Question about Canon MF6530 Black and White Copier
I unplugged our copier, and after plugging it back in, it will not work. It says, "downloading standby". we have tried to soft reset by *2, 8 , * which did not work. we use this as a stand alone copier, its not plugged into any network or computer. please help if possible.
    New Friend:
  • 140 Answers
You must have to download the firmware. which can do canon engineer.
copier missing it's operting system.
Posted on Apr 07, 2011
  • backdoc99 Apr 07, 2011
    A waist of my money and time... I just went to canon.com to find fix.
PANASONIC VIERA TX55as802b will not switch on red power/standby light blinking once every 3-4 seconds have been told its the screen and it cant be repaired can anyone confirm this or help.thanx
The manual says nothing about the power light flashing at that rate. Unless an expert tells you that's the specific indication for a failed screen, I wouldn't believe it. Most TV's will give you sound even if the display has failed.
Try resetting it by unplugging and waiting 60 seconds before plugging it back in.
If that doesn't work, most likely the power supply board needs to be replaced. Or possibly the T-con board.
If you don't know what you're doing, DON'T OPEN THE TV UP TO FIX IT, THERE ARE HAZARDOUS VOLTAGES ON THE POWER SUPPLY BOARD, EVEN WEEKS AFTER THE TV IS UNPLUGGED!
If you don't know how to do it yourself, find some local Electronic repair shops, get quotes, try to find reviews on the shops.
Sep 20, 2016 | Panasonic Televison & Video
Hi. I have a HP Deskjet 3745 printer. The green light keeps flashing and the printer is said to be "offline". I have tried everything but nothing works...
Try lifting the top (2) panels where the ink cartridges go, than place back down after the ink cartridges go to the center. Or just unplug and plug back in!
This should reset your printer! You may be asked to realign the ink cartridges, but you can press the cancel button to bypass this.
Kind regards!
Sep 13, 2011 | Office Equipment & Supplies
I have a uniden Tru9466 base station and a uniden TWX 977 that the later that was previously registered with the first displayed a out of range notice so I went thru the process in the owner's manual...
Welcome to FixYa.
  1. Turn OFF your handset (TWX977) and any other handset registered to the base (9466).
  2. Unplug the base from its power source.
  3. Unplug the phone line from the base.
  4. Wait for 15 mins.
  5. Plug back the power source and the phone line.
  6. Turn ON the handset (TWX977)
  7. Reset the handset (TW977) by doing the following:
  • Press the MENU soft key. Select the DEREGISTRATION submenu.
  • ARE YOU SURE? appears. Move the cursor to select YES. Press the OK soft key.
  • To clear other handset information, please follow these steps:
  • From the handset, press and hold [ ] and [#] for more than 5 seconds. Select the DEREGISTER HS submenu.
  • Move the cursor to select the handset ID to be de-registered from the list, and then press the OK soft key.
  • DEREGISTER HS appears. Move the cursor to select YES. Press the OK soft key.
  • ARE YOU SURE? appears. Move the cursor to select YES, and then press the OK soft key. You will hear a confirmation tone.
8. Register the handset by doing the following:
  • With the base in standby, press the MENU soft key.
  • Move the cursor to select REGISTER HANDSET. Press the OK soft key.
  • On the handset, press and hold [#] until you hear a beep.
  • While the handset is registering, HANDSET REGISTERING will appear in the LCD. When REGISTRATION
  • COMPLETE is displayed; the handset has been registered to the base. If REGISTRATION FAILED appears,
  • please try these steps again.
Thank you for using FixYa.
Have a great day.
Jas247
Aug 22, 2011 | Uniden TRU9466 Cordless Phone
Continual "reset power" message on
Try reset your printer by following this procedure to reset it,
1. Without turning the unit off, unplug the power cord from the back of the product.
2. Press and hold # and 6 keys.
3. While holding those keys plug the power cord back in.
4. Wait until the screen goes blank before you release those keys.
5. Follow on printer screen instructions.This should fix the problem..
Jul 05, 2011 | HP Officejet 6310 All-In-One InkJet...
ImageClass MF6590 gives "Download Standby"
the firmware is down . u have to call a rep to solve this as u have u get install a service software or change the boot rom
May 25, 2011 | Office Equipment & Supplies
I was exploring the setup menu and I found an election of Progressive Scan "on" and "off". When I tried "on" then the picture get out and no image was since then. I can't...
There are 2 ways you can reset the player to default factory settings, although I am not sure about progressive scan being reverted back to interlaced output.
1) Unplug the player (or switch off) at power point, as soon as you reconnect (switch on) power to unit, press and hold the [STANDBY-ON] button (on the front). As soon as you see 'IS TV ON?' on the front panel display, release the [STANDBY-ON] button. This should reset it.
- OR -
2) If you do not have the instruction manual, you can download a free pdf of it;
http://www.retrevo.com/support/Philips-DVDR615-DVD-Players-manual/id/280ag201/t/2/
I hope this helps a tiny bit.
Mar 17, 2011 | Philips DVDR615 DVD Player
I get "system error e000" message when i copy
1) Press the "Additional Functions" key.
2) Press the "#" key.
3) Press > to the "#7" printer function.
4) Press the "Set" key.
5) Press > to the "#4 Printer Reset".
6) Press "Set".
7) Press 8) Unplug printer, plug it back in, and turn it on.
Mar 14, 2011 | Canon Image Runner 1630 Copier Copier
I try to turn on and stays on standby
unplug the unit, hold down the power button and plug in this is a reset, I'm not sure if its a soft or hard reset, but it brought mine back on. mine did the same thing. Now it works again!
Nov 14, 2009 | RCA RT2500 System
DOWNLOADING STANDBY
  • Unplug machine.
  • Press 1, then 9.
  • Plug machine back in.
  • Press 1, then 9 (again).
Machine should then initialize and be ready for service.
Apr 14, 2009 | Canon Laserbase MF6530 All-In-One Printer
Canon MF6530 Black and White Copier Logo
67 people viewed this question
old marine
old marine
