Question about Garden
When i start it it will run for about 30 min and shuts off, and wont start back up. If i let it set for a while it starts up and we start all over. I was wondering if it might be the coil?
  • 2,239 Answers
It sounds very much like an ignition problem, it could also be vapour lock due to poor quaility fuel.
Posted on Apr 06, 2011
Dryer runs for 30 mins then all lights flash and machine wont start
oh oh bad windings on motor usually runs for about 20-30 minutes hen shuts off cant start agin after a half hour?
Feb 05, 2015 | Washing Machines
Quits after warm up wont restart
sounds like you have a fuel pump problem, fuel pumps will usually get hot and then shut off allowing it to sit 30 mins lets the pump cool down allowing it to start pumping, the way you can test it is get a can of starting fluid the next time it quits raise your hood and spray some fluid down into the throttle body and if it starts and then dies it is most likely your fuel pump, hope this helps.
Feb 02, 2013 | 1999 Dodge Dakota
Runs for anywhere from a few miles to 10 miles then just ...chug chug chug ...shuts off, then wont start again usually. may start after setting for 30 min.
There is a drain plug at the bottom outside edge of each carb float bowl. Drain the carbs. Chances are condensation from the gas tank is partially filling the float chamber. tombones49_226.gif
Aug 09, 2011 | 1984 Honda VF 1100 C
1993 toyota camry 4 cylinder runs 15 mins and shuts off and wont start back up until 30 - 45 mins later
This could likely be a problem with your cooling, Next time you turn your car on pay attention to the temperature gauge and see if it rises above the norm.
May 02, 2011 | 1993 Toyota Camry V6
1990 honda accord ex does not start when hot?
Sounds like the pgmfi relay is going out. This is a common problem with these cars. They get hot and dont want to work, they cool off and everything is ok.
May 17, 2010 | 1990 Honda Accord
Gas dryer runs for 30 mins then shuts off.
This is a common problem that is not a good one. But the motor is goin bad. If you try to start it you will hear like a hum then start. Motor is going bad and over heating and shutting down on overload. Sorry. Hope this helps.
Jan 31, 2010 | Kenmore Dryers
Runs for a couple minutes then shuts off. will not start back for at least 30 min. when it shuts off i can spry in throttle body and it will start but shut back off, have changed fuel pump and problem...
need to check fuel pressure when it wont start if you don't have any check for 12 volts and a ground at fuel pump if you do have pressure need to check for pulse signal at fuel injectors
Jan 29, 2010 | 1995 Dodge Dakota
91 camray 2.0 4cyl. wont start after driving for 20 min.
I would start by have the starter itself checked. Electrical resistance may be increased by warmer temperatures.
Nov 19, 2008 | 1991 Toyota Camry
Garden Logo
22 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
