Question about Filter Queen Vacuums
Carbon brushes on ME-48 power head motor worn out. Where can I get replacement brushes? Motor is O 90197X7, Lamb, Model 118173-73 - 240V 50/60Hz
  • 710 Answers
Hi Les,
Most sites sell only the motor.
Here's a website that includes motor brushes: http://www.kleen-ritecorp.com/search.aspx?IsSubmit=true&searchTerm=lamb+motor&gclid=CIbZ59zwiKgCFQprKgod8W2itQ
Hope you can find the right brushes.
I hope this helps. If it does, I'd appreciate your vote. Thanks,
Handie Andie
Posted on Apr 06, 2011
Motor carbon brushes
hi try potts in derby babbington lane ,very help full
Apr 08, 2013 | Sanyo Vacuums
Motor light comes on but motor does not start on Kirby Heritage II
Remember that the motor will not run unless the vacuum head or hose are properly installed. If this is not the problem, the most likely problem is that the carbon brushes in the motor are badly worn and will need replacement. A less likely problem is that the front safety switch is out of adjustment. While the light is on, remove the head and push the metal rod on the switch next to the fan inward to see if this causes the motor to run.
Jul 06, 2011 | Kirby Heritage II Vacuum
Motor smells hot after 5 minutes. Brand new exhaust filter turns black
First - stop using the machine! The black material in the exhaust filter is carbon dust from the carbon brushes in the motor. The fact that the motor quickly smells hot and is shedding so much carbon indicates that the carbon brushes are worn to their limit (or damaged). They need replacing. Don't use the machine again until the new carbon brushes are in place or you risk causing irreparable damage and will be in line for a costly new motor. Carbon brushes are usually not expensive but, depending on your expertise, you may need someone to fit them for you.
You don't tell us the make or model of your vacuum so that's about all I can say. Good luck.
Jan 23, 2010 | Vacuums
How to change carbon brushes
You need to know that very seldom will new carbon brushes alone `FIX`a motor in todays vacuums as they are higher RPM than those of 30 years ago.
On a salvageable motor a good rebuild procedure will generally include repacking bearings, cleaning suction fans and reseating new brushes with an abrasive seating stone at low speed with a motor run in device with variable voltage
That said, I have not done a HENRY in years but it likely will contain a generic AMTEK Lamb type motor as it is sold as more durable vac.
On a traditional vac motor, carbon brushes are removed by releasing a clamp over the brush. The brush holder will have either a flag terminal on it where the wiring will disconnect from the side, or a flat flag terminal which slides into a pocket on the carbon brush housing.
. If you are going to the trouble of replacing the brushes, remove and inspect the old ones for wear and chipping. Also inspect the commutator surface on the motor where the brushes contact. If there are any curved gaps between segments, or if the com is worn like an apple core , you need a motor complete.
If the motor has simply worn to the point where a brush has stuck or worn to nothing, you may be bale to reseat the new brushes, however any evidednce of BLUE sparks or noise is not a good sign . Best of luck. Post back if you need more help
Nov 01, 2009 | Henry Numatic "" Canister Vacuum
Eureka canister vacuum cleaner Model 6865
The 6865 has a high rpm AMTEK Lamb motor, Brushes will seldom solve the problem at this stage.
Once the sparking and burning starts the conectiion between the brush and commutator is arcing and burning. If the sparks are blue, save your time.
A good service tech will run in brushes with a seating stone and a low voltage setup to allow new brushes to seat, but this is generally best accomplished on heavy duty , lower rpm motors.
IF YOUR ARMATURE IS SCRATCHY LOOKING OR WORN LIKE AN APPLE CORE,OR THE SEGMENTS ARE NOT PARALLEL IN THE SPACING YOU WILL NEED A NEW MOTOR.
Oct 16, 2009 | Vacuums
No power. electric is OK. system will not turn on. Please help
Detach the vac itself from low voltage thin wiring leading to the house. With the vac plugged into power, try the manual switch and then try shorting across the low voltage exterior terminals with a rubber gripped set of pliers.
If you can hear a clicking inside, this is the vac's relay trying to start the motor. If the vac is more than 5 years old , or used more than 2 hours a week, you may need new carbon brushes, or a motor overhaul or replacement depending on wear. Carbon brushes are specific to the motor model # inside the vac, most often an AMTEK Lamb motor.
If you need brushes, the motors comutator should also be inspected for excess,wear, like gap ing between its conatct segments and "apple core" shaped wear
You you have a meter and can test for continuity across the motor leads, do so and post back.
If you don't have a meter, you will likely want to lift the vac off the wall after these checks and take to a repair shop, saving $$$$ for a house call...
Oct 06, 2009 | Broan-NuTone CV353 Central Vacuum
Need to replace motor brushes on Kenmore canister vacuum 116.25914503 - Getting lots of arcing at brush ends. Need tear-down steps to get at the brushes.
If you can see the arcing you are likely in the motor housing. The brushes are specific to the motor depending on RPM. Most brushes and motors in Sears units are supplied by AMTEK Lamb. The color on the plastic housing and stamped model # on motor will help identify the correct carbon brush, however new brushes will NOT always solve your problem if the motor is arcing.
If the armature is worn like an apple core or if the lines between segments on the copper commutator are gaping and not parallel you will need a new or rebuilt motor.
If brushes are properly removed there is a tiny flag terminal which will slide out of most brush housings where the wire meets the brush itself. New brushes are best installed after dressing the armature surface with a fine carbarundum seating stone or very fine wet dry sandpaper and then the motor is run in at half speed at reduced voltage.
|There is usually a hold down clamp over each brush to seat it and a lock tab underneath to align the new brush.
Sep 30, 2009 | Vacuums
Carbon Brushes wearing out quickly on Kirby Heritage II
4 possible reasons.
1 – one or both bearings are worn so armature (rotating part) wobbles as it is spinning and cause motor brushes to wear fast. Solution – change bearings too.
2 – Whoever replaced brushes – did not use some brush seating sticks to make cmutator smother and contour brushes to the shape of the comutator (not likely). Solution – appropriately install new set of brushes.
3 – Comutator is so warped that seating sticks do not help anymore – solution – new armature or turn the old armature.
4 – The fact that ONLY ONE brush was worn may mean that there is something wrong with the brush or housing. Maybe it could not move freely within the housing? I think this may be most likely cause it it may be a combination of all 4.Is it worth to fix? Hmm depends how much will it be. If this is 100+ - I’d say get newer Kirby for 300 ad enjoy the tech drive (Heritage does not have tech drive so it is much harder to vacuum with than the newer models)
Nov 05, 2008 | Kirby Heritage II Vacuum
Do i need to do anything special when replacing the brushes in a lamb ametek 117500 motor? It looks like I can just remove the old brushes and insert the new ones. Is it this simple? Will the motor work...
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=758676
Generic problem for all Vacuums
Do I need to do
Posted by edkraynak on Jul 08, 2008
Do I need to do anything special when replacing the brushes in a lamb ametek 117500 motor? It looks like I can just remove the old brushes and insert the new ones. Is it this simple? Will the motor work again? Thanks
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Make sure they are the right carbon brushes for your particular lamb motor and once you have installed the new ones then there is a seating chalk that you place against the armature to help seat the carbon brushes, you can pick up the seating chalk @ your local vacuum cleaner store or contact Lamb / Ametek listed below. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.ametek.com/contact/index.cfm
Customer Service – 610-647-2121
AMETEK Corporate Office
37 N. Valley Road, Building 4
P.O. Box 1764
Paoli, PA 19301 U.S.A.
Tel: 610-647-2121 Fax: 215-323-9337
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 08, 2008 | Vacuums
Vacuums Logo
185 people viewed this question
Top Filter Queen Vacuums Experts
Steve Sweetleaf
Steve Sweetleaf
Are you a Filter Queen Vacuum Expert? Answer questions, earn points and help others
