Question about IBM ThinkPad T23 2647 Notebook
I can't get my IBM ThinkPd out of sleep mode. (I'm using another computer right now.) I tried taking the battery out and unplugging it for 20 minutes, pressing power button, holding power button down, pressing Fn, F8, F4, F12...I can't even get a light or a fan noise. Can you help me? Thank you!
  • 73 Answers
It sounds like a failed motherboard, If it was stuck in sleep mode the computer would still turn on.
try leaving the battery removed plug in the laptop and see if it turns on, if not it sounds like a bad component on the motherboard.
Posted on Apr 06, 2011
Prostart 6 button in sleep mode
Sleep mode is a convenient power-saving feature used on both laptops and desktop computers. This feature powers down hard disks, monitors, wireless devices and any other power-consuming peripherals without turning the unit completely off and necessitating a reboot. Sleep mode can prevent battery drain if using a laptop or mobile device while away from the power supply. This mode is useful when quick access to a computer is needed, but can be irritating if the sleep mode takes a long time to come back from. It is simple to turn sleep mode off, based on the operating system being used.
Go to the "Start" button, then click on "Control Panel." In the control panel screen, click "System and Maintenance," then click on "Power Options." This brings you to the "Select a power plan" page. From the "Select a power plan" page, select the option that says "Change plan settings." This changes the settings on the currently selected plan. Select the "Change advanced power settings" option. Click "Sleep" and then click on "Sleep After" to expand it. If using a laptop or mobile PC, click "On battery" and "Plugged in," then select the "Never" option. This turns off sleep mode for both battery and AC use. If you are using a desktop computer, click "Setting," click the arrow and then click "Never" to turn off sleep mode. Click "OK," then click "Save changes" to save the modification. b> Turning Off Sleep Mode - Mac OS b> Click on the Apple logo at the upper left corner of the screen to open the menu and select the "System Preferences" option. From the "System Preferences" screen, click on "Energy Saver." If you are using a desktop, select "Power Adapter" in the top drop-down menu. In the second drop-down menu, select "Custom." Highlight the "Sleep" tab, then adjust the top slider to the far right, marked "Never." I f you wish the display to stay on, adjust the bottom slider to "Never." Click the red button on the upper left side of the "Energy Saver" screen. If you are using a mobile product or laptop, follow step 2 and select "Battery" from the top drop-down menu. Repeat step 3 to change the settings for battery use. Hope this helps.
Jan 09, 2013 | Computers & Internet
My dell Studio laptop takes too long to wake from sleep mode and the monitor just flickers when i try to switch on
If you use Windows 7, u might have hybrid sleep activated. This is similar to hibernate. When u choose SLEEP, your computer goes to hibernate. Sometimes this hibernate just hangs. You have to reboot computer.
Try pressing the power button for several seconds (10-15). It should power off the laptop.
If not, unplug the charger and remove the battery for a few minutes. Then try to start it up again.
May 13, 2011 | Dell Studio 1537 Laptop
I put my acer aspire in sleep mode and now it doesnt turn on
Hi marvmom,
Have you tried draining the power of your computer? The easiest way to resolve this issue is by performing a power drain. Please follow the steps below.
1. Turn of your computer completely by pressing the power button for about 10 seconds.
2. Now, unplug the AC adapter from the power outlet.
3. Remove the battery from the system.
4. Press the power button for at least 15-20 seconds.
5. Put the battery back inside the system and plug the AC adapter.
6. Try to reboot and observe the computer.
Hope it helps.
Thank you for using FixYa.
May 11, 2011 | Acer Aspire One PC Notebook
HP Pavillion a6230n Desktop PC sleeping mode is not working properly. After it entered into Sleep mode, it will keep waking up as long as the Internet cable is plugged in. Any other computer can sleep...
Click on Start, Control Panel, Network Connections, Right click on local area connection that is connected and click properties
Under networking tab, click configure. New window opens, then click on last tab power management, take check mark out of "Allow this device to wake the computer" then click "OK"
Nov 30, 2010 | HP PAVILION A6230N DESKTOP PC
My averatec lap top os stuck in sleep mode
Hi. I suggest you try pressing the power button to wake it up or you could also try power draining it and turting it on. To powerdrain your computer you must remove first the battery and unplug the ac adapter then press and hold the power button for 20 seconds, after that you must place back the battery and plugin the ac adapter then turn on your computer. Hope This Helps
Jun 02, 2010 | Toshiba Satellite M100 Notebook
Doesnt come out of sleep mode
It could be the problem with graphics drivers. remove it and reinstall it.
Also cross check the Power Options under control panel.
Aug 04, 2009 | IBM ThinkPad R30 2656 Notebook
Computer was in hibernate or sleep mode when the battery drained. Now, will not boot, appears to come out of sleep mode but only shows TOSHIBA splash screen and the hard drive lights do not activate. F8...
Dear! take display properties use tab ans select screen saver then click on power and use tab again select hibernate if it is enable check again it and disable now. After that your computer will not go in sleep or hibernate mode.
Thank You
Jul 26, 2009 | Toshiba Satellite M100 Notebook
Computer not sleeping in sleep mode.
One possibility is if you have an optical/laser mouse that is on a relective surface and the mouse light is reflecting and triggering the computer to think that there is activity.
More than likely, your network card is keeping your computer from staying in sleep mode as any internet data activity is taking the computer out of sleep mode making the computer think there is activity.
There is an option in the Network Adapter properties that says to "Allow this device to wake up your computer"
Go to Control Panel and click Classic View on the left hand side
Double Click the Network and Sharing Centre Icon.
On the left hand side of the window that opens, click Manage Network Connections.
Right Click on the connected Network Connection. It is probably the Local Area Connection. Right click on it and choose Properties
A new box will open up. Click the Configure button under the Connect Using: box
Click the last tab at the top that says Power Management.
Under the Power Management tab click the square box that is beside: Allow this Device to Wake the Computer to take the checkmark out of the box. Then Click OK at the botton and close all the windows.
Let the computer go into Sleep mode and see if the computer still comes out of sleep mode on its own.
Let me know if this worked for you,
Ry
Apr 03, 2009 | HP Computers & Internet
Sleep vs Shut down
It depends on how long computer is being used in a day.
for general use
you can shutdown your computer once in 2 days but i highly recommend not to put in sleep mode and betting putting in hibernate mode instead of sleep mode.
note: most of simple issues are resolved by restarting PC so you can guess now how important is to shut down computer.
Good luck,
Mar 25, 2009 | Apple 24" iMac Desktop
I can not start laptop because it stays in sleep mode.
Do A "Cold" Boot...
Remove The Battery For 30 minutes, And Leave It Unplugged..
With No Battery in and No Charger Cord Plugged In Now, Press and Hold the Power Button Down For 30 Seconds.....
After 30 minutes, Replace Battery and AC Adapter and Attemt to power on "hopefully not in sleep mode"
Nov 20, 2008 | IBM ThinkPad R31 2656 Notebook
IBM ThinkPad T23 2647 Notebook Logo
205 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
