Canon i9900 - When I try to print everything seems to be normal except that no ink is on the paper. I get no error message the paper goes through the printer but comes out blank. I have done cleaning with no change.
  • 805 Answers
Thanks for your question. may be your printer head damage. please change it
Posted on Apr 06, 2011
I have a Canon Pixma 260 photo printer which I have not used for 2-3 years. Everything seems to be working EXCEPT when I try to print, nothing appears on the photo paper! I just bought a new ink cartridge...
Inkjet printers need to be used frequently to prevent inkdrying out in the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
May 28, 2011 | Canon PIXMA mini260 InkJet Photo Printer
Black and white prints are not black
Sorry, steve, that you are experiencing this problem.
According to canon.com's website regarding the i9900 InkJet Photo Printer:
Why color ink may be used when printing in black and white Even when printing in black and white, color ink is used for the following reasons:
  1. Automatic cleaning of the print head.
    To prevent the print head nozzles from clogging, the print head is automatically cleaned periodically. At that time, a small amount of each color ink is consumed.
    Therefore, although printing in black and white is performed, color ink is also consumed.
  2. Color inks may be used to create black.
    When printing in grayscale or on photo paper or when duplex printing, although printing appears in black and white, the color black may be created using the three (cyan, magenta, and yellow) color inks. Printers without a pigment black tank / cartridge will print black / grayscale will create a composite black using color ink even on plain paper.
    Therefore, although printing in black and white is performed, color ink may be consumed.
  3. In order to keep the heavy black ink from smearing on the page or in the printer, color ink is used when duplex printing to help create black text.
I might suggest taking out the color ink cartridges leaving only black there, but some printers don't take kindly to this. So, you may have to further experiment with magenta, cyan, and yellow to make it at least seem b&w to your best eye's judgment.
Good luck on this.
Jul 13, 2010 | Canon i9900 InkJet Photo Printer
Most of Group 1inks,(except red) won't print
Over on the right is not waste ink pads, waste ink is under the print engine covering the whole bottom of the printer. On the right is the purge assembly and there is ink on the filters on top and on the squeegee that wipes the printhead. You may need a new purge assembly, or just re attach a hose in the purge unit that may have come off. That printer is well worth the repair...
Sep 10, 2009 | Canon i9900 InkJet Photo Printer
Ink jets plugged.canon i9900...deep cleaning dosen't work
Im getting an error message on my cannon i9900 saying error 5300c. The light flashes, how do I fix this problem, I can't print. Need to know asap.
thanks donna
Dec 08, 2008 | Office Equipment & Supplies
Canon i9900 not printing red or photo magenta after new printhead install
I have 3 Canons i9900 and the clogging of red and photo magenta is common, mainly photomagenta. I take the print head out and place it on a paper towel. I mix a solution of 50/0 distilled water and isopropyl alcohol. I use a syringe and put enough solution around each print head to cover it and let it soak for about 1 hr. I will keep adding solution to keep the head covered. You will notice color leaking out on the paper towel. After an hour I actually push the solution through each head until no color comes out the bottom. I took a piece of tubing and heated it to shrink the end and then cut it off straight. It fits snugly on top of the print head. I then attached it to a syringe and fill the syringe with my solution. Then I push the tubing on top of the head and gently push solution through the head until it comes out clear. I do all the heads. when I am done I use canned air to gently dry everything, especially the contact plate off. when I put the new head in I usually try to put OEM cartridges in the first time, I have been told they flow better. This works for me. It is a pain but I refill my ink and I save $1000's a year in ink.
Oct 03, 2008 | Canon i9900 InkJet Photo Printer
Canon i9900 black ink smudging
ok, What cartridges are you using, Are the Canon cartridges?
What paper are you using, is it Canon paper?
If you are to both of these it could be wise ordering a printhead, but this is mostly caused in the uk by None Canon Paper.
Please let me know what you are using?
Sep 24, 2008 | Canon i9900 InkJet Photo Printer
New ink is not printing
make sure the paper is off the ink cartridges
Jul 29, 2008 | Canon i9900 InkJet Photo Printer
jasbo
jasbo
