2010 | Computers & Internet
I have an E-Machine desktop PC that is failing to boot. It is running on windows 2000. When it starts booting, it says that one of the files needed for booting is missing. It further tells me to run a...
Windows 2000mag-glass_10x10.gif boot disks allow you to by-pass damaged Windows 2000 operating system files to get your computer up and running in a solid, stable configuration. You simply tell the computer to access the Windows 2000 codes necessary for start-up from your floppy disk drive rather than the hard drive. Creating the set of four boot disks is specific to this version of the operating system
  1. Step 1 Insert the Windows 2000 Professional CD into your computer's CD-ROM drive. Insert a formatted, blank diskette into the floppy disk drive. Have three additional formatted, blank diskettes standing by.
  2. Step 2 Click "Start" at the bottom left corner of your computer screen to open the start-up menu. This lists the start-up actions available for Windows 2000. Select "Run." The program then asks you to designate the drive, program, folder or file you want to open by either typing the destination or clicking "Browse," to select the destination from the Windows 2000 directory.
  3. Step 3 Click the "Browse" button at the bottom of the pop-up window. The PC's hard drivemag-glass_10x10.gif directory window appears.
  4. Step 4 Browse the computer's hard drive directory and select the CD-ROM drive to designate it as the destination you want to open. Click "OK" to open the CD-Rom drive. The folders and files saved on the Windows 2000 CD now appear in the directory format.
  5. Step 5 Select the "Bootdisk" folder. A directory of files appears.
  6. Step 6 Double-click the program file "Makeboot.exe," then click "OK" to launch the Windows 2000 boot disk maker program. The program checks that you have a formatted diskette in the floppy disk drive and then begins to make the boot disk.
  7. Step 7 Watch your screen as the process of making the boot disk progresses. The boot disk for Windows 2000 requires four diskettes. The program cues you to remove the first diskette and insert the second, and so on until all four diskettes are created and the boot disk making process is finished.
Nov 15, 2009 | E-Machines eMachines Desktop PC
How do i format my packard bell easynote
Hello
  1. Step 1 Ensure that the hard disk is installed properly in the laptop. The drive cannot be formatted before it is installed, or if it's not installed correctly.
  2. Step 2 Gather the required software. The type of media will depend on the hardware in your laptop. Older computers without a CD-ROM drive, will require the use of the operating systemmag-glass_10x10.gif floppy disks. Laptops that can run Windows XP require the installation CD and product key. Older versions of Windows also have disk-formatting capability in the installation process, and the installation media is either a CD or floppy disk.
  3. Step 3 Place the installation disk or manufacturer software in the drive and then boot the computer. Early in the installation process, the Windows installer has a step that will detect any installed hard disks and allow for them to be formatted. The software from the disk manufacturer will also detect the hard disk and give you the option to format the drive.
  4. Step 4 Determine which file system is to be used. Windows XPmag-glass_10x10.gif will either work on a NTFS file system or an older VFAT file system. Choose the desired file system when prompted.
  5. Step 5 Decide whether the whole disk should be formatted or if the disk will be partitioned and each partition to be formatted separately. The Windows installer includes a menu-driven utility that will create hard disk partitions before formatting. If the hard disk is being formatted to replace an existing Windows installation, delete the existing partitions and re-create them.
  6. Step 6 Format the hard disk with the Windows installer when prompted. The Windows installer will let you know when it is time to format the disk and ask for confirmation.
  7. Hope this can help you, kind regards, andrea
Nov 13, 2009 | Computers & Internet
How to reformat windows 2000
Do you have everything backed up? Are you absolutely sure, there's no going back?
If you are sure, then go to this webpage, scroll down half way where it says, "Steps to Clean Install XP"
http://www.michaelstevenstech.com/cleanxpinstall.html
Oct 03, 2009 | Microsoft Windows 2000 Professional for PC
Stepbystep procedure for formating
Hello jerapur_123 What you'll need:
  • Recovery CD or Restore CD from the MFG
  • WIndows Operating Disk 98 or ME, 2000, XP or Vista.
  • A CD Rom Drive
  • Or a Floppy for low level formatting.
Key Steps to Formatting
Back it Up!
Before the format process, you want to make sure that if your goal is hard drive recovery, you back-up as much personal data and information from your hard drive as you need. In some instances where a virus has caused serious system damage, this may not be possible, but if your format is planned ahead of time you certainly can copy and archive data off your hard drive before you start the format process.
How to Format
If you purchased your computer from systems vendor such as a Dell, HP Compaq or Gateway system, you most likely will have a set-up or a restore-and-recovery CD (also referred to as a master CD) that came with the system. If this is the type of system you use, then a format is an easy process as the master CD by inserting the CD into your CDROM, will format the hard drive, reinstall your Windows operating system, and install any software and programs that came with the system. If you no longer have your master set-up CD, you should contact the manufacturer to get a replacement.
How to Format without a Recovery Disk:
If you aren't using this type of mass-market system, then a hard drive format will consist of you formatting the hard drive manually, installing your Windows OS from CD, then installing your software programs and hardware drivers. Before you begin the formatting process, it is important to make sure you have all your driver CDs located, Windows CD and your software CDs to ensure a smooth set-up.
It's also important to know about your operating system before you format. For example, if you're going to be reinstalling an older version of the operating such as Windows 98 or Windows ME then you should have a Windows 98 or ME start-up disk to complete the procedure. In this instance, you would restart the system with the start-up floppy in the drive. Upon system boot, you will choose to have CD-ROM support. Once the files load you can then choose to run the format command on your main drive (usually C drive). If you are using Windows 2000, Windows XP or Windows Vista the Windows installation process offers "format your hard drive" as an option. Here you would ensure your computer is set to boot from CD-ROM (a setting in your system BIOS), insert the Windows CD and restart the computer. From there you will be on your way to reformatting.
As you can see there are many options to formatting a hard drive. Hopefully this gives you a good understanding that most of the operating systems today do the formatting for you, all you need to do is pick that option as you follow the onscreen steps when you install either your Restore, or Operating System.
Good Luck,
Mark
Please don't forget to leave a rating.
Feb 18, 2009 | HP Computers & Internet
DOES THE VERBATIM HARD DRIVE NEED TO BE FORMATED?
Many Verbatim hard drive models with a FireWire interface come “Mac formatted” – pre-formatted for immediate use with Apple Macintosh computers running Mac OS. They are formatted as HFS+, the preferred format when using the drive exclusively with Mac OS computers.
Note: A Mac-formatted drive will not mount on a Windows PC.
If you plan to use a Mac-formatted hard drive only with computers running Mac OS, you can leave it formatted as it comes from the factory. However, if you plan to use your hard drive with computers running Windows, or with both Mac OS and Windows computers, you should reformat your Verbatim hard drive before saving data to it. Generally, for use with both Mac OS and Windows you should format to FAT32, and for use strictly with Windows you should format to NTFS. More information about these two format types is given below.
FAT32 FAT32 is compatible with the following Windows operating systems: Windows 98, Windows 98 SE, Windows Me, Windows 2000, Windows XP, Windows Vista. FAT32 can also be read by Apple Macintosh computers running Mac OS.
Limitations: Maximum file size is limited to 4TB. Furthermore, using the formatting tools included with Windows 2000, Windows XP, and Windows Vista users will not be able to create partition sizes larger than 32GB (though they can access these larger partitions). This limitation does not apply to other supported operating systems. Furthermore, Verbatim provides a FAT32 format utility (see further below for download instructions) that eliminates the 32GB partition limitation.
FAT32 is a good choice if you’ll be using your Verbatim hard drive with older computers running Windows 98, Windows 98 SE, or Windows Me, or if you’ll be using it with both Windows and Mac OS computers.
NTFS NTFS is compatible with the following Windows operating systems: Windows NT, Windows 2000, Windows XP and Windows Vista. NTFS usually results in higher performance than FAT32, and will permit users to create partition sizes larger than 32GB, and file sizes larger than 4TB.
Limitations: NTFS is not compatible with Windows 98, Windows 98 SE, Windows Me, or Apple Macintosh computers running Mac OS.
NTFS is a good choice if you will be using your Verbatim hard drive only with one or more computers running Windows XP, Windows 2000 or Windows Vista. This is also a good choice if you plan to store files larger than 4TB, such as digital video files.
Per: http://www.verbatim.com/downloads/format.cfm
Good Luck
cbinny1
Oct 20, 2008 | SimpleTech SimpleDrive Portable USB 2.0...
Hard drives not detected
you should repartition your hdd. using disk manager, 1st step. do zero level, then low format. after doing those step. make partition and install your os. good luck
Sep 08, 2007 | Microsoft Windows XP Professional With...
Before installing Windows XP Upgrade
In order to update your system from the current Windows operating system to Windows XP Home, there are several steps that need to be taken prior to upgrading. Please follow the items listed below in order to prepare for Windows XP. Uninstall Trend PC-cillin2000 Click the Start button located on the Windows taskbar. Choose Control Panel, highlight Settings and select Control Panel. Double-click the Add/Remove Programs icon. Click install/Uninstall tab, select "Trend PC-cillin 2000". Click the Add/Remove button to uninstall "Trend PC-cillin 2000". Uninstall NTI CD-Maker 2000* Click the Start button located on the Windows taskbar. Choose Control Panel, highlight Settings and select Control Panel. Double-click the Add/Remove Programs icon. Click the Install/Uninstall tab, select "NTI CD-Maker 2000". Click the Add/Remove button to uninstall "NTI CD-Maker 2000". Uninstall Intel LANDesk Client Manager* Click the Start button located on the Windows taskbar. Choose Control Panel, highlight Settings and select Control Panel. Double-click the Add/Remove Programs icon. Click the install/Uninstall tab, select "Intel LANDesk Client Manager 6". Click the Add/Remove button to uninstall "Intel LANDesk Client Manager". Uninstall PowerDVD* Click the Start button located on the Windows taskbar. Choose Control Panel, highlight Settings and select Control Panel. Double-click the Add/Remove Programs icon. Click the install/Uninstall tab, select "PowerDVD". Click the Add/Remove button to uninstall "PowerDVD". * This software is optional. If this software is not installed previously, please skip the step.
Sep 11, 2005 | Acer n10 Pocket PC
Computers & Internet Logo
50 people viewed this question
David Payne
David Payne
