Question about Vtech DECT 6.0 Cordless Phone with Digital Answering System
I am trying to re-program my access code. - Vtech DECT 6.0 Cordless Phone with Digital Answering System
Press setup and what they want you to do simple.(desi)
Posted on Apr 10, 2011
When ever i open the program it demands the activation code
If you want to use the program you will need the activation code. If you purchased the program the activation code will be on the box or CD. What program are you trying to access?
Feb 11, 2014 | Computers & Internet
How to reset the parental control code - I forgot the code and want to reset with a new one
This is what I found in the instruction manual on this and I posted it here for you. Try using 3355 for the code and everything else listed here. If that doesn't work, try the very last tip which tells you how to do a factory reset and repeat the first step using the 3355 as the code.
Here's the instructions from manual:
Parental Control
Parental Control allows you to block certain channels or programs so children cannot view
programs that are not age appropriate.
To enter the Parental Control menu, you need an
access code. The first time you enter, use access
code 3355. See "Setting an Access Code" on
page 33 for information on creating a new access
code.
You can set the following options to block
content:
• Channel Lock — Blocks selected channels
• Movie Rating — Blocks movies based on their rating (G, PG, PG-13, R, NC-17, and X)
• TV Ratings — Blocks TV shows based on their rating
• Block Options — Turns on or off all your parental control settings
NOTE: You can use Clear All to unblock the channels and programs that you have set.
NOTE: If the Block Control in the Parental Control menu is enabled, all the sub screens in POP (POP1,
POP3 and POP12) mode will be blank
Setting an Access Code m
After you enter the Parental Control menu for the first time, you can set your own four-digit access
code. If for any reason you lose or forget your access code, you can use the default code.
1 In the Parental Control menu, select Change Code.
2 Using the number pad on the remote control, enter a new access code.
3 Select Exit.
Reset the original factory defaults. Press Menu on the remote
control, select Setup, and then select Factory Reset
Jul 28, 2010 | Dell W4201C 42 in. Plasma HDTV
I am trying to program a button on my Norstar M7310 telephone with a line pool, but I don't know the line pool access codes. Where can I find those?
the access code is the number you dial to access an outside line like 9 or 81 etc.
To program a button to access a certain line pool, press feature *3 press the button you want to be the line pool access button then press feature 64 and the pool access code. ex. feature 649 or feature 6481
Nov 02, 2009 | NorStar M7310 Corded Phone
Trying to access memory card on my phone
MSL code is a code used in phone programming. Your carrier will most likely not give it to you.
Mar 27, 2009 | Samsung Instinct Cell Phone
Cannot access System Programming Mode
You need to get the ''installer code'' in order to get deeper into programming.
Thanks,
lucus123
Feb 15, 2009 | GE Security Simon 3 Wireless Home Security...
I have a Samsung U520 and I accidentally activated NAM2. Now my phone does not work. When I try to deactivate NAM2 it asks for a password. Can you help? It needs a 4 digit code. It also states Initial...
hi sir have you done restore factory settings firstThe Nokia 2160 series hand portable CMT uses an EEPROM NAM that can be programmed directly from the standard user keypad. In order to access the
NAM, you must enter the special access code currently programmed into the
phone. Once the programming mode is accessed, NAM parameters are loaded
by entering them into the display and "storing" them to selected memory
locations. Be sure to obtain all parameters before proceeding.
EASY NAM PROGRAMMING
1. Turn on phone.
2. Enter the Easy NAM access code. Access code is: *#639#
3. Verify the display now reads "Cellular Number" and enter the 10 digit
MIN for the phone.
4. Press the softkey under the word "OK" in the display. If less than 10
digits are entered an error message will prompt you to reenter the
number.
5. Verify the display reads "Enter code" and enter the five digit SID
followed by four zeros. (Example 001750000 is a SID of 175 followed
by four zeros). An error message will display if an incorrect entry
is made. Do not add more than four zeros to the code.
Note: Change the Lock code by adding a pound sign and new lock code after
the code. (Example: 001750000#7788. Lock code = 7788).
Change the Language code by adding a pound sign (#) and new
language code after the code. (Example: 001750000#2. Language = 2)
Language Code: 0 (default) = English, 1 = French, 2 = Spanish,
3 = Portuguese
Change the Lock code and Language code by separating each set of
numbers by a pound sign. (Example: 001750000#7788#2). The SID =
00175, Lock code = 7788, Language = 2 (Spanish).
6. Press the softkey under the word "OK" in the display.
7. The display will tell you t
Sep 10, 2008 | Samsung Cell Phones
Programming feature access keys
These Keys may be set as line keys instead of feature access or not tagged as "feature access" in the programming, also you can only have so many feature access keys... 8 comes to mind but I could be wrong, some features can be programmed permanently onto a button in the main programming so you can free up some more feature access (user programable) buttons.
Jul 18, 2008 | NEC Electra Elite DTU 16D-2 Corded Phone
Need to program access code into phone line for long distance numbers
Does it work when you press speaker/hook and manual dial same fax number you are trying to program
It sounds like you are adding digit needed for outside line when it is in fact a direct/dedicated fax line, that needs it not (or vise versa).
Are you printing a report of rapid/speed dials that you set to ensure the number you put in is correct?
Nov 05, 2007 | Brother IntelliFax-1860C All-In-One InkJet...
Vtech DECT 6.0 Cordless Phone with Digital Answering System Logo
51 people viewed this question
Top Vtech Lands Phones Experts
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
