On the screen is only /attention / entering sleeping mode/no video input what is a problem?
  • 68 Answers
1.This means that your comp is supplying power to the comp...
2.check video cable...unplugg and replugg...
3.Still not resolved...unplugg all the devices from the back including the power cable...
4.then press and hold the power button for 20 sec...then connect the power cable keyboard mouse and the monitor cable...
5.then try to start the comp...
6.still not fixed...switch the voltage selector at the back...
7.still not fixed need to reset the ATX cable inside the comp...
8.Still not fixed can be a hardware problem...
Posted on Apr 06, 2011
I have a kyocera kc 100 viewer and it wont wake up the pc monitor can ya help?
I'm confused as to how you're connecting this with s-video. Are you using an RGB / s-video adapter?
What is the exact monitor brand / model?
Jan 12, 2008 | Sharp 17" Monitor
My Dell Monitor keeps going into sleep mode immediately after booting up.
Make sure your computer's screen resolution is fine for that when you power up the computer press F8 key 5 to 6 time untill you can see safe mode and other menu if you are able to see safe mode then enter in enable vga mode then enter as admnistrator go to control panel->display property ->settings change screen resolution to 1024*768 then apply and restart it.Let me know if you need further assistance.Thanks for using FixYa.
Aug 03, 2011 | Dell Dimension 4600 PC Desktop
Screen went black and a window came accross the screen saying attention entering sleep mode......and then it said no video input...
It sounds like the problem is in your computer, hook a spare monitor to verify, if you have the same problem, it is your tower that needs to be checked out.
Mar 25, 2011 | Philips Computers & Internet
I need to know the service mode of JVC TV flat screen
With TV powered ON press: [DISPLAY] and [VIDEO STATUS] on the remote at the same time.
-or- Press the [SLEEP TIMER] key and set the SLEEP TIMER for "0" MIN. While the SLEEP TIMER information is still on screen, press the [DISPLAY] key and [VIDEO STATUS] key of the remote control unit at the same time to enter the SERVICE MENU.
Exit the service menu by twice pressing the [EXIT] key on the remote.
Mar 18, 2011 | JVC AV-32S575 32" TV
HP monitor going into sleep mode right after turning it on
If it goes in to sleep mode, that means that the monitor is not getting a signal from the computer.
The things to try (from simplest to most complex) are:
  1. Make sure the computer is on and not in "sleep" mode -- press the "Caps Lock" key and see if it lights up the caps-lock light on the keyboard.
  2. Make sure the video cable is connected from the computer to the monitor (that the cable hasn't come loose on either end)
  3. If your monitor has multiple inputs, make sure it's set to the right (probably analog VGA or DVI) input
  4. If your computer has more than one video output (like a laptop with it's internal screen plus the external monitor) then make sure the external monitor is enabled
If none of those solve it, post a comment back here and we can dive in to the more complex tests
Sep 06, 2010 | HP w1907 LCD Monitor
When i press the power button to turn off monitor, i get a power button lockout message. how do i unlock the power button
I did not see anything regarding to the Power locked out function, may be it's time to call HP. Please post back what you find out from HP.
I look at HP WEBSITE: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01632269&tmp_track_link=ot_recdoc/c01643091/en_us/c01632269/loc:1&lc=en&dlc=en&cc=us&product=3770762
Locking OSD settings
When the OSD is locked, settings cannot be changed in the OSD menu. The OSD functionality is enabled or disabled by pressing the Menu button and holding it for 10 seconds. Upon disabling the OSD, an OSD Lock-out message is displayed for 10 seconds. When the OSD is locked and an OSD menu button is pressed, the OSD Lock-out message is displayed for an additional 10 seconds. When the OSD is locked, pressing the OSD menu button for 10 seconds unlocks the OSD and displays the main menu. Identifying monitor conditions
Special messages display on the monitor screen for the following monitor conditions:
  • Input Signal Out of Range : Indicates the monitor does not support the input signal because the resolution and/or refresh rate are set higher than the monitor supports. Recommended refresh rates are as follows:
    • For the w1858 monitor: 1366 x 768 @ 60 Hz.
    • For the w2338h monitor: 1920 x 1080 @ 60 Hz.
  • Monitor Going to Sleep : Indicates the screen display is entering a sleep mode.
  • Check Video Cable : Indicates a video input cable is not properly connected to the computer or monitor.
  • OSD Lock-out : When the OSD is locked, the warning message OSD Lock displays for 10 seconds.
  • No Input Signal : Indicates the monitor is not receiving a video signal from the computer on the monitor video input connector. Check whether the computer or input signal source is off or in the power-save mode.
  • Auto Adjustment in Progress : Indicates the auto-adjustment function is active and in process.
May 13, 2010 | Computers & Internet
Can't get into service mode av-56pw74
MENU.
Please rate our help to keep the free service online
Aug 28, 2009 | JVC AV-56WP74 56" Rear Projection...
No DVi input, then computer goes to sleep
Hi publicworker,
I had a similar problem whereas my monitor went to sleep mode after a few minutes. I'm running an HP LP 2065 in dual mode with another HP flat screen. However, I did resolve the issue after resetting the output settings.
How to do that:
  • right mouse click on the desktop
  • select graphic options
  • output to
  • extended desktop
Maybe some changings/modification will help you too.
Stefan
Jan 31, 2009 | HP 2025 20.1" Flat Panel LCD Monitor
JVC HD-52G786 Service Mode
Sure. I'm not sure if you can do it without the original remote, though. On my remote, you need to have the tv turned on, then press the sleep timer, then press the display and video status buttons simultaneously. This enters the service mode. Then, you should see an option for self-check (#2 i think). Enter that, then you should see 2 vertical columns of different inputs. From that screen, power the tv off. This resets all the ports on the tv.
Jun 18, 2008 | JVC HD-52G786 52" Rear Projection HDTV
Computers & Internet Logo
781 people viewed this question
David Payne
David Payne
