Question about Adobe Photoshop CS2 for PC
I need serial no
I send my computer for data recovery now all my serials is gonn
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 100 Answers
You dont have the serial on the disc?
Posted on Aug 10, 2008
I have a 2010 Chevy impala LS instrument cluster and it has a 20 pin plug I'm trying to figure out which wire's on the back of the cluster are for the speed sensor, rpm, gas, and temp wires.
Boy your way off base . All the gauges are inputs from the ECM - engine computer . The VSS - vehicle speed sensor , ETC - engine coolant temp sensor , sending unit in the fuel tank , All this sensors input the engine computer . The PCM then sends this info on the GMLAN serial data bus ,communications network . The Instrument cluster has a microprocessor inside that translates this info an controls the gauges. You probably have an instrument cluster problem or a communication network problem . Your best bet is to take your vehicle to the dealer or some other qualified repair shop. Need to have it checked for DTC'S - diagnostic trouble codes.
Indicators and Warning Messages
Refer to Indicator/Warning Message Description and Operation.
Engine Coolant Temperature Gage
The instrument panel cluster (IPC) displays the engine coolant temperature as determined by the engine control module (ECM). The IPC receives a serial data message from the ECM indicating the engine coolant temperature. The IPC receives the coolant temperature information via serial data message from the body control module (BCM). The engine coolant temperature gage defaults to 60?°C (140?°F) or below if:
The ECM detects a malfunction in the engine coolant temperature sensor circuit.
The IPC detects a loss of serial data communications with the ECM.
The IPC detects a loss of serial data communications with the BCM.
Fuel Gage
The instrument panel cluster (IPC) displays the fuel level as determined by the engine control module (ECM). The IPC receives a serial data message from the ECM indicating the fuel level percent. The body control module (BCM) sends the fuel level information from the ECM to the IPC via a serial data message indicating the fuel level percent. The fuel gage defaults to empty if:
The ECM detects a malfunction in the fuel level sensor circuit.
When the fuel level is less than a pre-determined value, the low fuel indicator illuminates in the IPC.
Odometer
The vehicle odometer is calculated and stored electronically in the instrument panel cluster (IPC). The IPC contains a season odometer and trip odometer A or B. Momentarily press the trip/fuel button in order to toggle between the season odometer and the trip odometer. Press the set/reset button for greater than 0.25 seconds, while the trip odometer is displayed, in order to reset the trip odometer. The IPC displays the vehicle mileage and trip mileage as determined by the engine control module (ECM). The IPC calculates the mileage based on the serial data vehicle speed information from the ECM. The odometer will display 'error' if an internal IPC memory failure is detected. The odometer displays either miles or kilometers and can be set through the customization menu in the driver information center (DIC).
PRNDL Display
The instrument panel cluster (IPC) displays the selected gear position as determined by the engine control module (ECM). The IPC receives a serial data message from the ECM indicating the gear position. The PRNDL display blanks if:
The ECM detects a malfunction in the transmission range switch circuit.
The IPC detects a loss of serial data communications with the body control module (BCM).
Speedometer
The instrument panel cluster (IPC) displays the vehicle speed as determined by the engine control module (ECM). The IPC calculates the mileage based on serial data vehicle speed information from the ECM. The IPC receives vehicle speed information from the body control module (BCM) via a serial data message. The speedometer defaults to 0 km/h (0 mph) if the IPC detects a loss of serial data communications with the ECM or BCM.
Tachometer
The instrument panel cluster (IPC) displays the engine speed as determined by the engine control module (ECM). The IPC receives a serial data message from the ECM indicating the engine speed. The IPC receives the engine speed information from the body control module (BCM) via a serial data message. The tachometer will default to 0 RPM if:
The ECM detects a malfunction in the engine speed sensor circuit.
How to Diagnose Controller Area Network CAN Suggest you read up on C.A.N.
May 14, 2016 | Cars & Trucks
1997 olds gutless. Fuel gauge stuck past full. How to reset
Need to replace the instrument cluster or fuel gauge sending unit in the fuel tank or there is a BCM problem .BCM is a computer module if your not familiar with that . The BCM controls the instrument cluster indicators through the SPI serial data communication bus. Refer to Body Control Module System Check in Body Control System.
Serial Peripheral Interface (SPI) Data Line
The serial peripheral interface (SPI) is a three wire interface connecting the BCM to the instrument cluster. The SPI allows for the exchange of information. This interface is a synchronous serial data link where the BCM is the master and the instrument cluster is the slave. Because of the need for modules on the different serial data links to communicate with each other, the BCM acts as an interpreter, or master, for data communication between the class 2 and SPI data lines.
Driver Warning System
The BCM is responsible for the following functions:
  1. Interpreting all of the driver warnings sent by the control modules on the class 2 serial data line
  2. Sending the information to the instrument cluster in the form of a SPI serial data bus message
The following list of messages are sent by the BCM to the instrument cluster:
Fuel gauge position
Temperature gauge position
Oil pressure
Low engine coolant
Check oil
Volts
ABS
High beam
Low fuel
High temperature
Washer fluid level low
CRUISE
BRAKE
SERVICE VEHICLE SOON
Door ajar
Seat belt
THEFT SYSTEM
PRNDL
your best bet is to take your vehicle to a ASE certified repair shop an have it diagnosed .
Mar 02, 2016 | Cars & Trucks
I want serial key for card recovery software
Hi, You may use Sysinfotools windows data recovery tool to restore your damaged, corrupt, inaccessible data of any file format from any internal or external hard drive. You should try the free version before opting any utility to recover your damaged file.
Visit: https://www.sysinfotools.com/recovery/windows-data-recovery.php Windows Data Recovery Software to Restore Corrupt FAT or NTFS File
Feb 06, 2014 | Data Recovery Software IdeaPad A2109 ...
Stellar phoenix photo recovery softwear serial key
if you are trying to recover a key of an already installed program on your computer there are freeware keyfinders on the internet
http://download.cnet.com/%7Bvalue=http://www.download.com/keyfinder-thing/3000-2094_4-10491989.html
if you have lost the serial number
its illegal to post serial codes
you might use this software its 100% freeware
http://100-downloads.com/download.php?p=346
Data recovery for Flash Card, Smart Media, Memory Stick, Micro Drive, Multimedia Card, Secure Digital Card or any other data carrier for digital cameras
hope this helps
Jul 06, 2012 | Computers & Internet
My toshiba HDD (Model-MK3265GSX) Serial Nunmbet 40LDF2NIS KK 8 EC . A has failed. It is not readable from outside. In order to recover the data, I need another good Toshiba HDD with a serial number close...
If the drive has failed then the only option to recover data is to send it to a data recovery service but these are not cheap.
Installing another drive with a close batch/serail number will not allow you to copy from a dead drive.
I would be connecting to a regular desktop computer and trying some of the free data recovery software available such as hirens boot cd.
ANY drive within the max and type supported could be used in your laptop.
Thses are common problems with laptops and in most cases I recover data (when the drive is not too damaged) as i described above.
I then install a new and often larger drive and build the system from the recovery CD's available from the laptop manufacturer.
Then old transfer any old data I recovered back to a folder on the new drive so that customers have access to anything that was saved.
The only sure way of getting everything back from a damaged drive is to send it off but that is only of use to you if your data is mission critical.
I use the cheap USB to IDE/SATA adaptors often available from good computer shops.
Feb 15, 2011 | Toshiba 320GB MK3265GSX SATA 3Gb/s 2.5"...
V5.30 serial key
I suppose you have to purchase the program if you want to get the serial key, or you can try some free program like Card Data Recovery.
Oct 27, 2010 | Memory Card Data Recovery Best Digital...
Recovery mode / serial data displayed ! keypad inop ????
If you have a cable for connecting it to your computer, you might be able to get it working again. Otherwise, I'd suggest removing the battery and putting the phone and the battery (separate) in the fridge over-night. The next day, insert the battery and turn the phone on to see what happens. If it's still stuck in recovery mode, I'd advise seeking help at your local phone store or sending an email to sanyo asking for any codes they could supply.
Hope this helps, TechnoWolfy.
May 16, 2007 | Sanyo MM-8300
Adobe Photoshop CS2 for PC Logo
23 people viewed this question
Top Adobe Computers & Internet Experts
lemesee
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
