Both the shift keys are not working in my hp pavilion dv3 laptop
  • 13433 Answers
SOURCE: thinking about purchasing a HP loading dock HP DV2000(ES631AA)
Compatibility document.write(neg_specification_newline('HP Pavilion dv2000, dv6000, dv9000; Presario V3000, V6000 series; compatible (reduced functionality) with Pavilion ze2000, dv1000, dv4000, dv5000, dv8000; Presario M2000, V2000, V4000, V5000; HP Special Edition L2000 series using included expansion base adapter
Note: When using a notebook that requires the included Expansion Accessory Adapter, the following functions will not be supported on the HP Notebook QuickDock: VGA port functionality, stereo microphone (only mono is supported) and power button (must use the notebook power button).')); HP Pavilion dv2000, dv6000, dv9000; Presario V3000, V6000 series; compatible (reduced functionality) with Pavilion ze2000, dv1000, dv4000, dv5000, dv8000; Presario M2000, V2000, V4000, V5000; HP Special Edition L2000 series using included expansion base adapter
Posted on May 05, 2009
  • 89 Answers
SOURCE: Where's the switch to turn on wireless networking?
The wireless switch is on the front bottom of the laptop. It should be blue when ON and red when OFF
Posted on Aug 02, 2009
  • 5 Answers
SOURCE: keys coming off my HP Pavilion 5000 laptop
I would say it would be best to just replace the whole keyboard. It's not hard, just time-consuming, & you can get a good price for one on eBay.
Posted on Dec 09, 2009
  • 6 Answers
SOURCE: left shift key came off hp pavilion dv4000 laptop
you may have to hold the metal bar up as well wile u r pushing it back down
Posted on May 19, 2010
  • 425 Answers
SOURCE: laptop fan has a noisy
How to Replace a HP Pavilion dv3 Fan?
1. Follow your laptop owner's manual and assembly guide carefully you can download this from HP web site as you disassemble the laptop. Touch something metal periodically to remove static charge, and work on a large table with a bright light source.
2. Turn off the laptop and unplug it. Remove the main battery, CD/DVD drive and the hard drive. The hard drive is usually located in a slot on one side of the laptop. Remove the screw that holds the cover in place, then pull out the hard drive sled.
3. Turn the laptop over and remove the screws on the bottom that hold the keyboard in place. Flip the laptop over, open it, then lift the keyboard up and out. Unplug the flexible ribbon cable that connects the keyboard to the motherboard.
4. Remove the screws that hold the keyboard bezel and palm rest in place. Carefully pry loose any plastic snaps on the sides, then lift the bezel and palm rest up and out.
5. Unplug the HP Pavilion dv3 Fan Cooling Fan. Remove the screws that hold the heat sink and fan in place, then remove the entire unit from the laptop. Remove any thermal compound residue from the bottom of the heat sink and the CPU.
6. Apply a thin layer of thermal compound on the CPU, then replace the heat sink and fan. Replace the screws, plug the HP Pavilion dv3 Fan back in, then reassemble the laptop.
7. Plug the laptop in and turn it on. After you use it for a few minutes, you should hear the new fan running and feel warm air blowing from the vent on the side of the laptop. A HP Pavilion dv3 Fan does not run continuously, so don't be concerned if the HP Pavilion dv3 Fan shuts off periodically.
Posted on Jan 10, 2011
Problem with HP dv3 power cables.
Sounds like the charging board may be malfunctioning/shorting out inside the laptop itself causing these ac adapter failures.You really need to have it looked at before other it causes you motherboard to fail or any components connected to it.The power jack may be shorting as well which is attached to the motherboard
Dec 17, 2011 | HP Pavilion Dv3-1075us Notebook
Why does my HP Pavilion leak electricity?
Sounds like a power jack problem where the charger plugs in has a short or is touching other components near it.
Dec 16, 2011 | HP Pavilion dv3-2150us Notebook
How do I access the fan on an HP Pavilion DV3 Laptop? I've taken it apart with the online guide available but that failed to access the cooling fan. Laptop is overheating and it's clearly the...
Honestly, try harder. If you've taken the thing apart, you're more than half way there. You probably just need to unscrew more stuff and pry more parts out.
Jul 22, 2011 | HP Pavilion Dv3-1075us Notebook
Hi... how can i turn on the double click on touchpad ... my laptop is hp pavilion dv3
access control panel - select the mouse - select device settings - then the setting button - the rest is straight for for all the settings are displayed or hit default
Jul 04, 2011 | HP Pavilion Dv3-1075us Notebook
Pavilion DV3 not working on a car charger That is working flawlessly on other hp nc6400 laptop they both work great on the 220v standard adapter! Why isnt my laptop charging?? Please help
the 220 v power of cities has 25 Amper
has your inverter 25 A . of course not
so this is right that tow power sources have 220 VOLTS but the important matter for working
a device by power source is the out put AMPER plus output Voltage.
good luck
gorbesia
Jun 29, 2011 | Inverter 175 Watt Power Car Adapter for...
I cannot wake up my HP Pavilion dv3. blue power led flashes on and off and orange connection led too.
The display driver could have crashed, try holding the power button until the lights go off, and the hard drive powers down (you can hear the spinning stop) then try to power it back on. If that doesn't work, do a hard reset, which would be unplugging it from any AC power, and removing the battery and then reconnecting the battery before powering it on. Should this not work, i would say it's safe to assume the backlight is non functioning and a replacement would have to be ordered.
May 05, 2011 | HP Pavilion Dv3-1075us Notebook
Laptop fan has a noisy and pc is shutdown after some time ..so can I replace the fan ? pavilion dv3-2175ee
Jan 10, 2011 | Computers & Internet
I had HP pavilion dv3-2175ee loptop. i want driver for "network controller" ???
I just went and looked it up for you. I hope this link works for you. I was able t osee 7 network drivers.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?cc=us&lc=en&dlc=en&product=4029989
Best of luck..
Nov 18, 2010 | Computers & Internet
Computers & Internet Logo
418 people viewed this question
David Payne
David Payne
