Question about Watches
I replaced the battery now it won't come on. - Watches
Watch won't work after changing battery
Shortcut battery with AC contact. AC can be found on the sides of watch movement(very tiny). You have to use pointed tweezers: one end on battery+, another on AC contact for three secs..
Apr 20, 2013 | Watches
Won't run, it it battery operated?
yes it is battery operated,sudjest you get the battery changed at local jewelers.
Jan 09, 2013 | Fossil JR9413 Watch for Men
Why would a tissot t-touch need an overhaul to replace a dead battery
These babies are notorious for going down the tubes with a battery change. I bet if you get it back it won't work with a new battery. Twice I have replaced batteries and the watch didn't work when I finished. One of them was my own watch, I think $450 is about half the price of a new watch and that is sad. Cool watch just not very long life
Oct 01, 2012 | Tissot T-Touch T33759851
My Sportline won't zero the steps
find your watch off this link below click on it and download the manual
http://www.sportline.com/products/heart-rate-monitors.html
Sep 20, 2012 | Watches
New watch won't start
Maybe the battery is bad? If its new take it back to where ya bought it and tell them. Most places will replace of fix it. I would check the battery.
Aug 11, 2012 | Armitron Watches
Stop screen flashing on nike trax fury
Nike Triax Fury 100 Super
Yes you need to replace the battery. I had the same problem. Replaced the battery on mine and everything is fine now.
Nov 29, 2011 | Nike Triax Watches
Won't run anymore where can we get it fixed?
it's only a problem in the battery. you can replace on any watch service centers.
Jul 17, 2011 | Armitron Watches
It appears that the battery died and when I replaced it, the screen still won't turn on.
after replacing the battery you had to reset it. short the pads inside your watch or push all the buttons of your watch at the same time
Jul 08, 2011 | Watches
Need to know what battery goes in the fossil blue AM-3860?
Hello:
The battery number will be imprinted on the dead battery (for that watch it's most likely 379), however, I wouldn't recommend replacing a battery on a Fossil yourself. They are notorious for their back being incredibly difficult to remove and put back on and if you're not a professional, you will most likely break the crystal in the process. If it's a screw-back (and you can tell because it will have six rectangular shaped notches around the edge of the back) you won't be able to get it off unless you have a case wrench and a case vise. Take it to a jeweler and have them change it for you. Screw-back Style Case
May 12, 2011 | Fossil Watches
Replace battery for PULSAR Y911. how ro start it?
To restart the watch, you have to short the battery with a pin that sits under a sticker on the back of the watch. The sticker is supposed to explain that. You can usually do it with a pair of sharp scissors or tweezers. Without "jumpstarting" the watch, just installing a new battery won't start the watch. (I don't know why.)
Dec 04, 2009 | Pulsar Watches
Watches Logo
41 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
