Question about Tyco Skid Flat W / 3 Tractors Ho Train Model Rr Car Md
Tyco model train locomotive - motor runs but the locomotive doesn't move. I need a manual for Tyco model 263-10 HO gauge locomotive
SOURCE: GP40 style HO Diesel motor squeals when run from slow to top spd.
Use a tiny amount of light weight oil (sewing machine oil will work) on the outsides of the motor shaft,., Use a tooth pick to apply. Of cours you'll need to remove the plastic body first. Another suggestion if that doesn't take care of the noise is to place a tiny bit of vasoline on the gears that are exposed when you take the plastic boy off. While your doing that you may want to place some vasoline on the gears inside the driving truck or trucks (dual drive). Pay attention when removing the plastic bottom covers from the truck. Use a small screw driver to pry one end of that cover loose and the other becomes loose and then remove to expose the gears.
Happy Happy
Posted on Feb 27, 2009
  • 5 Answers
SOURCE: locomotive won't come on
This train set is very particular and getting it to work each Christmas is a family tradition in frustration. First you must make sure that all the pieces of track are connected properly and that the track is perfectly symmetrical and flat. We double-check the battery positions every year and find one in wrong. There are + and - signs, but they're hard to see; use a flashlight. There is a black toggle switch below and behind the red stack that toggles forward (to make the train go forward) and backwards (reverse); straight out perpendicular to the train is the "stop" position. Also, you have to start at a stop/switch station. One other note: behind the red stack, there is a smaller black stack. If you turn this, you can make smoke come out of the stack. I think I remember someone suggesting a drop of cooking oil. Hope this helps!!! Hope you get it set up for Christmas!!!
Posted on Dec 24, 2009
  • 7 Answers
SOURCE: My granddaughter has about a dozen Brio
Alas, the traction drive on these Brio locomotives seems to have a pretty short life. According to a Brio rep, the only hope is to indeed give it a good firm solid whack down onto a hard surface (table or floor) in an attempt to get the internal pressure gears to settle down and get more traction. There's a 50/50 chance it might work. There is no other solution. Attempting to open it up will create a mess because it's almost impossible to get all the tiny loaded springs back into place. At least the lights and sounds still work, and it can be easily pushed around the track--it just will no longer do so itself...
Posted on Mar 29, 2010
captjack163
  • 13 Answers
SOURCE: tyco trains are set up have power but trains will not move
Check the engine and transformer by taking the two wires from the transformer and, while holding the engine upside down put on wire against one side wheels and the other wire on the other sides wheels...that will tell you if the engine is at fault.
Posted on May 04, 2010
  • 1015 Answers
SOURCE: tyco toy train does not
I would start by making sure all the connectors on the track are clean and locked together firmly.Wipe off track rails and all electrical connections with clean soft cloth such as a wash rag.Try to not touch electrical connections with bare hands as even small amounts of body oils or hand lotions can interfere with good connections. Check hook ups from transformer to track. Clean electrical pick up points on engine with pencil eraser and soft rag, you can use eraser to clean track surface also.
Hope this is helpful and have a good new year. Thanks
Posted on Dec 28, 2010
Is there a parts list?
Parts Catalog : Bachmann Trains Online Store!
estore.bachmanntrains.com/index.php?main_page=index&cPath=66
Please browse by scale and model. If you can't find what you need, contact our PartsDepartment for more information. Bachmann's Parts & Service Departments ...‎HO Parts - ‎N Parts - ‎Large Scale Parts - ‎On30 Parts
Model Train Couplers / Trucks - Hobbylinc.com
www.hobbylinc.com/model-train-couplers-trucks
Discount pricing on couplers - ho, trucks - ho, misc parts, trucks - n, couplers - n, and trucks - g. ... 1-20 of 1,476 results in Model Trains > Parts. ... +Wish-List.
HO Scale Parts - Atlas
www.atlasrr.com/hoparts.htm
We are in the process of converting all of our parts diagrams for locomotives and freight ... If you do not see a loco or freight car on this list that you are interested in, ...Atlas Production Schedule. Track. HO Models. N Models. Parts. Beginners.
Train Repair Parts Home Page - Hobby Surplus
www.hobbysurplus.com/trainrepairparts.htm
Come to Middletown or New Britain Connecticut and visit our huge Toy and Hobby stores. ... Example of an"Exploded View" from a train repair manual ... operators and collectors have correctly identifying the parts required to repair their trains, ...
Brasseur Electric Trains - Over 12,000 Model Train Parts ...
www.brasseurelectrictrains.com/service/catalog.asp
Jan 04, 2016 | Crafts & Hobbies
Only runs in reverse, why?
Polar Express only runs in reverse ' O Gauge Railroading ...
ogrforum.ogaugerr.com/topic/polar-express-only-runs-in-reverse
Dec 7, 2011 - Polar Express only runs in reverse ... At this time of the year all Polar Express trains are programmed to run North only. ... This would not be so bad on the Strasburg set because half the time, the prototype runs in reverse.
both trains only go backward - Classic Toy Trains Magazine
cs.trains.com > ... > Forums > Toy train operating and collecting
... trains that i set up around Christmas. The first train, according to the box, is a k-line 0/027 gauge dual motor mp-15. For a long time it has only run backwards.
no forward only reverse - Model Train Forum - the complete model ...
www.modeltrainforum.com > Scale Specific Model Train Forum > O Scale
Oct 18, 2009 - 10 posts - ‎3 authors
There are two switches under the cab; they have no effect on forward motion. This setis 2 or 3 years old and has been run maybe 1 hour total. New Athearn HO Locomotive won't go in reverse ...
Mar 5, 2015
Lionel Rio Grande 8213 only runs in reverse - Model ...
Nov 18, 2013
More results from www.modeltrainforum.com
Jan 01, 2016 | Crafts & Hobbies
Lionel train problems
Have you let the loco charge first? The instructions are a bit vague but the loco needs to charge before it runs. Not easily understood from the instructions and many have spent some frustrating minutes wondering why their train wouldn't move.
Dec 24, 2013 | Crafts & Hobbies
I bought a marklin steam locomotive where the wheels are frozen up or not moving at all. Any help ? Ho can repair it. Thanks
If the wheels don't move even when you try to "slide" them with your fingers, the possible problem is with the motor brushes: with a pair of tweezers gently push the springs that hold the brushes (there is one cooper brush and a carbon brush, on the motor). Remove the brushes and replace them by new ones (available from any Marklin dealer). Notice that there are 2 brush models - for old motors and new motors (these ones use 2 carbon brushes instead). Hope this helps. Best!
Oct 08, 2013 | Walthers Marklin "Veolia Transport" Class...
Help please. Lionel (30190) Thomas & Friends remote O gauge. Train won't move. Light comes no, nothing. I took the roof off and made sure the switch was in the on position. ??
First, check to make certain that the batteries in the remote are good.
Second, if the train has been running and the problem is new, clean your wheels and pick up roller on the locomotive, then clean the track.
Make certain that when you use the remote, you orient the antenna in an upright position and are within 6 to 8 feet of the locomotive.
If none of the above helps, contact the Lionel Service Department.
586-949-4100
Oct 07, 2013 | Lionel (31956) Thomas The Train Set
Lionel battery operated g scale locomotive will not move
Replace all batteries in locomotive & remote.
You do need to be fairly close to the set with the
remote for it to work.
Jan 19, 2013 | Lionel A Christmas Story Gauge Train Set...
My son has an Iron King Train that the locomotive just stopped. It was stop/go for a while and now it doesn't run at all. Any ideas on what to look for?
First: clean your trackSecond: clean your wheelsif that fails, call 1-800-356-3910& speak with Bachmann Parts & Services to find out if your
locomotive need to be sent in for repair.
Mar 13, 2011 | Bachmann Ho Iron King Train Set
Tyco trains are set up have power but trains will not move
Jan 28, 2010 | Tyco Ho Vintage Wm Flat Car W/ Tractors...
Need motor brushes for Penn Line and Tyco HO
If you go to :
www.hoseeker.net
they have old catalogs and part numbers for Penn Line trains. Then try:
www.yardbirdtrains.com
for parts or a replacement motor or they may be able to point you to someone who may have the parts. Good luck.
Bob D.
Apr 25, 2009 | Electric Vintage Tyco Ho Scale Trains...
Tyco Skid Flat W / 3 Tractors  Ho Train Model Rr Car Md Logo
52 people viewed this question
Top Tyco Toys Experts
john h
ray gallant
Robert Reed
Level 1 Expert
Are you a Tyco Toy Expert? Answer questions, earn points and help others
