Question about Broilmaster P4BL Gas
I have a gas leak coming from grill, gas is turned off. Is this a common problem and is it a simple fix?
    Brigadier General:
  • 4,736 Answers
If you still have a leak when the gas tank is turned OFF, it's not the grill leaking it's the propane tank valve leaking. Carefully disconnect the hose from the grill (No Smoking) and move the tank as far from the house as you can, into an open area, where the gas can dissipate. Propane gas is heavier than air, it doesn't rise it falls. If after doing this and you still smell gas leaking from the tank, contact your local fire department.
Posted on Apr 07, 2011
I smell gas ,sprayed connections ,no bubbles ,cleaned everything still leaking ,suggestion please whats most common for leaks thanx Tom
The leak itself may not be in the grill. It may be the connections to the gas tank regulator and hose. Or a minor leak in the tank valve, itself. Occasionally, the burner control valves will leak even when they are turned OFF. Of course, they are the hardest thing to test. These are just a few of the things you may need to check, in addition to those you have already tested.
Good luck and Happy Grilling!
Mar 17, 2011 | Thane Q-BBQ Grill
Turned on gas at regulator and heard a loud high pitched whoosing noise accompanied by a smell of gas. Taps on unit were in the off position
this could be the rush of gas when you turn the gas on , and the gas coming out of the breather hole on the reg try turning it on slower and test for leaks on the reg with soapy water if it bubbles up you have a leak on the reg, then you would have to change it .
Jun 29, 2010 | Napoleon BBQ Grills Rolling Grill Propane...
Grill does not get hot. I have a fresh bottle of propane. Hose is not kinked. Grill is maybe 6 - 10 years old.
hi,
When a new or newly filled propane tank is attached to your gas grill, the OPD is usually at its maximum limit position above a tank filled to capacity. Propane may come through the valve too strongly due to the additional pressure of being full and the OPD displacement. The propane tank goes into check and limits gas flow when too much pressure hits the valve. Some grill manufacturers provide instructions for this in the users manuals but most people do not read the manual. Many grillers believe replacement parts are needed and burners, ignitors and regulators get replaced without reason. Depending on how efficient the grill is operating, some grills attached to a tank in check will not ignite and others will light but cannot reach cooking temperatures because the tank has limited the amount of propane released. Sometimes the food will be unable to exceed 200 degrees in temperature because the propane tank is in check.
Gas grill replacement parts are available and are sometimes necessary, low or no gas flow indicates a different typr of repair. Most grillers accept instructions and the problem is corrected in minutes -- but believe it or not I have had a few insist on purchasing replacement parts.
How do I fix grill?
To reset the check valve and get back to cooking on your gas barbecue grill, first
turn everything off. Turn off the grill, the rotisserie, the side burner and the LP gas cylinder tank. Once everything is turned off disconnect the propane tank from the gas grill regulator by unscrewing it or pulling the quick-release on older or retro-fitted propane cylinders. Now turn the grill on. I know, it is dis-connected from the gas tank but we want to ensure that the pressure in the gas lines or any gas in the burners is released. Leave all grill burners in the on position for 3 - 5 minutes before turning them off. Make sure. Most gas grill valves must be pushed in to turn them and if turning is attempted without pushing the knob, they will not turn to the "on" position. With the grill, et al turned off reconnect the propane tank and slowly turn the hand wheel to the open position.
Slowly. The trick here is to turn the hand wheel slowly. Propane in a new or very full tank will be under more pressure, especially with the OPD floating in position. The extra pressure will come through the tank valve stronger. Turn the gas tank slowly allowing small increments of propane to enter the grill.
Once this is complete, you should be able to turn the grill on high and ignite your gas grill burner. Your cooking heat should be back to normal and cooking times decreased. If the problem persists, try this process again to make sure you followed every step. The check valve exists to save your life if there is a leak in any of the gas fittings. Constant check valve issues could imply a gas leak and a visit from your local gas grill service technician may be necessary.
To find a leak, turn the grill valves to the off position and the gas tank valve to the full on position. This should pressurize the gas line. Spray soapy water on all the fittings and look for bubbles just like checking for the leak in a flat tire.
Do not attempt to correct a gas leak on your own. While a check valve error when your gas grill will not get hot or will not ignite is a user education error and an issue corrected by learning about your propane tank, a gas leak should be corrected by a licensed gas service technician. When you are grilling, turn the propane tank on first and then turn on your grill. When you are done cooking, turn the gas tank off first and then turn off the grill valves. The process releases the pressure in the gas grill hose and manifold which allows the gas tank to release pressure by filling these lines. Read the safety features of your gas grill, clean it when necessary and replace used and failing parts. Aside from that be safe, eat well and have fun.
thanks.
Jun 15, 2010 | Weber Genesis Silver B Grill
Just bought a new propane tank and attached it. When I turn the knob to ignite the grill, no gas is coming through the line. How can I fix this?
Turn tank off and disconnect coupling. Re-attach coupling and turn gas tank on very slowly. Check for leaks with soapy water. If no leaks, you should be all set start grilling.
May 23, 2010 | Broilmaster Premium P3 Grill
Flames periodicly coming out bottom by hose going totank getting
then you have a gas leak needs to be fixed unsafe to use try soap water on joints to trace leak when on
May 10, 2010 | Fiesta Advantis 3000 Grill
Gas not coming out enough; flame not catching on to other burners
Problem: Low flames on grill, tank is full.
Cause: These newer tanks have a device inside that limits the flow of gas to prevent leaking or accidental discharge of gas from the cylinder. The leak detector mechanism inside the tank shuts off the gas whenever the valve is opened rapidly.
Solution:
Close the tank valve and remove the tank. Check the gas line for ANY object that could cause blockage. Open all valves on the grill to eliminate any pressure whatsoever. Close all valves and reattach tank. SLOWLY open the tank not over 2 turns. Check for leaks. I just open my tank a tiny bit but that is just me.
This late model gas grill service manual has more details on page 13.
Apr 28, 2010 | Weber Genesis Silver A Grill
I have a fiesta grill, new propane tank, and it would lihgt. I tried turning on gas and inserting lighter and it would come on, but barely. Are my burners gone?
check for leak if no leak then make sure knobs are turned to off turn off tank and start over turn tank on then try again if it still doesnt work need new hose and regulator
Aug 09, 2009 | Fiesta Blue Ember Gas Grill
Low flame when all four burners are on
This sounds like one of two things - either the gas regulator (the big bulky thing between the tank and the BBQ that is usually round) is faulty, in which case it needs to be replaced, OR (and a much cheaper fix) the air intakes on the grill itself are clogged.  Get underneath the grill, and look where the gas lines connect.  There should be some sort of mesh material where the lines connect to the different burners - make sure those are really clean, as the burners depend on a precise mix of gas and air.
May 26, 2009 | Char-Broil Commercial Stainless Steel...
We have a sunbeam 540 gas grill with a leak in the connector between the gas tank and the hoses leading to the grill. How can we fix the leak?
If the leak is in the black fitting you turn to tighten it onto the tank, that is a replaceable part.
It is part# 86495 from Music City Metals.
You can get it for $13.99+ at marbeck.com
Jul 05, 2008 | Thermos Stainless Steel Gas Grill
My baby q is sick
Since 1995 all regulators (the part that attaches to the gas tank to regulate the flow of gas) have included a safety device that restricts the flow of gas in the event of a gas leak. This safety device can be inadvertently activated in two ways, putting the grill into what is commonly called “bypass”. The first way for the device to be activated is to leave one or more burner control knobs in the “ON” position when the LP cylinder valve is opened. The second is not to wait long enough to “start” the grill after opening the LP cylinder valve. The safety device in the regulator is activated each time that the LP cylinder valve is opened. The device resets itself when the gas pressure equalizes between the closed burner control valve and the regulator, through the hose. If a burner control knob is turned on before the gas pressure can equalize, the device will remain in “bypass”. The length of time necessary to wait to “start” the grill after turning on the LP cylinder valve is dependent on the length of the hose and outside air temperature. It is always good practice to wait a few seconds after opening the LP cylinder valve before turning on the burner control knob to start the grill.
Keep in mind that the safety device reacts to a gas leak. If a grill is in bypass, the gas connections and hose should be tested for leaks with a soap and water solution.
If the grill is in bypass, after checking for gas leaks do the following to get the grill out of bypass:
To reset the gas safety device:
Open the barbecue lid.
1. Close the LP tank valve.
2. Turn your burner control knob to the OFF position.
3. Wait at least 5 minutes if the barbecue had been lit, then
4. Disconnect the hose from the LP tank.
5. Turn your burner control knob to the HIGH position.
6. Wait at least 2 minutes, and then turn the burner control knob to the OFF position.
7. Re-connect the hose to the LP tank.
Re-lighting the barbecue:
1. Open the barbecue lid.
2. SLOWLY open the LP tank valve all the way and wait 1 minute.
3. With the lid open, turn the burner control knob to the HIGH position.
4. Ignite the grill by pushing the crossover ignition button.
5. Close the barbecue lid.
6. The barbecue should reach 500 to 550 degrees in 10-15 minutes.
When you are done grilling:
1. Turn all burner control knobs to the OFF position
2. Turn off the LP tank valve last.
* Always follow the re-lighting instructions whenever you use the adapter hose and larger tank.
Feb 16, 2008 | Weber Q Grill
Broilmaster P4BL Gas Logo
289 people viewed this question
Top Broilmaster Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Broilmaster Grilling Expert? Answer questions, earn points and help others
