Question about LG WM0642H Front Load
My lg washer will not drain fills with water and spins. when time to drain just makes funny noise. cleaned drain filter still wont drain
  • 4,399 Answers
Thanks for choosing FixYa. If your washer doesn't drain or spin, you may read and learn what parts may cause this. First, you will want to check your water pump. You need to make sure it is working. Make sure you check the belt on the pump. Make sure it is not broken or loose. Also, make sure your pulley is not stuck in place. Sometimes, they will stick or barely turn at all. If this is the case, you will need to replace it. If the pump, pulley, and belt are working, make sure your motor is working. You should be able to hear it if it is. If it isn't, check your lid switch. The lid switch can cause the motor to not work. It may need adjusted. If not, go ahead and change it. A bad lid switch may cause the washer to not work at all. Now, if your pump is pumping and the washer still won't spin, you will want to check your belt and clutch. Once again, the belt may be broke or loose. Check to make sure your clutch is not worn also. This may be a case of a bad lid switch again as well. You could have a bad drive motor. This is what controls spinning, draining, and agitation. You could have a broken motor coupler. Over time, they will go bad and need replaced. It is possible that your transmission is slipping or damaged. And lastly, you could have a bad basket drive ir spin bearing. This is what allows the inner tub to move. If this is the case, you will probably hear loud sounds or loud banging. I want to thank you for reading and I hope this helps you. Best regards and thanks for reading
Posted on Apr 30, 2011
MY FRIGIDAIRE FRONT LOAD WASHER WONT FILL WITH WATER OR SPIN . HAVE TRIED CLEANING THE DOOR LOCK & UNPLUGGING IT FOR EXTENDED PERIODS OF TIME.
Sounds like the fill water solenoid has bust, they are cheap to replace and fairly easy. make sure you disconnect from power supply and water supply before trying.
Jan 30, 2014 | Frigidaire GLTF2940ES Front Load Washer
Spinning cycle
Keeping in mind that the soap & bleach gets dispensed into your wash on the second to last rinse cycle and that most all rinse cycles are in cold water. Is your cold water valve screen plugged causing your washer to rinse poorly? Are you using the HE detergent? If not maybe the washer is sudsing up to much and having a hard time rinsing all the suds and bleach out and leaving the clothes soapy.
Fill the washer up with no clothes in it on a cold/cold wash setting does it take a long time to fill the washer up? Also when it is full and agitating is there suds in the washer?
Last suggestion is if the drain is hose is a lot higher than the top of the washer it might have a hard time draining out all of the soap water before the next load
Mar 23, 2008 | LG WM-2277HW Front Load Washer
Need help
Are you saying it is draining the water properly? Because it sounds as though the pump is faulty. Every now and then you get pup motor that don't short out or stop completely they just don't drain we'll anymore. The drain period on your machine is timed so a slow drain may cause the error. So even though everything is clear and 'working' the pump needs replacing. Another cause would be a false reading from the pressure switch(level switch) but you would normally have problems with fill etc also, so unlikely.
Jul 09, 2013 | Washing Machines
My lg washing machine is making a lot of noise when it is spinning and it wont spin out the water to good
Hi blare131,
I believe there may be a foreign object in you drain pump filter, this must be removed (Should solve both issues)
Please follow my below Tip on how to do this:
ACCESSING, DRAINING & CLEANING THE DRAIN PUMP FILTER...
Kind Regards
JEDEMEYER1
* If this solution helped you, please rate it
Aug 17, 2011 | LG WM-2277HW Front Load Washer
What does the IE error code mean? The washer wont drain.
The IE fault code indicates that your washer is not filling properly with water This error code is displayed if the washer is not fully drained within 10 minutes. I will give you troubleshooting tips for both the fill problem and the drain problem.
To troubleshoot a drain problem, follow these steps:
  • Follow the steps on page 17 of your owner's manual to clean the drain pump filter. If you do not have your owner's manual, you can access it on our Manage My Home website.
  • Check your drain hose for kinks or clogs.
  • Make sure that the drain hose is properly installed according to the installation instructions for your washer.
Here are some troubleshooting steps for the filling problem:
  • Make sure that the water valves behind your washer are fully open.
  • Check the filter screens on the inlet valves where your fill hoses connect to the back of the washer. If debris is clogging the screens, remove the screens and thoroughly clean them. Flush the inlet openings thoroughly with water to prevent debris from entering the washer and corrupting the inlet water valves.
  • A drain installation problem can cause siphoning of washer fill water. Make sure that the drain hose is properly installed per the installation guidelines for your washer.
Jan 13, 2011 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Wont spin the water out
check for the DRAIN MOTOR PUMP , located where the DRAIN HOSE is attached to ,it could be clogged,
hpe it helps , AJ
Dec 21, 2009 | Frigidaire GLTR1670A Front Load Washer
Washer won't rinse and spin
clean the drain hose, but make sure you have a container to catch the water and lot of debris will come out. Then unplug the washer and put water on spin cycle to drain water, after draining water remove the pump filter located next to the drain hose turn left to open and clean more debris. I found my husband wedding band I thought he lost it on purpose. You will be surprise how much funk is in that filter. Turn pump filter to right to close and put cap back on hose. Don't call the repair guy. Hope this helped.
Darlene, New Orleans
504-296-4391
Jul 24, 2008 | LG WM-1832C Front Load Washer
Whirlpool AWM6120 Front Load Washer
Cleaning depends on use. 8 years is a bit over the top! When your water does not drain, check the outlet filter first, then the pipe from below the tub to the filter. Your washer wont spin 'cause the pump/filter is blocked.
Jul 24, 2006 | Whirlpool AWM6120 Front Load Washer
LG WM0642H Front Load Logo
337 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
